BA - MCC to ACC Conversion
Goto page Previous  1, 2, 3 ... , 10, 11, 12  Next
kjoy064
PostPosted: Sun Mar 30, 2008 1:50 pm    Post subject: Reply with quote
where do you lug the drivers side into if there is already 3 plugs into it?
Lukeyson
PostPosted: Sun Mar 30, 2008 2:21 pm    Post subject: Reply with quote
The drivers actuator plug is a 4th plug. The main 3 are across the bottom, 4th is smack bang in the middle.
Luke
kjoy064
PostPosted: Sun Mar 30, 2008 6:51 pm    Post subject: Reply with quote
Lukeyson. Cheers for that and i'll have another look later. I was having a looksee at the door harness and i know i need a new one but i took a photo of the dash side.
image 1 Red wire plus orange / white stripe no pins on door side of plug
Image 2 Black wire plus green / yellow stripe no pins on door side
could this be for the temp sensor for mirror..
i am just trying to limit the fact of a new dash harness that all and by chance do you know where i could download a wiring schmatic from?
[/img]
 Description:
Image #2
 Filesize:  106.79 KB
 Viewed:  4 Time(s)
 Description:
Image #1
 Filesize:  94.22 KB
 Viewed:  4 Time(s)
Lukeyson
PostPosted: Sun Mar 30, 2008 7:22 pm    Post subject: Reply with quote
Take a look at the actual mirror plug. Normal mirrors have a smaller 3-pin connector, mirrors with temp sensor (std or memory mirros) have a 5-pin connector.
As for the dash, the temp sensor isn't listed as a loom option, so i reckon it's in all dash looms. I don't have proof though.
And as for some schematics - you won't find diagrams that tell you what's in each loom which is a PITA. But I do know where you can find a BA workshop manual at the moment.
http://homepages.chilli.net.au/~ford/index.html
Lukeyson
kjoy064
PostPosted: Sun Mar 30, 2008 10:29 pm    Post subject: Reply with quote
Thanks mate...
Last question for now is, did your 09/03 XR6 with premo sound have the sunload sensor on it? just double checking with one of you previous posts..
thanks again mate
Lukeyson
PostPosted: Mon Mar 31, 2008 6:45 am    Post subject: Reply with quote
It had the connector, but no sensor.
Lukeyson
fnp
PostPosted: Mon Mar 31, 2008 3:01 pm    Post subject: Reply with quote
Well, as of today and thanks to Dave (xpression) for doing by far most of the work my climate control is in.
Despite a few hiccups at first the climate is working 100%. Unfortunately the autolights refuse to work (every other function on the stalk works and the sunload sensor is fine, probably a dodgy multifunction switch) and my ICC appears to have had a bit of abuse icon_sad.gif - the screen has a few scratches which I'm not fussed about, but it refuses to play CD's properly. Yesterday it played a CD fine for eight minutes or so then spat it out.. ever since then I can load a CD but it tries to read it then spits it out after five seconds or so.
Also, the lack of a clock is already irritating me icon_smile.gif I'm considering emailing ASL to see what they can do with the ICC in regards to the CD stacker and perhaps any firmware changes that enable a clock.
fnp
PostPosted: Mon Mar 31, 2008 3:06 pm    Post subject: Reply with quote
Just to throw a bit more information out there:
kjoy064 - I reckon you could get away without auto headlights - mine arn't working but the climate control is fine. Also my original dash loom (from a low series Mark 1 BA) did not have a connector for the sunload sensor.
xpression
PostPosted: Mon Mar 31, 2008 3:54 pm    Post subject: Reply with quote
yeh we need to get the auto lights sussed out. its buggin me hey,
fnp
PostPosted: Mon Mar 31, 2008 4:16 pm    Post subject: Reply with quote
Heres another one too - the mobile phone wiring has no power, either the 12v line or ignition 12v line.
Apart from that, the new ICC looks much better (especially at night), the dual zone is fun toy to play with and even the new indicator stalk is nicer to use icon_smile.gif
Lukeyson
PostPosted: Mon Mar 31, 2008 5:07 pm    Post subject: Reply with quote
OK, so Sunload Connector is in XR-with-Audio-Prep Loom but not in XT Loom. Good to know.
There are separate fuses for those two lines in the Mobile Phone connector. It's not a problem with one of these two fuses is it? Otherwise make sure that all those connectors in the back of the fuse box are pushed in right.
The other point to check is the clockspring. But I'd be checking the pins on the connector under the steering column to make sure that the appropriate pins go 'closed circuit' correctly when auto lights are selected - that way we eliminate the switch. It's sounding like maybe the Dash Loom itself may have some issues if the mobile phone is problematic too.
I was speaking to expression this morning and neither of us can remember if the Auto lights is wires-to-bem-CAN-to-ic or wires-to-ic-CAN-to-bem. The IC seems to have all the testable auto-lights parameters, but you can't test that on a low series cluster. For some reason I thought headlights all wired to the BEM and Indicators wired to the IC.
And thank goodness I didn't get the same issue as you on the drivers side actuator! I did mine before I had full diagnostic access at home and that one would have stuffed me good. But if anyone does theirs and has the same issue, I can tell them what commands to issue using a cheap ELM327 scantool to fix it...! (I've found some for $50 on eBay recently - including shipping!)
I'll help lookup the wiring loom info tonight if I get the chance.
Luke
Lukeyson
PostPosted: Mon Mar 31, 2008 5:30 pm    Post subject: Reply with quote
Someone else has asked this question, and as of about 3 or 4 months ago there wasn't any apparent way of getting an old non-clock DZ ICC to show the clock. But they may have been working on it since then. I'd be interested too.
See, I don't have the dash pods, so I got a dash clock.
If the answer is a persistent no Re: ICC Clock, then you're only other option may be an FPV ceiling mount clock. Not the cheapest plastic taiwanese LCD clocks I've ever seen....and I still can't get used to having the clock on the ceiling in our Tory ghia.
Lukeyson
Lukeyson
xpression
PostPosted: Mon Mar 31, 2008 5:58 pm    Post subject: Reply with quote
no power at the mobile phone plug thats weird. Maybe the loom has some pins in a different spot somewhere?
data_mine
PostPosted: Mon Mar 31, 2008 6:09 pm    Post subject: Reply with quote
I've gotten used to it to the point when I get into the work BF Futura wagon, the left hand goes for a non-existant starter button, and I look up for a clock. I get asked why I always tap the dash before starting the car lol.
As for the windscreen mount clock is the loom for it available in the roof on non FPV/Terry's ?
Lukeyson
PostPosted: Mon Mar 31, 2008 6:29 pm    Post subject: Reply with quote
Nope. Just like the auto-dimming mirror - there's a custom loom for them. But you can take power from the overhead lights.
Lukeyson
Lukeyson
PostPosted: Mon Mar 31, 2008 6:36 pm    Post subject: Reply with quote
I wouldn't think so. Remember, I have a BF Fairlane loom under my dash, and there was no real difference. This loom even had the 'fix' for the low-volume Sat Nav issue - which means there's a mono-preamp stuck to the back of the Fuse Box - and I just hooked up a Bluetooth Kit to my car 2 weeks ago.
Mind you, my reverse camera video converter has been taking power from the Mobile Phone connector Acc line since it was installed a few years ago - and worked just fine on both the BA XR+Audio Prep and BF Fairlane+Audio Prep+SatNav looms.
The Phone-Audio-Input line goes to the ICC. But of the 4-pin power socket, the 2 x Power and 1 x GND lines travel only a short distance to the Fuse Box, and the Mute line goes to the ICC.
Lukeyson
 Description:
Wiring for Phone Connector
 Filesize:  57.86 KB
 Viewed:  7 Time(s)
Lukeyson
PostPosted: Mon Mar 31, 2008 7:02 pm    Post subject: Reply with quote
Autolights.
So what appears to happen is:
(1) Power is supplied from battery
(2) Stalk is at Permanent Low (could be permanent high or flash high. Flash High has it's own earth. Permanent settings depend on rotary dial setting)
(3) Rotary Dial - either earth the light settings for parkers/headlights, or pass headlight earth through to BEM controlled GND
(4) BEM controls the Earth by using the auto on/off settings.
This is all the low-power side of the low/high headlight relays and the tail relay.
HOWEVER, there's also a line (1416) that appears to run from the switch to the Cluster - which would most likely be the line that tells the cluster whether auto-lights are on or not - so the IC stops b**ch if the lights are left on when ign is off (which my low cluster does annoyingly.)
So it now appears wired to BOTH the BEM and the IC.
Lukeyson
 Description:
Autolights
 Filesize:  151.72 KB
 Viewed:  6 Time(s)
fnp
PostPosted: Tue Apr 01, 2008 12:37 am    Post subject: Reply with quote
Some good interesting info there lukey. I seem to remember somewhere someone mentioning (vague I know) that the premium XR ICC can indeed display a clock, but its not a WDS option, and only ASL can enable it. I'm not sure what I'll do with my ICC and dodgy CD player yet but if I do end up sorting something out with ASL I'll definately be looking into this option. I don't really want the FPV roof clock as I think it looks like a cheap piece of tat icon_smile.gif
Lukeyson
PostPosted: Tue Apr 01, 2008 6:20 am    Post subject: Reply with quote
Enabling clock and clock overlay (when using Video) are options on the Premium ICC yes. I've come across some bit values via OBD2 that I can turn on and off. I haven't found these values in the IDS though. So this might be what you're talking about.
I've tried setting the same value on a DZ ICC without success though. This is the holy grail at the moment - there was lots of discussion about it on AFF, and there was a picture somwhere. I'll see if i can dig it up.
Lukeyson
Lukeyson
PostPosted: Tue Apr 01, 2008 8:48 am    Post subject: Reply with quote
Found one at last.
From here: http://www.fordforums.com.au/showthread.php?t=11192720
Lukeyson
 Description:
DZ ICC with clock.
 Filesize:  138.63 KB
 Viewed:  7 Time(s)
Page 11 of 12
[49 queries :: 0.08177 seconds ]
