BBM install into a EB/ED Anyone got any doco's?
altedxr6
Sponsor + Donator
Sponsor + Donator
PostPosted: Thu Jan 13, 2005 8:08 pm    Post subject: BBM install into a EB/ED Anyone got any doco's? Reply with quote
Okay ... Looking at doing a BBM install on an ED and a EB falcon
What I need to know!
The fuel rail pipes? .. they need to be changed right? ..
And also, you need to run extra wires from the ECU .. if using EEC-4
can anyone give me any more details, or does anyone have a doco about how do this conversion? ..
Also, I know you need the accel cable & cruise cable from an EF/EL ..
What else is needed? ..
Thanks!
Antony.
justfordima
PostPosted: Thu Jan 13, 2005 8:40 pm    Post subject: Reply with quote
I can't answer much, except for the fuel rail. The fuel rail is the same, no change, its the fuel regulator that you have to change as far as Im concerned. With the rest of it, Im sure there was some Doco's floating around the web...
Post up your results, Ive been considering this mod myself.
Jaysen
Commercial Sponsor
PostPosted: Fri Jan 14, 2005 12:13 am    Post subject: Reply with quote
You will have to change the fuel rail as the BBM rail has the fuel reg bolted to the back of it as opposed to the earlier E series ones that suspended the reg out towards the intake runners. I dont think that you can run the BBM vaccuume control module off an EECIV so you would need to hook up a RPM switch to change the runner length at the desired RPM. Ford do this at about 3800RPM but you may want to change this (this would be to little benifit cause ford spent big bucks developing this system) Also spark advance changes slightly when the runners change length due to better VE so you may need to run a piggy back chip to simulate these characteristics, or run a EECV ECU and harness instead.
Striker
PostPosted: Sat Jan 15, 2005 2:00 pm    Post subject: Reply with quote
Jaysen: do you have any further information on what exactly needs to be done for a BBM install?
I want to install one also, but once it's bolted on, I'll be completely lot, as I know nothing about the wiring.
There used to be a doco on FordMods, I'm sure of it. Anyone know who posted it?
--Striker.
justfordima
PostPosted: Sun Jan 16, 2005 1:15 am    Post subject: Reply with quote
I stand corrected. I knew it had something to do with the reg. Jaysen, you sound like you've done this mod? any gains? benefits? worth the money?
Andrew J
PostPosted: Sun Jan 16, 2005 1:27 am    Post subject: Reply with quote
I wouldnt be so sure about the intake runners after the trouble SVO XR6( I think) is having. He apparently made more power when they werent changing, than what he did when they were operational. If this is true, one would really have to wonder about how good the BBM manifold is.
justfordima
PostPosted: Sun Jan 16, 2005 1:31 am    Post subject: Reply with quote
Yet alot of people seem to do this mod, but only for NA cars? I heard ED manifold is the best for forced induction setup?
Strange, about the first part that is... lots of people do mod, when its not that good? it costs quite a bit of money.
Striker
PostPosted: Sun Jan 16, 2005 8:03 am    Post subject: Reply with quote
From what I am aware, the BBM does not do much for topend power (a kilowatt or two, by all reports). Its sole purpose is increasing torque.
As for it being an expensive mod, I picked up a BBM (including fuel rail and loom) for $100.
There's not terribly much left to buy (EL airbox, intake piping, RPM switch), so I don't consider it to be a terribly expensive modification.
I ran my 3.9l EB1 MPFI on the dyno, and with my stage 2 cam got 359nm. Two close to stock EFs ran, and got 450nm and 470nm each.
--Striker.
justfordima
PostPosted: Sun Jan 16, 2005 11:21 am    Post subject: Reply with quote
I knew about the torque... what I didn't know was how cheap they go for...lol... definately considering now.
Nigel
PostPosted: Sun Jan 16, 2005 11:30 am    Post subject: Reply with quote
Righto - Couple of things.
Need BBM, also need fuel rail. Injectors same. Need to modify wiring to accomodate BBM Throttle body and ISC as the EB/D one hits the bonnet (apparently).
Need the BBM Vacuum switch also.
To Switch BBM - get the new Jaycar RPM based switch - not expensive and will switch reliably at RPMs. Tune it to switch around the 3250 - 3750 mark (seems the more mods the more your gonna want to get closer to 3750.
If you want to go from there, look at getting an EL ECU which could switch the BBM and can also control a set of thermo fans. The EL ECU has dual-maps - for the BBM states. The EL ECU can also use a knock sensor so your timing may be better. There are a few other things to look at here as well including that you may need to alter your base ignition timing as per EL specs.
Nigel
altedxr6
Sponsor + Donator
Sponsor + Donator
PostPosted: Sun Jan 16, 2005 3:58 pm    Post subject: Reply with quote
Is it possible to run the ED ECU, & loom, By moving the wiring from the ED intake, and putting into an BBM? ... I know this will need some splicing some wirings and stuff ... and then run the jaycar RPM switch, and tapping extra wires into the ED ecu? .
ch0c0
PostPosted: Sun Jan 16, 2005 7:05 pm    Post subject: Reply with quote
the best way to go is definitely using the EL ECU, and then as stated you have the advantage of thermofan control icon_smile.gif
altedxr6
Sponsor + Donator
Sponsor + Donator
PostPosted: Sun Jan 16, 2005 7:07 pm    Post subject: Reply with quote
Already have thermo fan control, aftermarket, wanna get it going without an EL ecu, got everything but that, I know its been done with an ED ecu before, just gotta pick someones brains who done it .
[40 queries :: 0.06773 seconds ]
