AU ECU problems
terry j
PostPosted: Thu May 01, 2008 6:36 pm    Post subject: AU ECU problems Reply with quote
Au futura auto had tickford motor fitted by a company but cannot get car to start with the tickford ECU they have supplied I can not find out if it is a manual ECU or an auto that has other problems . the numbers on the one supplied are as follows 1RC23-12A650-CB other No's are 12CB 004121 If any one can help please as i would like to get it sorted by the way it is running on the standard AU ECU at the moment
foggy
PostPosted: Fri May 02, 2008 10:05 am    Post subject: Reply with quote
Is it a Smartlock or smartshield ECU? that is why it isnt starting as the lock/sheild is not setup for your bem.
terry j
PostPosted: Fri May 02, 2008 7:26 pm    Post subject: Reply with quote
thanks Foggy.
The car is a smartlock system . The motor and ECU are from a 2000 model fairmont ghia. which is smartsheild system . according to ford , is there any way this can be resolved other than replacing the BCM or refitting a stock motor back in . Thanks Terry
foggy
PostPosted: Fri May 02, 2008 8:46 pm    Post subject: Reply with quote
The easiest way I can think of is to try and get an ecu out of a 99 au which has smartlock on it. Im assuming the new motor is a VCT one???
terry j
PostPosted: Fri May 02, 2008 9:58 pm    Post subject: Reply with quote
Hi Foggy , Yes the motor has VCT. I am new to this and trying to help out our daughter who has the problem . Thanks again for your information
foggy
PostPosted: Sun May 04, 2008 9:50 am    Post subject: Reply with quote
Hi Terry, You should be able to use the motor with your current ecu but you will need to rig a trigger for the vct. Have a look through the 6 cylinder workshop for more info
foggy
foggy
Sorry about the double post
AU99
PostPosted: Fri May 23, 2008 12:32 am    Post subject: Reply with quote
any luck yet????
have seen a VCT motor put into a AU before but they had to put in the full wiring loom in ECU, BEM etc
another thing is that you cant just put in another ecu, ford have to program it to work from what I have been told. not like the EF-L's where you turn the ignition on for 30-60mins so it relearns
[36 queries :: 0.03027 seconds ]
