ba xr6t dose pipe???
Goto page 1, 2, 3  Next
falcongli6
PostPosted: Tue May 20, 2008 9:43 pm    Post subject: ba xr6t dose pipe??? Reply with quote
g'day..
i was just wondering where do ya get a dose pipe from??
can anyone help. ?
thanks
Tocchi
View User Gallery (18)
PostPosted: Tue May 20, 2008 9:44 pm    Post subject: Reply with quote
1) remove BOV and block up lines.
2) it will have to be custom made. different shapes, lengths, amount of holes, produce different sounds.
needfordspeed
PostPosted: Tue May 20, 2008 9:45 pm    Post subject: Reply with quote
Just go to your local exhaust joint and grab a 2.5-3" straight pipe....that's all they are.
falcongli6
PostPosted: Tue May 20, 2008 9:59 pm    Post subject: Reply with quote
cheers but where's it go? i dont reali know much about them .
el_xr6_luke
PostPosted: Tue May 20, 2008 11:07 pm    Post subject: Reply with quote
goes on front of the turbo, where the air gets sucked in.
get a silicon joiner that will connect the piece of pipe to the turbo.
you wont be able to run a air filter, the filter will muffle the noise but still sound ok.
pipe should be 10cm-15cm, different lengths get different noise.
also try using different types of metal
Mr.Kiss
View User Gallery (21)
PostPosted: Tue May 20, 2008 11:34 pm    Post subject: Reply with quote
I run a dose pipe on my BA. It's tight fit. The inlet to the turbo is 3 inch, you need a tight 90 degree bend. I used 90 deg's from a dounut and about 10cm of straight pipe with a K&N filter on it. Dont worry about the filter muffling it, mine f**k loud!! But then I'm running 15psi.
 Description:
the length of the straight pipe is actually shorter than in the pic
 Filesize:  48.2 KB
 Viewed:  12 Time(s)
 Description:
 Filesize:  64.88 KB
 Viewed:  14 Time(s)
alfy
PostPosted: Tue May 20, 2008 11:46 pm    Post subject: Reply with quote
whats a dose pipe do? does it make the "choof choof" sound when you back off as opposed to the "psccchhhhht" of a normal BOV?
Mr.Kiss
PostPosted: Tue May 20, 2008 11:49 pm    Post subject: Reply with quote
Dose pipe makes a tutututu sound. the BOV is removed from the car..
Link
alfy
PostPosted: Tue May 20, 2008 11:51 pm    Post subject: Reply with quote
yeah thats what i tried to mean haha.
falcongli6
PostPosted: Wed May 21, 2008 12:03 am    Post subject: Reply with quote
thanks mate.. and do i block the blow off valve?
to make it work??
schnoods
PostPosted: Wed May 21, 2008 12:04 am    Post subject: Reply with quote
And thats caused by the throttle closing and the air moving back through to the turbo, trying to spin it the other way???
If I wer to do a modification it would be to wreck tyres, not turbo's. icon_smile.gif
Or id be using one of these with the BOV.
Link
alfy
PostPosted: Wed May 21, 2008 12:05 am    Post subject: Reply with quote
alfy
PostPosted: Wed May 21, 2008 12:10 am    Post subject: Reply with quote
http://youtube.com/watch?v=W_Qul7MiImk&feature=related
Mr.Kiss
PostPosted: Wed May 21, 2008 12:24 am    Post subject: Reply with quote
to make it work??
Yeah you have to block off the BOV otherwise you wont get the desired sound!! I just used 2 rubber chair leg stops, and make sure you use hose clamps, otherwise one of the stop will blow off!!
Tocchi
PostPosted: Wed May 21, 2008 12:52 am    Post subject: Reply with quote
here's it with a filter.
Link
TURBO_GHIA
PostPosted: Wed May 21, 2008 1:24 pm    Post subject: Reply with quote
why bother ,you may as well go buy a VL BRO then you can all be fully sick ulah !!
el_xr6_luke
PostPosted: Wed May 21, 2008 1:45 pm    Post subject: Reply with quote
Link
damn i cant wait to get my car back to do some fluttering, only another 2-3 weeks till the engines done, reckons ill be easy pushing 300rwkw on about 11-12psi
Tocchi
PostPosted: Wed May 21, 2008 1:58 pm    Post subject: Reply with quote
el_xr6_luke wrote:
Link
that was with the small turbo, with the big one, the flutter is so loud and goes hell long. haha
you got auto or manual? might help to strengthen gearbox.
i killed my BTR and it makes f**k power
257rwhp @ 5000rpm
500Nm @ 1450rpm
needfordspeed
PostPosted: Wed May 21, 2008 2:57 pm    Post subject: Reply with quote
A mate of mine had a 17cm straight pipe on his VL, dosed like no other, i've also tried a few combo's on a mates turbo EA, just try a few different setups till you get the best sound, on the EA we found a 90 degree bend worked best.
Steady ED
Fordmods Addict
PostPosted: Wed May 21, 2008 5:02 pm    Post subject: Reply with quote
You can only get a 90deg on a T with stock cooler piping and the battery still there.
I've got a bit of EL intake flexi hose going to a 90deg 3" mandrel bend and a drift mushroom type pod filter on mine.
Would probably be better minus the flex hose, but I can't be fcked chopping the mandrel bend up to get it to fit.
I got no vid with decent sound, but heres a pic of the setup.
With stock cooler and boost it won't be nothing fantastic.
No one with half a brain will mistake it for a VL for instance.
Page 1 of 3
[49 queries :: 0.07493 seconds ]
