AU Tickford Snorkel into EB/ED V8
BuNtEr
PostPosted: Sun Apr 06, 2008 2:33 pm    Post subject: AU Tickford Snorkel into EB/ED V8 Reply with quote
EDIT
This will also work on the boxcar lanes and LTDs if you use the thermo fans from an EF/EL.
Parts and tools needed
„« Au Snorkel
„« 2x Self Tappers
„« 2 mil Drill Bit
„« Drill
„« Phillips head screw driver
Time to do this mod
Less than 20 minutes
Some of you have heard that the Tickford AU Snorkel will fit a EB/ED 5.0, and that it will also rub on the back of the snorkel from the power steering pulley, well it is true if you still use that s**t taxing Clutch fan.
If you install a set of EF/EL electric thermo fans you will have no problem with the AU Tickford Snorkel rubbing on the power steering pulley.
also the rubber on the inside of the EB/ED bonnet that goes around the stock EB/ED air intake snorkel will block part of the new AU Tickford intake, all you need to do is push the AU intake snorkel as far forward and drill 2 small holes into the top of the radiator support to hold the new AU snorkel in place, then the rubber will be behind it and out of the way.
After doing this easy as chips mod i found that the car seems to be slightly better in throttle response and the fuel economy seems just a tad better but not buy a great deal.
Oh thanks Brett for the Snorkel.
Here is a few photos of the AU tickford Snorkel on my EB and you can see all the clearance's on it.
Before the mod stock EB/ED Snorkel
The mod After
the clearance's
TerroristGHIA
PostPosted: Sun Apr 06, 2008 4:10 pm    Post subject: Reply with quote
Looks godd, well done, told ya it wouldn't take long to fit.
Brett
DRHEMI
PostPosted: Wed Apr 30, 2008 12:47 pm    Post subject: Reply with quote
Nice job...........
How much is an Au Tickford Snorkel, the one with wings?
knowsfords
PostPosted: Wed Apr 30, 2008 5:27 pm    Post subject: Reply with quote
if all ford plastic is created equal I'd say it'd be the same as an XR6T snorkel, $40ish from ford.
BuNtEr
PostPosted: Wed Apr 30, 2008 10:52 pm    Post subject: Reply with quote
you see them on ebay allot
Ben_Daui
View User Gallery (28)
PostPosted: Fri May 23, 2008 9:19 am    Post subject: Reply with quote
Ok I have the snorkel on the EB & attempted to install it on the NC, from what I can see reove the fan shroud & it will fit but taking that off I may as well do the thermo conversion.
BuNtEr
PostPosted: Fri May 23, 2008 9:55 am    Post subject: Reply with quote
well worth doing the thermo conversion
black.canman
PostPosted: Sun May 25, 2008 8:36 pm    Post subject: Reply with quote
so too do the thermo conversion do i need themos from an 8 or a 6 thanks
BuNtEr
PostPosted: Sun May 25, 2008 8:44 pm    Post subject: Reply with quote
they are the same dude it dont matter
black.canman
PostPosted: Sun May 25, 2008 8:53 pm    Post subject: Reply with quote
lol i thought so thanks for you quick reply mate yes im a noob but too ask is too learn icon_lol.gif
rootdog01
PostPosted: Tue May 27, 2008 6:34 pm    Post subject: Reply with quote
Was wondering if it would be worth my while running a 60mm diameter hose from the bottom front of my au xr6 into a hole in the airbox? would it make a differnce to the power?
BuNtEr
PostPosted: Tue May 27, 2008 8:48 pm    Post subject: Reply with quote
only one way to find out. ??????????????????????
rootdog01
PostPosted: Fri May 30, 2008 5:52 pm    Post subject: Reply with quote
bit worried about cuttin a hole in the air box. I heard puttin a ba snorkel on is the go. bigger intake opening.
[40 queries :: 0.04697 seconds ]
