AU falcon XR series
bud and lynn
PostPosted: Fri Jan 07, 2005 4:17 pm    Post subject: AU falcon XR series Reply with quote
i have an AU futura Wagon with xr extras..
does anyone know if it is common for the rear door actuator to f**k up or have i got a painful car
i would also like to know if fitting a v8 air intake to the six is worth the effort
XCH45R
PostPosted: Fri Jan 07, 2005 4:28 pm    Post subject: Reply with quote
alot of guys on here are running AU XR8 intake snorkels and think they are just as good as the SS inductions product.. No idea about the rear door mate.
bud and lynn
PostPosted: Fri Jan 07, 2005 4:30 pm    Post subject: au intake Reply with quote
ty dude
that couple ith a 21/2 inch single muffler system should give me about 15 to 20 kw shouldnt it
uglybob
PostPosted: Fri Jan 07, 2005 4:36 pm    Post subject: Re: au intake Reply with quote
bud and lynn wrote:
ty dude
don't be expecting any real rwkw gains from an intake like that - it helps the engine breathe easier - doesn't add mega rwks's - *maybe* 1-2 at most, if at all. as for the exhaust - the only real way to find out what gain you'll get is to dyno before & after! there are no guarantees on what any particular exhaust will give you - chuck extractors on at the same time - you'll get a better result with that.
the actuators on AU's were pretty good AFAIK - so you might just have one dodgy one - i *think* they are about $100 or so to replace, so worth doing - i couldn't see you having any real problems like the EF's...
bud and lynn
PostPosted: Fri Jan 07, 2005 4:41 pm    Post subject: au Reply with quote
what can i do to make easy gains with the au ......i know i need to make the intake and output bigger but what about chip wise
uglybob
PostPosted: Fri Jan 07, 2005 4:45 pm    Post subject: Reply with quote
chips only after you've done a heap of other stuff - look at a new cam (stg 2 you can run up to with stock computer - talk to wade cams they give FM members discounts) as well as extractors etc - also mandrel intake, K&N filter, etc - the basic stuff, then you should start looking at the more expensive s**t...
xr8 dismantler
Commercial Sponsor
PostPosted: Fri Jan 07, 2005 9:37 pm    Post subject: Reply with quote
the rear door acctuators are very common for failing we sell a s**t load of them. heaps more than the EF ones. 10 au ones to 1 ef one.
also while your looking at your mods try a shift kit and a diff ratio change.
i have a 3.45:1 lsd that would go nicely under the back of it. icon_lol.gif
LG
PostPosted: Fri Jan 07, 2005 10:10 pm    Post subject: Reply with quote
From a full exhaust and intake mods, you could be looking to about a 20kw gain at the fly. Otherwise you'll be looking at about 115rwkw.
Get a AUII XR8 snorkal, for $30, you cant go wrong. Get a K&N or BMC Flat Panel filter ($150). Then look at a wade cam, or a JMM kit.
http://www.jimmockmotorsport.com/
Bomber
PostPosted: Fri Jan 07, 2005 11:43 pm    Post subject: Reply with quote
hmm the door actuators seam pretty common mine went about a month after i got the car.
xr8 dismantler: what do ya charge per rear door actuator for the AUs?
bud and lynn
PostPosted: Sat Jan 08, 2005 1:05 am    Post subject: Reply with quote
i got quoted $87 for labour and around $100 for the actuator per door
that is from a dealer tho
can anyone tell me how far i can advance the timing on a 4.0 litre intech motor
am doing a couple of thousand k's this week icon_cool.gif and wouldnt mind saving on fuel icon_biggrin.gif
Bomber
PostPosted: Sat Jan 08, 2005 1:21 am    Post subject: Reply with quote
who 87 labout and 100 a side, i got mine from my mate a ford 70 a side there not hard to do either think it took us about 15 mins in total
bud and lynn
PostPosted: Sat Jan 08, 2005 1:41 am    Post subject: actuator Reply with quote
The price is about right for a dealer
does anyone know if there is an XR rear bumper kit for a wagon in the AU....would like to finish the car off and that with a set of Gmax wheels would look real good i think
xr8 dismantler
Commercial Sponsor
PostPosted: Sat Jan 08, 2005 9:03 pm    Post subject: Reply with quote
$45 each side for FM members only so make sure you tell me (Darren) or mooch where you are from
Nanger
PostPosted: Sun Jan 09, 2005 8:11 am    Post subject: Reply with quote
I think a lot of people over look changing their diff ratios to a shorter/lower geared one for an increase in performance. While it won't make any difference to your RWKW, it makes a huge difference to 0 to 100km/h times, and should knock off a bit over the 1/4 too.
[41 queries :: 0.06945 seconds ]
