blueblood Fordmods Newbie
Age:31 Posts: 15 Joined: 12 Jun 2005 Location: sydney NSW, Australia
Posted: Sun Nov 09, 2008 1:10 am Post subject: AU maf in ED? |
| Can anyone tell me why AU extractors dont fit e-series, and what, if anything has to be done to use the bigger AU maf on my ED? |
COBRAED Fordmods Stock as a Rock
Posts: 108 Joined: 22 Jun 2008 Location: INGLEWOOD QLD, Australia
Posted: Sun Nov 09, 2008 8:01 am Post subject: |
| blueblood wrote: | | Can anyone tell me why AU extractors dont fit e-series, and what, if anything has to be done to use the bigger AU maf on my ED? | I'm assuming your ED is a V8?, if so the AU extractors won't fit cause of the steering knuckle on the e-series, ( i found that one out aswell!!).
As for the AU maf you can put that on, you just got to change your electronics over.
Hope that helps.
Jason.  |
cjh Fordmods - Getting Side Ways
Age:40 Posts: 3037 Joined: 18 Dec 2006 Location: rockhampton QLD, Australia
Posted: Sun Nov 09, 2008 4:00 pm Post subject: |
| I think the plugs for the MAFs are different too. |
Posted: Sun Nov 09, 2008 8:47 pm Post subject: |
| cjh wrote: | | I think the plugs for the MAFs are different too. | Correct me if i'm wrong, but you do change the electronics over, ED electronics to the AU maf?
That's what other fella's are doing, well so i've read!!. |
Posted: Mon Nov 10, 2008 11:43 pm Post subject: |
| I hoped that was the case, now I just have to hope the soon to be installed lpg mixer doesnt make a bigger maf & t/b useless! |
banarcus Fordmods - Getting Side Ways
Age:34 Posts: 582 Joined: 29 Nov 2004 Location: Kurri Kurri NSW, Australia
Posted: Tue Nov 11, 2008 8:28 am Post subject: |
| Your mixer will be the restriction. It will only be about 44mm ID and your MAF is 55mm. Mine still goes well on LPG with my mini MAF. |
HELL LPG Fordmods Newbie
Age:26 Posts: 8 Joined: 30 Oct 2008 Location: sunny carrum downs VIC, Australia
Posted: Tue Nov 11, 2008 9:50 am Post subject: |
ive put the au maf body and au xr8 t/b in my ed 5.0 it works really well noticably more power even with lpg as i am running a impco 425 mixer.
with the mixer removed it runs real sweet lots more flow = more power |
millard455 Fordmods - Getting Side Ways
Age:24 Posts: 824 Joined: 19 May 2005 Location: naracoorte SA, Australia
View User Gallery (29)
Posted: Tue Nov 11, 2008 10:38 am Post subject: |
| yep as said you can put your maf electronics in the au maf housing but id recomend that you have your afr's checked after doing the swap. some people have had issues and some havent but none the less its worth checking. |
