smally351 Fordmods Stock as a Rock
Posts: 165 Joined: 05 Jan 2006 Location: Berri SA, Australia
Posted: Wed Jun 04, 2008 7:24 pm Post subject: AU2 BEM replacement problem |
Hi guys,
got an AU2 ute at work at the moment and have to replace the BEM due to a problem with the instrument cluster.
Got the replacement BEM thru Injectronics and went to fit it today. Thats where the fun began. The instructions were telling me that I have to go to a Ford dealer to have the keys programmed to it and that I need 2 keys to do this. The owner only has one key. I went to a dealership and they couldnt make it work either, and they seemed a little confused about it all.
What do I need to do to make this replacement BEM work??  |
Disco Frank Fordmods Junkie
Age:29 Posts: 13277 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Wed Jun 04, 2008 9:19 pm Post subject: |
cant see why u would need 2 keys...
thats a new one to me |
Age:23 Posts: 2339 Joined: 07 Nov 2004 Location: Perth WA, Australia
Posted: Wed Jun 04, 2008 10:25 pm Post subject: |
the keys are electronically trained to the bem, and as a security feature you cannot code 1 key, thus the requirement for 2 keys.
Also, what instrument cluster issue on an AU would require a new bem? |
Posted: Wed Jun 04, 2008 11:04 pm Post subject: |
Intermittantly all the gauges drop out, speedo, tach, fuel and temp gauges.
If there's only one key, can the replacement BEM be made to work at all? |
Posts: 2047 Joined: 06 Nov 2004 Location: Canberra - The Nations Capital ACT, Australia
Posted: Thu Jun 05, 2008 6:53 am Post subject: |
| smally351 wrote: | Intermittantly all the gauges drop out, speedo, tach, fuel and temp gauges.
If there's only one key, can the replacement BEM be made to work at all? | You could buy another blank and just program the fob in. |
Posted: Thu Jun 05, 2008 8:30 am Post subject: |
| Yeah, but to do that I need 2 keys that work in the system already!!!! |
Posted: Thu Jun 05, 2008 9:01 am Post subject: |
| smally351 wrote: | | Yeah, but to do that I need 2 keys that work in the system already!!!! | Good point I am assuming that it meant you need two keys to complete the retrain not two originals. Otherwise are you protecting the car or the BEM from theft? |
Posted: Thu Jun 05, 2008 11:25 pm Post subject: |
Rang around a couple of contacts from my days at Ford and got some more info.
Yes, we need 2 keys, but they only have to be cut to suit the lock barrel.
OK, got a new key and got it cut to suit.
Fitted the new BEM and tried again (at the dealership).
Cleared the PCM parameters so it could recognise the new BEM, all good.
Tried to relearn the keys to the BEM, no go!
The Ford IDS tool will not communicate with the BEM, I reckon we got a bodgy one!!
Rang the supplier and have organised a replacement BEM. Will try again when that shows up.
Getting sick of this BS!!! |
[35 queries :: 0.19436 seconds ]
