raff-26 Fordmods - Getting Side Ways
Age:27 Posts: 451 Joined: 05 Aug 2007 Location: melbourne VIC, Australia
Posted: Thu Nov 06, 2008 11:08 pm Post subject: BA XR Wheels Onto EF Ghia??? |
G'day, I can pick up a cheap set of BA XR6 17's - off a BA.
I have heard around that you can put them on E Series, however the setup is a little different.
Can anyone shed a little light on the situation?
Thanks  |
green car Fordmods - Getting Side Ways
Age:31 Posts: 567 Joined: 27 Sep 2007 Location: perth WA, Australia
Posted: Thu Nov 06, 2008 11:14 pm Post subject: |
| You need spacers because the mags will sit in too far from the different offset.Been done heaps of times |
Posted: Thu Nov 06, 2008 11:19 pm Post subject: |
| green car wrote: | | You need spacers because the mags will sit in too far from the different offset.Been done heaps of times |
and are there any con's associated with using spacers?? Noise, vibrations, smoothness ??
anyone done it? |
elf100capri Fordmods Stock as a Rock
Age:40 Posts: 169 Joined: 08 Jul 2007 Location: brighton SA, Australia
Posted: Thu Nov 06, 2008 11:24 pm Post subject: |
ive been running mine with 35mm adapters for over a year with not one problem. they are done up using locktite on the threads. the problems i have heard about seem to be from user having incorrect or loose nuts fitted ( using adapters from skylines etc with the wrong thread- 12x 1.5 and somehow the nuts were mixed up ) or having the rim mounting lips removed from them. floating spacers are illegal in sa . i see no difference in using these to having the correct e series offset rim
OZBMX Fordmods - Getting Side Ways
Age:19 Posts: 720 Joined: 31 Dec 2007 Location: Munruben QLD, Australia
Posted: Fri Nov 07, 2008 5:29 am Post subject: |
| raff-26 wrote: | | green car wrote: | | You need spacers because the mags will sit in too far from the different offset.Been done heaps of times |
anyone done it? | legalities, potential safety risk, have a search through the forum its been discussed plenty, and you can get the wheels in the correct offset off ebay, fordforums etc. |
Posted: Fri Nov 07, 2008 5:42 am Post subject: |
| OZBMX wrote: | | raff-26 wrote: | | green car wrote: | | You need spacers because the mags will sit in too far from the different offset.Been done heaps of times |
true, but not 5 of them all with good tyres for $200....
I did do a search and had a mixed bag of opinions....
as long as threads/studs and nuts match, and installed properly...there should be no issues |
Posted: Fri Nov 07, 2008 1:44 pm Post subject: |
I would also check if they are legal in your state, if you have a prang your insurance may not cover you.
$200 is very cheap |
[34 queries :: 0.03867 seconds ]
