au series stereo changes NEED HELP
Enilate
PostPosted: Sat Apr 19, 2008 7:15 pm    Post subject: au series stereo changes NEED HELP Reply with quote
hi all
i recently bought a single din dvd unit for my falcon and wanted to know how do i go about installing it into a double din space i know i will need a pocket for the open whole that will be left underneath. but was wondering how i secure it.
thanks
Airved
PostPosted: Mon May 26, 2008 12:37 pm    Post subject: Reply with quote
I'd like to know this too (I know the thread is a month old).
I've got a fairmont AU with double din player and Ive got my old single din H/U out of the EA. Will the plastic pocket out of the EA fit underneath the H/U in the AU?
In case you don't know what i mean by pocket, it's this thing:
Airved
PostPosted: Tue May 27, 2008 10:50 am    Post subject: Reply with quote
Can you buy just the pocket on its own from somewhere?
dave0
PostPosted: Tue May 27, 2008 7:20 pm    Post subject: Reply with quote
jb hi fi sell the au pockets
BIONIC
PostPosted: Thu May 29, 2008 8:07 pm    Post subject: Reply with quote
Get 1 from ford. Part number (er 18846 a1) about $22
Airved
PostPosted: Mon Jul 07, 2008 5:54 pm    Post subject: Reply with quote
I can't seem to pull the stereo out of my car. I've bought those crap tools off ebay to try and pull it out, but they just keep sliding out. Anyone had this problem? Is there anyway of just popping it out with a screwdriver? I'll give JB a go soon and see if they know how.
arcpanda
PostPosted: Mon Jul 28, 2008 3:05 pm    Post subject: Reply with quote
[quote]I can't seem to pull the stereo out of my car. I've bought those crap tools off ebay to try and pull it out, but they just keep sliding out. Anyone had this problem? Is there anyway of just popping it out with a screwdriver? I'll give JB a go soon and see if they know how.
[/quote]
I had the same problem with my car (AUIII), after many hours of trying with the tools and various other methods i had to rip the factory unit out by destroying the face and physically releasing the latches. The latches wouldn't release with the tools because whoever had the car before me tried to remove it and stuffed them, when the proper tools were inserted they pushed the latch outwards instead of in! If you opt for the destructive method don't be afraid to damage the unit, mine was completely annihilated after i was through with it.
And with the single din headunit, mine came with a cradle that you simply bent the tabs over. With the pocket i got from Autobarn (designed specifically for AU dash, cost <$20), it held in perfectly.
lil_lincoln
PostPosted: Mon Jul 28, 2008 9:15 pm    Post subject: Reply with quote
well your stupid for having to do that.
all you need is a wire coat hanger straighten it out, cut the ends off that twist then cut it in half bend both halfs in half again to for a tight u with long prongs, then stick one tool in each sides 2 holes. then push the 2 tools away from each other (to sides of car) this should push the pins in and pull towards you, does take a fair bit of time but u will get it, took me agesss to do my borthers car, also you can buy the pockets from jb hifi about 11 dollars i think from memory, and just painted it black with vynal paint as he has an xr6
fourL6
PostPosted: Mon Jul 28, 2008 9:35 pm    Post subject: Reply with quote
this is how iv mounted mine... iv made 2 taps of the top of the bracket (that comes with the head unit) and screwed them in here... holds up the back of the unit up and the front is kept in place bye the pocket... this is how it looks installed... please note these photos make my dash look really s**t... its not i actually just bought new heater controls (the mat black bit)
adam_k
PostPosted: Mon Aug 11, 2008 10:32 pm    Post subject: Reply with quote
argh pain in the a** headunit... i'm currently changing mine to a single DIN... i have the pocket and all... i just cant get it in there securely. whats the best go (as far as getting the bracket mounted)?
cheers, adam
fourL6
PostPosted: Mon Aug 11, 2008 11:39 pm    Post subject: Reply with quote
hey adam the pictures above show the best way i have found to keep the rear of the headunit from falling down...
to take of the surround you have to undo undo 2 screws behind the ashtray and 2 screws at the left and right of were the cd player was, then gently unclip the res of the surround and disconnect the heater controls an clock. then mount a cage as shown above...
adam_k
PostPosted: Wed Aug 13, 2008 6:13 pm    Post subject: Reply with quote
cheers!
ended up drilling screwing it into the sides ... just have a little gap to fill at the top.
sikford
PostPosted: Tue Aug 19, 2008 8:56 am    Post subject: Reply with quote
what did u use as a "cage" to mount at the rear f the deck?
sikford
PostPosted: Tue Aug 19, 2008 8:57 am    Post subject: Reply with quote
dw, just re-read ya post.lol.my bad
[41 queries :: 0.05681 seconds ]
