Pane Fordmods Tyre Shredder
Age:22 Posts: 345 Joined: 28 Nov 2004 Location: Melbourne VIC, Australia
Posted: Tue Jan 18, 2005 11:16 am Post subject: au into xf |
G'day
This has probably been covered before but i am wondering if it is possible to put an au2 motor into an xf.
What are the clearances like in the engine bay.
Cheers |
Posted: Tue Jan 18, 2005 7:33 pm Post subject: |
should drop straight in using XG Engine mounts
the bigger drama will be the electrics |
smoke_ Cruise Moderator
Age:24 Posts: 5814 Joined: 05 Nov 2004 Location: Brisbane QLD, Australia
Posted: Tue Jan 18, 2005 8:41 pm Post subject: |
| Interceptor wrote: | should drop straight in using XG Engine mounts
asorry to get off topic, but are the xg engine mounts different to ea/eb?
and yes it is possible to put an au motor in an xf. |
neil101 Fordmods - Smokin em up
Age:27 Posts: 240 Joined: 11 Dec 2004 Location: kellyville NSW, Australia
Posted: Tue Jan 18, 2005 10:28 pm Post subject: |
| nope same up to ED only changed on EF upwards |
Posted: Tue Jan 18, 2005 10:31 pm Post subject: |
| smoke_rubber wrote: | | Interceptor wrote: | should drop straight in using XG Engine mounts
asorry to get off topic, but are the xg engine mounts different to ea/eb? |
f**k if i know, all i know is they're the ones u need to drop an EA-AU 4.0l into an XF |
xr8 dismantler
Age:37 Posts: 3084 Joined: 06 Nov 2004 Location: MELBOURNE VIC, Australia
Posted: Tue Jan 18, 2005 11:15 pm Post subject: |
| engine mounts are the same up to ED. the mounting plates on the chassie need to be changed to the XG ones.like you would when you change from a 6 to a 8 in a X series |
Posted: Wed Jan 19, 2005 4:21 pm Post subject: |
Whats the big drama with the electrics?
If you have the computer that goes with the motor wheres the problem.
Cheers |
4.9 EF Futura Moderator
Posted: Wed Jan 19, 2005 4:27 pm Post subject: |
| Pane wrote: | Whats the big drama with the electrics?
Cheers |
ECU likes to talk with body control module and dashboard for smartlock/smartshield etc. |
Posted: Wed Jan 19, 2005 5:07 pm Post subject: |
do you have to have that stuff conected or can you by pass it.
Cheers |
Age:23 Posts: 2432 Joined: 07 Nov 2004 Location: geelong VIC, Australia
Posted: Wed Jan 19, 2005 5:24 pm Post subject: |
| you would most likely have to go to an aftermarket ECU, so if you can get the BCM (or is it BEM - i forget) and the rest of the dash wiring i suggest you do, even then your gonna have troubles with the ignition lock, you should be able to run the au motor (with a coupla changes) with an EB (pre smatlock one) computer. (without the broadband manifold) |
xr8 dismantler
Posted: Wed Jan 19, 2005 9:25 pm Post subject: |
If you use a series 1 au vct motor and computer with smartlock (ive got one for sale )
you can buy a module from petroject that disables the smartlock and allows you to obsolete the BEM |
