MRFYI78 Fordmods Newbie
Age:30 Posts: 12 Joined: 04 May 2008 Location: Adelaide SA, Australia
Posted: Mon May 05, 2008 7:54 pm Post subject: AU turbo set up???? |
Ok, would like to know of peoples ideas and thoughts.......
So i have a AU XR6 ser1 ute, stock as atm and im looking at either 1, Adding a turbo kit to the AU motor and building it up to suit.
2, Buying a BA XR6T motor and box
or
3, Fitting a supercharger kit of some sort to the AU motor
Any thoughts or experinces would be good
Ps have thought about buying a BA turb, but like some features of the AU over the BA. Plus like things a lil different
Craig.
ISQUIK Fordmods Stock as a Rock
Posts: 195 Joined: 24 Nov 2006 Location: Funky Town VIC, Australia
Posted: Mon May 05, 2008 8:15 pm Post subject: |
go the turbo on the au motor.
get an acl oringed gasket, cam, and high volume oil pump.
get a turbo kit costs vary depending on overall power you want.
3" exhaust, front mount cooler, big fuel pump, injectors and reg. Maybe go computer as well depending on how much power you want.
alot of variables just think about wat you want for the end result and do it.
Posted: Mon May 05, 2008 8:31 pm Post subject: |
Yer prob should of said what im lookin for to.
Looking to get 200 - 250 rwkw (maybe more later on ) and still be able to use it as a daliy driver...
Also being a ute, what do people run (usable) power wise in there utes.
Craig.
Posted: Mon May 05, 2008 8:34 pm Post subject: |
Thanks sexyr6.
That answers my question i sent them on there ebay store.
I think the stage 1 will be perfect for now
Posted: Mon May 05, 2008 9:30 pm Post subject: |
You can EASY get 280 rwkw with std compression with good tune [good ecu], springs, mild cam...
Leave the rotating assembly and save your money... IMO run about 240 rwkw and all will be fine. With auto and trans cooler.. Over that everything needs major attention...
You'll have over 800 FtLb torque with good throttle responce. Very little lag with 9.6 compression...
Age:19 Posts: 1320 Joined: 30 Oct 2006 Location: Grafton NSW, Australia
Posted: Mon May 05, 2008 9:31 pm Post subject: |
Whats your budget?
ba motor and box would blow everything else out of the water, especially if you got a nizpro upgrade kit or similar, but it'll also blow the fck out of your wallet.
Posted: Mon May 05, 2008 10:01 pm Post subject: |
yer dont quite have a open wallet HAHA, seen BA turbs for about 5k mark, was just a idea??? But if the AU motor will handle some mild boost ok ill stick with a bolt on kit.
EBXR8380, what would have to be done to get that without the turb????
Craig.
Posted: Mon May 05, 2008 10:27 pm Post subject: |
| MRFYI78 wrote: | yer dont quite have a open wallet HAHA, seen BA turbs for about 5k mark, was just a idea??? But if the AU motor will handle some mild boost ok ill stick with a bolt on kit.
Craig. |
lol you definitely need a turbo to get that power. he was just stating how stock you could keep your motor even with the boost.
a higher compression ratio means you cant run as much boost safely, BUT, it cuts out lag before the boost kicks in.
I dont think you could get that power safely and reliably, especially for a daily. a computer to run something with that much power is over the 1k mark already. I think aiming for 200rwkws would be a much more achievable target, especially on a budget. Its still pretty powerful, much more than stock, and will be much more reliable.
the stage 2 snort kit with cooler is what i'd buy, especially with a budget in mind.
More Grunt Fordmods - Getting Side Ways
Age:26 Posts: 712 Joined: 10 Jul 2007 Location: Bacchus Marsh VIC, Australia
Posted: Mon May 05, 2008 11:24 pm Post subject: |
| EBXR8380 wrote: | You can EASY get 280 rwkw with std compression with good tune [good ecu], springs, mild cam...
You'll have over 800 FtLb torque with good throttle responce. Very little lag with 9.6 compression... |
800 ftlbs? no way, you would need to be putting out more than 240 rwkw...
thats 1083 nm. you would need a better than budget setup to get that much.
sly Fordmods - Smokin em up
Age:45 Posts: 258 Joined: 09 Feb 2006 Location: Newcastle NSW, Australia
Posted: Tue May 06, 2008 8:59 am Post subject: |
| Limit the boost to 10psi or less and you won't need to open the motor. That'll be good for 200 - 250 rwkw depending on intercooling, exhaust etc. Stock injectors are good for 160-170 rwkw so the fuel system will need upgrading. There's a SC build going on ATM aiming for 200rwkw from an AU with 36lb injectors and stock pump and reg. IIRC the stock fuel pump pegs out at about 220-240 rwkw. Getting power isn't hard, but reliability depends on the tune. A well setup 250rwkw car is still a very nice daily driver.
Posted: Tue May 06, 2008 8:42 pm Post subject: |
Cheers for the help an comments guys. Im takin it all in. So what i recon ill do is....
Buy the stage 2 kit, larger injectors, larger fuel pump and a good tune.
And hopefully all should be set.
Craig.
Posted: Tue May 06, 2008 10:13 pm Post subject: |
First you need to do this...Or similar..
A T connector before that oil pressure sender..
Not yet fitted .. This is to feed oil to turbo.. A -3 braded hose will do, even brake line...
Fit up turbo / manifold. In this case its a T04Z .84 A.R.. Tial wastegate.. If using GT3540 it can come with internal wastegate..
Fitted with aie cleaner, latter to be boxed ..
In our case we fabricated a plenum with front throttle body..
All done..
It runs EMS 8860 with 42 LB injectors, Walbro 255 intank pump..
The engine is TOTALLY std..It now runs a prepped c4 that is bilt to handle 700 h.p....
Fairmont ED / AU turbo...
Posted: Tue May 06, 2008 10:24 pm Post subject: |
| More Grunt wrote: | | EBXR8380 wrote: | You can EASY get 280 rwkw with std compression with good tune [good ecu], springs, mild cam...
thats 1083 nm. you would need a better than budget setup to get that much. |
Torque is hard to get in this application as it has loose converter 3000 rpm..As soon as it hit the boost was so quick it spun straight up to rpm limit.. Compression and near 4" stroke means engines make heaps of it...
Why there MPH is low but ET is good compared to other cars....
Posted: Wed May 07, 2008 10:10 pm Post subject: |
cheers for the pics man, set up and car look sweet, nice lil sleeper
Looks like i have a lil more work ahead of me than i thought ????
Has anyone thought of supercharging?? Pros and cons ??? i still havent yet decided on which way to go .........
Craig.
Posted: Thu May 08, 2008 12:39 am Post subject: |
| The market's a bit light on for supercharger kits for AU's ATM. CAPA have dropped the ball, the only real option for a complete "bolt on and flash" setup is Raptor. Their kit is almost ready to go, have a look in their forum under Site Sponsors. If you wanted a positive displacement blower rather than centrifugal, you'd be looking at custom fabrication. Someone like KPM should be able to set up & tune an Eaton or Whipple blower on an AU.
justa6 Fordmods Oompa Loompa
Posts: 38 Joined: 03 Mar 2007 Location: lismore NSW, Australia
Posted: Thu May 08, 2008 9:44 pm Post subject: |
| turbo's the go, i know it's alot of work, but if your handy with the tools it's very rewarding.
Posted: Thu May 08, 2008 9:53 pm Post subject: |
| yer lookin into the raptor kits atm, turbos are rather common an dwould like something a lil different so maybe a supercharger will go before a turb umm
Posted: Thu May 08, 2008 10:43 pm Post subject: |
| turbo's are only common for one reason. you just have to know what you want
horses4courses Fordmods Newbie
Age:20 Posts: 7 Joined: 21 Mar 2008 Location: Charters Towers QLD, Australia
Posted: Sun Jun 08, 2008 3:03 am Post subject: |
turbo mate is the way to go I am currently setting one up on a AUIIIXR6 5speed. I bought the kit from Geoff at snortperformance, I went with the stage 4 kit.
Custom stainless 3" cooler piping,4"inch intake to turbo, 3" mild steel exhaust with redback turbo muffler, 42lb injectors and a haltech E6X computer set up. No power figures yet but will send pm when finished.
Here R some picks....
| Description: |
| Filesize: |
71.52 KB |
| Viewed: |
11 Time(s) |
| Description: |
| Filesize: |
77.25 KB |
| Viewed: |
10 Time(s) |
| Description: |
| Filesize: |
181.56 KB |
| Viewed: |
5 Time(s) |
[49 queries :: 0.07308 seconds ]
