Auto to Manual Conversion Guide
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
DJ_Brown
PostPosted: Sat Aug 16, 2008 7:50 pm    Post subject: Reply with quote
Firstly well done Voxace on the fantastic doco.. Everytime i undertake a modification, i cant be bothered stopping and taking photos of anything. Well done!
Secondly, i cant seem to find the same coloured wires in my plug??
My car is a 1996 EF Fairmont, and i can find the solid purple, the solid yellow, and the lightbrown-red wire, but i cant locate a purple-green trace.. i found a green wire-purple trace, and a pink-green trace, but cant find the purple-green trace wire the doco says.. The two wires that terminate off into their own plug are the pink-green trace, and solid purple in my loom. are these the ones i want???
Can anyone help me out??
David
Gaz
PostPosted: Sun Aug 17, 2008 11:16 pm    Post subject: Reply with quote
I remember the wires on mine were the same colour as stated but I was confused as the colour of the wire was a bit crappy and faded. If you have a a workshop manual its helpful as you can eliminate the others, I just looked at the colours that were they and took the odd one out.
lowghia
PostPosted: Sat Aug 30, 2008 6:58 pm    Post subject: Reply with quote
MAJOR HELP NEEDED
please has anyone done the conversion to their 98 EL hybrid?
The loom is completely different, so have no idea where to use resistors or even to start. we tried plugging the auto's inhibitor switch back in to crank over but had no luck there.
lol pulled apart the freakn auto box aswell to get the round plug out and connecting that and still nothing!
HELP!
Froudey
PostPosted: Sat Aug 30, 2008 7:12 pm    Post subject: Reply with quote
lowghia wrote:
MAJOR HELP NEEDED
HELP!
the car should start as the auto to man resistor trick is only to stop the fans being on all the time.... (as so have read from many of the topics/threds) i couldn't start my old EB cause i forgot a loom so check all ya wiring and alike and see, check fuses and alike if not iam sure some one will help... or also go to search and type in car won't start.. there are plenty on here about that
RAPTOR_XR8
PostPosted: Mon Sep 01, 2008 8:46 am    Post subject: Reply with quote
Hi all,
we are doing this conversion in an ED Falcon using a T5 from an EA, I have a questions if someone can help or point me to a thread that may cover this topic.
firstly the ED auto loom does not have the same coloured wires mentioned in the doco,
light brown with red stripe
solid yellow
solid violet
purple withe green stripe.
would appreciate if someone can tell me which coloured wires should be used.
thanks in advance.
Brad.
lowghia
PostPosted: Mon Sep 01, 2008 9:20 am    Post subject: Reply with quote
Froudey wrote:
lowghia wrote:
MAJOR HELP NEEDED
HELP!
Thanks for that we got it running icon_smile.gif And yes the thermos run all the time now, does anyone know where to put the resistor?
jet_pilot
PostPosted: Mon Sep 08, 2008 9:20 pm    Post subject: Reply with quote
im halfway through putting an 1990 ea s pack t5 into my ebII gli
my questions are will the ea ecu plug straight in?
and what what loom needs to be carried over from the ea?
the electrical is the only problem im having ive traced the 2 wires from the clutch pedal back to the firewall but cant find them on the other side.
any help will be appreciated
frankieh
View User Gallery (29)
PostPosted: Mon Sep 08, 2008 11:53 pm    Post subject: Reply with quote
Why would you want to swap the ECU's?
Just put the resistors in to convince the eb ECU that its in neutral and your good to go.
I'm running an auto EL ECU (that thinks it's in neutral) in my ea and it's great.
The EB likely has revised fuel tables etc.. so better off keeping the newer ECU if you can.
jet_pilot
PostPosted: Thu Sep 11, 2008 12:00 pm    Post subject: Reply with quote
ve got both looms (manaul and auto) can i just use the manual loom with the manual ecu and not have to cut wires and what not?
also what is the plug on the clutch pedal and where does it go too?
jet_pilot
PostPosted: Fri Sep 12, 2008 9:44 am    Post subject: Reply with quote
anyone? this is the last thing needed to be done before i dump the clutch for the first time lol
frankieh
PostPosted: Fri Sep 12, 2008 12:17 pm    Post subject: Reply with quote
If you have manual loom and manual ECU, what would there be to cut and join?
jet_pilot
PostPosted: Fri Sep 12, 2008 12:32 pm    Post subject: Reply with quote
so its just plug and playh then?
thanks heaps mate
boom1
PostPosted: Tue Sep 23, 2008 4:36 pm    Post subject: resistor "trick" work for EL ecu's Reply with quote
voxace wrote:
atomicmushroom00 wrote:
just a quicky, but does that resistor "trick" work for EL ecu's??? i heard its only for EF's anyone confirm please?
Should be the same. Wire colours could possibly be different.
where can i get the instuctions on how to trick the ecu
jet_pilot
PostPosted: Wed Oct 22, 2008 12:48 pm    Post subject: Reply with quote
hmm having trouble with the clutch fork and throwut beariong not sitting in place it keeps falling out a mechanic said that there should be a spring but this guide doesnt mention that and the guy i spoke to is a holden nut that hasnt worked on a t5
TROYMAN
View User Gallery (20)
PostPosted: Wed Oct 22, 2008 1:45 pm    Post subject: Reply with quote
there should be a small allen key bolt in the bellhousing that holds the clutch fork in position and the tension on the clutch cable holds it against the pressure plate..it shouldnt come out unless the fork is damaged or it wasnt bolted on properly before it was fitted..
im actually doing a 5 speed conversion on my ed today and the clutch fork doesnt come out unless i undo that allen key bolt..
xcbest
PostPosted: Thu Oct 23, 2008 1:07 am    Post subject: Reply with quote
good thread fellas--question--my young fella has a sierys 1 EB s-pack 10/91 3-9 multipoint=5speed complete as doner car===wants to put 5 speed into 94-EF-fairmont==can he use the eb pedal box or any other parts off of it ,or just the box/bellhousing/clutch cable/& modify the shifter to suit the EF==== will he have to get ef/manuel ECU or just use auto ECU with resistor setup==thanks icon_confused.gif icon_rolleyes.gif icon_eek.gif icon_question.gif
jet_pilot
PostPosted: Thu Oct 23, 2008 12:57 pm    Post subject: Reply with quote
cheer's troyman the allen key bolt is there might have to play a bit
fiend
PostPosted: Fri Oct 24, 2008 5:29 pm    Post subject: Reply with quote
MY GAWD... Boy oh boy - I was told this guy had a T5 that would be a straight bolt on to my EF. I bought it knowing full well that the bellhousing was different, but that was okay as I got the correct bellhousing.
Now my problem is simply that the box has 8 (EIGHT!) holes to connect it to the bellhousing and the housing itself only has four. The box looks to be taller and thiner at the front end, and none of the holes line up in order to get bolts through.
The bellhousing that came with the box uses the same fork and release bearing - it is definately a Ford part from an XF or maybe even earlier... Guess the five speed box must be ancient!
It has a cast steel or iron body where as I was expecting alloy the whole way around. MOST of it is alloy - just the main body where the gears reside within is steel...
Bad luck for me... Mind you, I should be able to make it fit to the bellhousing...
Can anyone shed any light on what the hell is going on here?!
Sheeez - If I had any money I would have just bought a complete ED manual already and be done with all this confusion!
ToranaGuy
PostPosted: Fri Oct 24, 2008 8:24 pm    Post subject: Reply with quote
thanks heaps mate
If your EB has smartlock, no.
You will need a EB2 or ED manual ECU to be plug n play. EA ecu may or may not work, due to smartlock on EB 2 onwards falcon's.
That's why i bought a ED GLI 5spd from the auctions, you get all the gear, including the electrical side of things. I just plugged in the manual gearbox loom to the main loom, and plugged in the ED manual ECU. Kicked it in the guts & all is good. It's just hard to find a complete parts donor!
ToranaGuy
TROYMAN
PostPosted: Fri Oct 24, 2008 10:52 pm    Post subject: Reply with quote
holly s**t..
can you post a pic of the box?
im thinking steel case gearbox? maybe its a celica 5 speed?
Page 7 of 9
[47 queries :: 0.09933 seconds ]
