AU straight gas versus petrol
relaxed_diplomacy
PostPosted: Tue Jun 17, 2008 7:48 pm    Post subject: AU straight gas versus petrol Reply with quote
Does anyone know the main differences between the straight gas AU motor and the normal AU motor? Particularly in regard to efficiency and gas system.
-GAS-MAN-
PostPosted: Tue Jun 17, 2008 10:40 pm    Post subject: Reply with quote
The straight gas engine will have advanced ignition timing and possibly harder valve seats.
The falcon engines have the hardest stock valve seats, but the straight gas engine may be improved moreso.
I would assume the ecu would be different and the engine compression may also differ.
Im very interested in this area also, so if anyone here knows better please correct me icon_smile.gif
Mechan1k
PostPosted: Tue Jun 17, 2008 10:58 pm    Post subject: Reply with quote
The actual main engine is identical ... compression ratio is identical ... valve seat are identical.
The only difference I can see is the throttlebody is a once-piece unit with the gas feed in the side of it (built in mixer ring) ... the ECU is different as well as it runs stepper motor metering instead of injectors ... spark map would be different as well.
Rocker cover is different.
That's about it ... oh there's colant lines running around the back of the engine to the converter as well.
Fuel lines are different and tank locations as well.
Oh ... there's also no cylinder shut-down setup in the ECU as well when temps get too warm ... due to backfiring issues ...along with lack of TC as well ... fro obvious reasons.
These are just to name a few things off the top of my head that I can remember when looking at both petrol and LPG engines side by side.
-GAS-MAN-
PostPosted: Tue Jun 17, 2008 11:04 pm    Post subject: Reply with quote
Nice work mechan1c thanks, hopefully those valve seats dont need to be any harder icon_smile.gif
Mechan1k
PostPosted: Tue Jun 17, 2008 11:11 pm    Post subject: Reply with quote
Nah I doubt it ... I had to replace my EGAS engine (as the head wouldn't part with the block ... so it was cheaper to replace the engine than try and get it apart.
I picked up a petrol AUIII engine with 66,000km on it ... it was the same really. Made the same power before and after replacement too. I found some info on it and they are identical block-wise. Not sure of the cam was the same though ... I used my cam I had anyway when i swapped the motors over.
xpression
PostPosted: Tue Jun 17, 2008 11:31 pm    Post subject: Reply with quote
actually you are not quite right, the Egas motor has a different head and a different compression ratio
Mechan1k
PostPosted: Tue Jun 17, 2008 11:34 pm    Post subject: Reply with quote
On B-series yes the compression ratio was different in the EGAS models ... not on AU2-3 ... comp ratio is the same at 9.6:1
relaxed_diplomacy
PostPosted: Wed Jun 18, 2008 12:19 am    Post subject: Reply with quote
Is there a significant price difference, secondhand?
Are they available ex non commercial, did Joe Blow buy them too?
It seems that in my case putting one into an EB there wouldn't be much advantage, mainly just the inlet manifold. Despite petrol prices, living where i do i should probably stick to dual fuel.
Last edited by relaxed_diplomacy on Wed Jun 18, 2008 12:31 am, edited 1 time in total
Mechan1k
PostPosted: Wed Jun 18, 2008 12:21 am    Post subject: Reply with quote
I just got myself a petrol 2ndhand motor as there were more available with LOW km ... it was hard finiding an EGAS engine with low kays on it.
relaxed_diplomacy
PostPosted: Wed Jun 18, 2008 12:40 am    Post subject: Reply with quote
Yes, even Joe Blow would likely only choose gas if he does heaps of kays, thinking that if he doesn't he won't recoup the extra purchase cost.
xpression
PostPosted: Wed Jun 18, 2008 1:30 am    Post subject: Reply with quote
i stand corrected.
Mechan1k
PostPosted: Wed Jun 18, 2008 1:37 am    Post subject: Reply with quote
That's cool ... I thought it was the case as well .. and I started digging around ... it took me a while to find the info ... but I found it eventually.
I was initially surprised when i found that AUs were the same ... I know Ford has to change the B-series with stronger rods and I think they used dome-topped pistons to bring up CR as well. It was strange though that the B-series suffered more from backfiring issues moreso than the AUs ... maybe it was due to the different ingition/spark setup (coil on plug).
Rick's EF Fairmont Wagon
PostPosted: Wed Jun 18, 2008 6:22 am    Post subject: Reply with quote
Kind of sounds like a Gas research set up?
Mechan1k
PostPosted: Wed Jun 18, 2008 6:33 am    Post subject: Reply with quote
Best bet is from a wrecker if you can ... I am pretty sure FTG Autosalvage had one recently ... Ford want well over $1000 for it if you feel like getting a new one.
gogetta
PostPosted: Tue Jun 24, 2008 11:40 pm    Post subject: Reply with quote
where did u find the info?
also i would be surprised if the EGAS didnt have different valves and seats....as its the weakest link in an LPG motor....ive seen heaps of badly pitted valves and seats on std falcon heads
AU99
PostPosted: Wed Jun 25, 2008 12:19 am    Post subject: Reply with quote
Tickford Duel Fuel AU have duel Fuel ECU and might have copped a different cam???
but S2/3 came as straight LPG didnt they?
[43 queries :: 0.05059 seconds ]
