richie Fordmods Stock as a Rock
Age:55 Posts: 171 Joined: 09 Nov 2004 Location: perth WA, Australia
Posted: Thu Apr 24, 2008 3:33 pm Post subject: AUIII on Gas |
My daughter just bought AUIII I6 03/2002 on factory gas. I am about to do service - however there is I believe, a filter at the convertor. What is involved in changing this or is it a no go item?
Is it worth changing leads & coil - done 200,000k?
What's the story with the Ford Motor oil for gas - should I use it?
Change HEGO? I am told the OEM one is around $300.
Apart from above & oil filter, air cleaner, spark plugs, coolant flush, thermostst change, brake fluid flush, auto trans service, -anything else?
Richie. |
AU2SR Technical Contributor
Age:39 Posts: 170 Joined: 05 Nov 2004 Location: MELBOURNE VIC, Australia
Posted: Thu Apr 24, 2008 4:17 pm Post subject: Re: AUIII on Gas |
| richie wrote: | My daughter just bought AUIII I6 03/2002 on factory gas. I am about to do service - however there is I believe, a filter at the convertor. What is involved in changing this or is it a no go item?
Richie. |
i run magnatec by castrol do the leads and plugs there is a filter on the converter but get a gas guy to do it if it is getting bad econ change the thermostat and coolant with just inhibitor and disconnect the battery for 60 mins . hope this helps cheers |
Posted: Fri Apr 25, 2008 11:53 am Post subject: Re: AUIII on Gas |
Richie. |
Any idea about this circular wire guaze size of 50 cents filter?
Richie |
Posted: Mon Apr 28, 2008 1:25 pm Post subject: |
Is there a manual (apart from Ford worshop) that covers AUIII factory dedicated Gas?
Richie. |
Age:31 Posts: 1973 Joined: 08 Mar 2005 Location: East Kurrajong NSW, Australia
Posted: Wed Jun 18, 2008 12:15 am Post subject: |
I was unaware of a filter on the converter for the factory VIialle converters ... I just replaced the converter on AUII EGAS ute ... and I didn't see one at all.
I used Shell 15W40 LPG oil ... it does the job ... I replace it every 5,000km though as I do a lot of city metro driving ... and oil is cheap insurance. For EGAS models I am pretty sure it mentions 15W40 anyway (not the 10W40 or 30 for the petrol models)
I purchased a new Ford HEGO sensor on eBay for $55 ... works a charm and very easy to unbolt out of the exhaust and replace.
If the vehicle is new to you ... replace the spark plugs at least.
Also a clean out of the throttle body might be a good idea too ... every little bit helps.
If you have a decent LPG mechanic nearby ... get them to remove and clean the idle jet ... and clean the gunk out of the solenoid plungers as well. |
[32 queries :: 0.07883 seconds ]
