SQUEAK Fordmods Tyre Shredder
Age:24 Posts: 375 Joined: 05 Nov 2004 Location: SYDNEY NSW, Australia
Posted: Wed Jan 12, 2005 3:53 pm Post subject: Auto gearbox with aftermarket ECU |
Just wanted to know can you use an auto gearbox if I was to replace my ecu with am ems 8860?
The reason I ask is because every one on here who has an aftermarket ecu has a manual.
Ive been told by a few people that its a pain in the a*** and its better to go manual. |
Dellboy999 Fordmods - Getting Side Ways
Age:37 Posts: 1031 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Wed Jan 12, 2005 4:27 pm Post subject: |
| You can get a sepertate trans ECU, I have one, it uses a few wires from the gearbox, and the TPS basically, i have a wiring map if you PM your email address will send the excel spreadsheet I have. |
Disco Frank Fordmods Junkie
Age:29 Posts: 13060 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Wed Jan 12, 2005 8:39 pm Post subject: |
thats fine but i am sure your could get the ems to work withthe facotry ecu
i know that SVO xr6 has the factory ecu controling the thermo fans so i cant see whay u cant get the factory ecu to change the box and allow the ems to handle trhe engine... |
tjb45 Fordmods - Getting Side Ways
Age:28 Posts: 549 Joined: 05 Nov 2004 Location: Wodonga VIC, Australia
Posted: Thu Jan 13, 2005 2:17 pm Post subject: |
| Disco Franks right, I run a Wolf 3d in my EF in conjunction with the standard ECU. The wolf controls the engine timing and ignition and the standard ECU runs the auto, thermos, dash and so on. |
View User Gallery (17)
Posted: Thu Jan 13, 2005 3:21 pm Post subject: |
| The real questoin is do you NEED a aftermarket ECU as have you actually done any big mods that your standard ecu cant handle? they learn pretty damn well.. |
Posted: Thu Jan 13, 2005 5:27 pm Post subject: |
well......If you remember a while ago I was speeking to 6boost and well that engine is still getting put together.
So basicly just wanted to know what I was up for in the electrical department. |
Posted: Fri Jan 14, 2005 1:21 am Post subject: |
| fuzion wrote: | | The real questoin is do you NEED a aftermarket ECU as have you actually done any big mods that your standard ecu cant handle? they learn pretty damn well.. | yes they may learn but hey after a zorts and intake and a mild cam you might as well go for a aftermarket ecu as then u can do anythign u want ie MASSIVE cam or headwork
from what i hear it is the head work that causes the ecus to have dramas |
