AU falcon Wade 1502a cam
Goto page Previous  1, 2, 3, 4
Grimketel
PostPosted: Mon Sep 22, 2008 11:31 pm    Post subject: Reply with quote
I see. will be investigating a 12 month working visa to the UK so I may have to shelve my plans of doing up the AU any further which is a shame, but i will still watch this space very closely incase I do end up camming it...
GeZza200
PostPosted: Tue Sep 23, 2008 7:42 am    Post subject: Reply with quote
I picked up the cam yesterday, i will book it in next week to get the cam in. I'm just wondering how the ECU will cope with it. Because i will be getting the unichip a little bit later on now.
edfairmont4.0
PostPosted: Tue Sep 23, 2008 8:32 am    Post subject: Reply with quote
Hey dude good work with the new engine lol i wish my rebuild was free! lol $2000 later......
and by the looks of that cam spec the computer SHOULD handle it no worries at all. you just might need a bit more juice up top...
GeZza200
PostPosted: Tue Sep 23, 2008 8:59 am    Post subject: Reply with quote
cheers, so it will lean out up at the top end?? will the unichip be able to fix that or will i need new injectors?
FordFairmont
PostPosted: Tue Sep 23, 2008 10:04 am    Post subject: Reply with quote
it will be fine
edfairmont4.0
PostPosted: Tue Sep 23, 2008 10:14 am    Post subject: Reply with quote
IF it needed more juice the uni chip should be able to fix no worries, i dont think it would need more though.
If it was VERY lean you would need injectors.
GeZza200
PostPosted: Tue Sep 23, 2008 11:25 am    Post subject: Reply with quote
FordFairmont wrote:
it will be fine
Gday, you went from a 1636 to a 1673 didn't you or was it 1636 to 977B. Was there much difference?
FordFairmont
PostPosted: Tue Sep 23, 2008 11:47 am    Post subject: Reply with quote
yep 1636 to 977b
The 977b made the most power in mine so far. I went with a larger Wade cam and made slightly less power & torque.
Because yours is auto though, for a top end cam to work well, you would need shorter diff gears
GeZza200
PostPosted: Tue Sep 23, 2008 11:52 am    Post subject: Reply with quote
ok, with the 1671 spec sheet on the other page is there much difference between that and the 977B? I will be getting different gears. But i might need a different housing by the looks of it.
FordFairmont
PostPosted: Tue Sep 23, 2008 3:15 pm    Post subject: Reply with quote
the 1671 specs seem to be closer to the e-series 1673 cam.
I tried using that "cam cat" program to see whats available for the AU and it confused the f**k out of me.
GeZza200
PostPosted: Tue Sep 23, 2008 3:23 pm    Post subject: Reply with quote
Yeah its not the easiest thing to use. I dont think it's up to date aswell. Im just wondering if i should get the same person to put my cam in, because he blew my engine before lol
FordFairmont
PostPosted: Tue Sep 23, 2008 3:47 pm    Post subject: Reply with quote
yeah i dunno how he f**k it last time, the cam only goes on one way onto the cam gear because of the keyway.
Simple as keeping tension onto the chain and removing the bolt on the cam gear sprocket and swapping cams over. Also fitting shims into the rocker arms if its a regrind.....
I'd be spending money on diff ratio change next if i were you
GeZza200
PostPosted: Tue Sep 23, 2008 3:51 pm    Post subject: Reply with quote
yea i will. my diff is a locker atm so it needs to be fixed. skips arond corners and tyres are wearing so quick
Grimketel
PostPosted: Tue Sep 23, 2008 11:30 pm    Post subject: Reply with quote
as long as you get the gears from an r31 the gears will fit fine. had no probs fitting em in the au. good luck finding 3.7's from the r31 manual though, you will find pintara 4.11's everywhere, best bet is 3.89 from the r31 auto.
GeZza200
PostPosted: Wed Sep 24, 2008 3:50 pm    Post subject: Reply with quote
I have found 3.7's are they a good choice for the auto
edfairmont4.0
PostPosted: Thu Sep 25, 2008 9:17 am    Post subject: Reply with quote
you will probably still get 75-80 from first i got 65 from first with 4.11s which was good i thought and highway cruising is 2300 at 100.
GeZza200
PostPosted: Thu Sep 25, 2008 9:35 am    Post subject: Reply with quote
that seems to be ok, i dont want it reving to high at 100k's because i go on the freeway a fairbit
Page 4 of 4
[44 queries :: 0.04625 seconds ]
