au2man Fordmods Stock as a Rock
Age:34 Posts: 104 Joined: 01 Sep 2007 Location: Adelaide SA, Australia
Posted: Tue Jul 08, 2008 8:40 am Post subject: BA Falcon front inner control arm bushes lower |
| Has anyone got any tips about replacing the inner bushes on the front lower control arms on a ba? Apparently the originals are fluid filled and mine are rooted so i was wondering whats involved as they look like a**hole to replace. Also wondering wether to go nolathane or use standard? |
punktured Fordmods - Getting Side Ways
Age:23 Posts: 1108 Joined: 04 Apr 2006 Location: Melbourne VIC, Australia
Posted: Tue Jul 08, 2008 8:21 pm Post subject: |
Do yourself a favour and get someone to do it If it's the same one's i'm thinking of it's a prick of a job. I paid around $600-650 to get mine done with nolathane and it's well worth it |
dc357 Fordmods Stock as a Rock
Posts: 178 Joined: 10 Feb 2008 Location: Gunnedah NSW, Australia
Posted: Thu Jul 10, 2008 12:09 am Post subject: Re: BA Falcon front inner control arm bushes lower |
| au2man wrote: | | Has anyone got any tips about replacing the inner bushes on the front lower control arms on a ba? Apparently the originals are fluid filled and mine are rooted so i was wondering whats involved as they look like a**hole to replace. Also wondering wether to go nolathane or use standard? |
hey au2man,
Your right they are not all that easy to do!
For what its worth -I would pay to have them replaced with nolathane as they will last longer if you plan to keep car for 5yrs or more,However the standard bush will give a softer feel with less road noise picked up.
I had a EL & had upper & lower all done in nolathane & it felt harder up front & there seemed more road noise but it handled better.
Chances are your top bush's aren't far behind either! may as well do them all & chuck in a camber kit as well.
How many clicks you got on the BA now?  |
Posted: Thu Jul 10, 2008 7:29 am Post subject: Re: BA Falcon front inner control arm bushes lower |
| dc357 wrote: | | au2man wrote: | | Has anyone got any tips about replacing the inner bushes on the front lower control arms on a ba? Apparently the originals are fluid filled and mine are rooted so i was wondering whats involved as they look like a**hole to replace. Also wondering wether to go nolathane or use standard? |
hey au2man,
59000kms. Looks like some dumbass didnt fit one of the bushes correctly from the factory,its not seated all the way in. |
arm79 Cruise Moderator
Age:29 Posts: 3559 Joined: 05 Nov 2004 Location: Westside VIC, Australia
Posted: Thu Jul 10, 2008 11:00 am Post subject: Re: BA Falcon front inner control arm bushes lower |
| au2man wrote: | | dc357 wrote: | | au2man wrote: | | Has anyone got any tips about replacing the inner bushes on the front lower control arms on a ba? Apparently the originals are fluid filled and mine are rooted so i was wondering whats involved as they look like a**hole to replace. Also wondering wether to go nolathane or use standard? |
hey au2man,
If your interested, I'm running a group buy for Nolathane bush kits that ends next Friday when I will be placing the order. All the details are in a sticky thread at the top of the For Sale section.
A full front end B-Series kit is $360, so you could replace every bush at the same time.
I'm sure if you did most of the work yourself and got someone like Pedders to remove the bushes for you, it would be a fairly inexpensive job. |
roobin Fordmods Parts Gopher
Age:55 Posts: 74 Joined: 16 Jan 2007 Location: Adelaide SA, Australia
Posted: Thu Jul 10, 2008 8:58 pm Post subject: Re: BA Falcon front inner control arm bushes lower |
Take it to a good mechanic.
Life must be cheap these days. |
Posted: Sat Jul 12, 2008 11:40 am Post subject: |
| I might be going for super pro bushes as word around the traps is its hardness is somewhere between standard and nolathane. Most people are saying putting nolathane in the front of a BA will increase its harshness quite significantly. |
Posted: Sat Jul 12, 2008 8:30 pm Post subject: |
| Upto you, but I'd be checking the details on that. |
Posted: Sun Jul 13, 2008 10:28 am Post subject: |
| I didn't find it more harsh putting nolathane in the front, the main thing i noticed was a better feeling in braking, no more sponginess |
Age:33 Posts: 643 Joined: 14 Dec 2007 Location: delegate NSW, Australia
Posted: Mon Jul 14, 2008 12:02 pm Post subject: |
| punktured wrote: | | I didn't find it more harsh putting nolathane in the front, the main thing i noticed was a better feeling in braking, no more sponginess |
That's interesting, the radius rod and its front bush does take most of the load when braking, and if it's soft, there will be a slight delay effect as the bush squashes. Upgraded braking with heavy application would exascerbate this effect.
But when a sharp bump is hit it also creates a similar type of load.
And when braking over sharp bump(s), the two loads add together. |
[38 queries :: 0.06025 seconds ]
