fourl6 slow but steady BA Interior Conversion
ttickfordbetty
PostPosted: Mon Jul 21, 2008 5:57 pm    Post subject: Reply with quote
fourL6 wrote:
02tonna wrote:
hows it comin along this weekend. get the dash in yet... im really interested to see how this conversion goes. icon_biggrin.gif
the cars at the panel beaters getting the body kit painted so nothing this w/end... im on the lookout for a BA wrecking as i will need a fair few little bits... so all i have atm is some door trims and scuff plates icon_sad.gif is still all go though...
hey lukeyson for now im just going to mount a AU cluster in the BA dash (should be easy i think) then look into the BA cluster... i just need a hand with the passenger airbag... all i know is that i want it to work and the AU is a single stage and BA is Dual stage activation so will be fairly tricky... any help appreciated (the passenger airbags $150... so dont fell like testing them lol..)
How would you go disabling it ? Pull the bag off and dont connect the wire.
You will get air bag issuie light on dash thats all.
But depends what BEM you use AU or BA.
I would think if you disable it,just take it to ford tell them what youve done and they should be able 2 clear airbag warning light on dash.
Sounds like your AU came with one air bag ? You should get away with it.
Cant wait and see how it all goes,big job alot a fun and sore head i bet ? lol
02tonna
PostPosted: Mon Jul 21, 2008 8:07 pm    Post subject: Reply with quote
yeah ford should clear the air bag light for you. and if there in a good mood it wont cost ya. they let me off when i brought my VT in to holden icon_redface.gif . as it is only a 5 min job...
Froudey
PostPosted: Thu Jul 24, 2008 8:51 pm    Post subject: Reply with quote
any progress on this?
02tonna
PostPosted: Fri Jul 25, 2008 12:23 am    Post subject: Reply with quote
frankieh
View User Gallery (29)
PostPosted: Fri Jul 25, 2008 12:40 am    Post subject: Reply with quote
I was toying with doing this with an XC panel van I have.. cept I was goign to go a step futher and the entire BA in the thing.. engine, dash, all wiring etc etc... but thats for another day. I have too many projects on the fly already.
fourL6
PostPosted: Mon Jul 28, 2008 11:42 pm    Post subject: Reply with quote
02tonna wrote:
haven't given up lol... painting the kit cost alot more than expected and now doing up a eb2 for a mate... full ef engine and interior conversion for it so it'll be pretty good practice for this icon_biggrin.gif... so yes this has been put on hold for now apart from fitting the rear doors, rear power windows and im on the lookout for some red/black ba xr seats...
Lukeyson
PostPosted: Thu Jul 31, 2008 6:28 pm    Post subject: Reply with quote
02tonna wrote:
yeah ford should clear the air bag light for you. and if there in a good mood it wont cost ya. they let me off when i brought my VT in to holden icon_redface.gif . as it is only a 5 min job...[/quote]
Well, to disable the airbag, you won't want to leave it disconnected. You will want to put a bridging resistor of about 2.2 to 2.9 Ohm across both of the airbag feeds so that the airbag module knows that there's something connected.
If you want to clear any airbag errors, buy yourself a clone ELM327 scantool from eBay and I can talk you through clearing the errors. Well, at least I know how to do this on BA airbag modules anyway, an AU module is still an unknown for me.
Lukeyson
fourL6
PostPosted: Tue Aug 05, 2008 11:39 pm    Post subject: Reply with quote
bit of an update...
so iv slowed the full conversion down.. also decided i wanted the Red XR interior (seats and door trims) and have realized most sellers sell seats and trims as a pack...
so for now iv started to mod my black xr door trims to fit the AU dash... hear is some progress...
this show the part iv had to cut out to allow the doors to close... also have removed the speaker grill
you can see in the center (and just to the right) of this image that there is two holes... one with a white plastic thread in it and the other with paint scraped of around it(from me trying to remove the white thread bit)
The white plastic bit had to be moved for the door handle to screw into...(from top to bottom) so im wondering if the AU3 doors have wholes to fit BA trims? as there are a few others i will have to move like the two at the bottom of the door trim... also wonder if S1 and S2 doors have the whole to move the plastic thread bits too?(hope that makes sense)
and theres two of the door closed...
Cheers Cam
02tonna
PostPosted: Thu Aug 07, 2008 8:41 pm    Post subject: Reply with quote
all coming along now...... keep u the good work
Lumpy_Camo
PostPosted: Sun Aug 10, 2008 4:59 pm    Post subject: Reply with quote
well your certainly getting there. what are you going to cover the dirty big gaping holes with?
fourL6
PostPosted: Sun Aug 10, 2008 5:39 pm    Post subject: Reply with quote
a mate has recommended just using expandable foam stuff and taping of the front then sand it back and ill see how spraying it looks... i can cut the plastic away from behind the material and fold the material over the plastic to get a nice edge...
fourL6
PostPosted: Mon Aug 25, 2008 10:06 pm    Post subject: Reply with quote
now the iv pretty much got the doors sorted out im going to see if i can fit the BA center console and maybe even the icc (not functional) into the AU dash...
wont be able to use hacksaw as ill just be "borrowing" the parts from the misses BA mont...
Cheers Cam...
02tonna
PostPosted: Tue Aug 26, 2008 12:30 am    Post subject: Reply with quote
not the BA mont!!!!!! haha nice man.. love free parts
fourL6
PostPosted: Sun Oct 05, 2008 9:17 pm    Post subject: Reply with quote
never got around to playing with the center console but here is some progress...
made some speaker surrounds today... so this is pretty much one finished door trim (minus the extra power window switch...)
badam
PostPosted: Mon Oct 06, 2008 12:32 am    Post subject: Reply with quote
I commend your efforts fourL6, that was quite a task you set yourself! What happened to the top half of the door near the a-pillar though? In previous pictures it wasn't cut off? Would have looked more flush but nevertheless still a top effort mate! Will be interested to see how the BA centre console fits if you go ahead.
fourL6
PostPosted: Sun Oct 19, 2008 5:20 pm    Post subject: Reply with quote
that part stuck out that far it just about covered the air vents so i cut it off icon_smile.gif...
have now done both front doors...
Any idea how different the mounting points etc. are for the BA handbrake?
MaTTeB
PostPosted: Mon Oct 20, 2008 4:55 pm    Post subject: Reply with quote
Hey mate, sounds like afun project.
The handbrake has 3 bolts running horizontally through the bracket. It looks like the bracket on yours has the bolts going vertically down through it.
You may be able to put an AU airbag into the position the BA airbag sits in.. I haven't seen an AU one to know..
In terms of everything else.. provided the wiring remains all AU, then you shouldn't have a problem, do away with all the BA electrics and it should be a reasonably direct swap. As you've said retain the AU cluster (you can probably change the fascia but keep the mechanical side) Keep your heater etc..
To make the car 4 door power windows, you'll need to get the interior wiring looms out of a car that had this feature..
I hope this helps
MaTTe
fourL6
PostPosted: Sat Nov 01, 2008 8:51 pm    Post subject: Reply with quote
iv got the ba power window switches working today and put a few extra mounting parts for the door in now... the passenger window was pretty easy i just used a multi meter to figure out what pin was open/closed when the switch was up/down or out... and then used a crimping kit to adapt the looms... the drivers 4 switch one wasnt that easy... id say because of the auto down feature... so iv just got the drivers window working of the rear right switch... iv also got the the rear window lock/unlock thing working (supply's 12 when of and 0 when on) so that will be used to power the rears (when i get around to purchasing the regs)
Cheers Cam
fourL6
PostPosted: Sun Nov 02, 2008 10:03 am    Post subject: Reply with quote
this is what i have figured out so far...
if anyone has any more info it would be greatly appreciated...
and this is how i have connected the passenger switch
fourL6
PostPosted: Sun Nov 02, 2008 2:58 pm    Post subject: Reply with quote
so today i pulled the misses BA fairmont apart and dummy fitted the center console... photos dont do it justice but you get the idea...
in the photos the AUs in neutral so you can see the whole center console will need to move towards the dash... will also have to cut back a bit of the white plastic around the gear shift and modify how the air hose parts connect to the dash...
i personally think the AU handbrake will look better and fit better into the center console that the BA...
Page 2 of 3
[47 queries :: 0.08177 seconds ]
