vorno Fordmods Newbie
Age:40 Posts: 2 Joined: 15 Jun 2008 Location: CAirns QLD, Australia
Posted: Sun Jun 15, 2008 8:20 pm Post subject: Au engine into EL |
Hello.
A mate of mine has put an Au into an EL auto wagon. Changed the sump etc etc and all in and working.
Only thing is - it is really down on power, sluggish take off etc. Throttle opens fully wide, had the injectors etc checked and the EFI checked. Was statically timed on installation.
Is this likely to be an ECU problem - like a default programme that needs a reset, or does the chip or programme need changing?
Any clues? |
Age:39 Posts: 660 Joined: 07 Sep 2007 Location: Brookfield VIC, Australia
Posted: Sun Jun 15, 2008 9:05 pm Post subject: |
| needs ECU I think for best operation. Probably bay loom as well |
madeaspack Fordmods - Getting Side Ways
Age:23 Posts: 814 Joined: 18 Jan 2005 Location: MAFFRA VIC, Australia
Posted: Wed Jun 18, 2008 6:30 pm Post subject: |
| does it ping? could be not advanced far enough,thats what i reckon it is,had same problem with mine,wou wont need to change ecu if you used all el bolt on accessories |
Age:33 Posts: 1026 Joined: 14 Dec 2007 Location: delegate NSW, Australia
Posted: Wed Jun 18, 2008 8:13 pm Post subject: |
What is the timing set at?
And what type of fuel pressure regulator is he running?
Is it running smooth or rough, or? |
macxr8 Fordmods Stock as a Rock
Age:39 Posts: 190 Joined: 03 Jan 2005 Location: Sydney NSW, Australia
Posted: Thu Jun 19, 2008 7:57 am Post subject: |
| check that you have the map sensor and air intake sensors hooked up. You will need to run the EL top half of the BBM, and also make sure the EL bottom half of the thermo housing with the temp sender |
