Pane Fordmods Tyre Shredder
Age:22 Posts: 345 Joined: 28 Nov 2004 Location: Melbourne VIC, Australia
Posted: Mon Mar 28, 2005 9:55 am Post subject: au t5 into xf |
G'day
I bought an au xr6 t5 gearbox. I ve heard that they are longer than the original t5's in the xf, is this true?
If so do i just have to move the gearbox support crossmember back. Will the shifter fit in the same hole as the current box. What about the tail shaft, does it have to be shortened?
Cheers |
Posted: Wed Mar 30, 2005 6:00 pm Post subject: |
Thanks,
So the case of the gearbox is the same size as the one thats in my car atm and i dont need to change the tail shaft.
Cheers |
Jim Fordmods Parts Gopher
Posts: 59 Joined: 06 Nov 2004 Location: Wollongong NSW, Australia
Posted: Fri Apr 01, 2005 8:51 pm Post subject: |
| Arh, that all depends on what box you've got in there at the moment. The yokes are different to the autos, but the length is the same. |
Age:34 Posts: 2503 Joined: 06 Nov 2004 Location: Melbourne VIC, Australia
Posted: Wed Apr 06, 2005 6:42 pm Post subject: |
| there are only 3 sizes of slip flanges, 38mm dia (short) 38mm dia (long) and 42mm. if you need one drop me a line, im in s.e melb. they will be the original new spicer slip flange. the shaft shouldnt have to be re-balanced if changed over. have universal joints also if needed. |
Posted: Wed Apr 06, 2005 8:00 pm Post subject: |
Thanks
I'll keep you in mind when i change over the boxes. Where exactly is the slip flange.
Cheers |
