Posted: Fri Jan 14, 2005 7:49 pm Post subject: BBM, interesting |
Hi all
As many of you know i got a ELXR6.
cam/mild porting/exhaust and intake ect....
I had it on the dyno about a month ago, unaware the bbm switch wasnt working. pushed 212 rwhp
Went yesterday to try again with some lil changes just to see the difference. This time with the bbm switching at 3750rpm.
Shocked look on my face when i saw the dyon results, 200rwhp!!!!!!!
Hit 3750rpm and kicked up really quick, but once it 200hp it went flat and stayed flat. also lost tourque after the initial spike.
*scratches head, so i thought the only thing it could be is to turn it back off.......225rwhp
Goes against theory, im sure its all working proplery and it shocked me to find this......
time for a custom plenum  |
Age:25 Posts: 3896 Joined: 11 Nov 2004 Location: townsville QLD, Australia
Posted: Fri Jan 14, 2005 8:28 pm Post subject: |
could it be switching backwards????
going to from short to long instead of long to short??????? |
needturbo6 Fordmods Parts Gopher
Age:24 Posts: 50 Joined: 30 Dec 2004 Location: Perth WA, Australia
Posted: Fri Jan 14, 2005 9:27 pm Post subject: |
| thats very interesting, whar rpm does it develop its max power - with bbm working and without |
Posted: Fri Jan 14, 2005 9:42 pm Post subject: |
with out, 5250rpm
with, opens at 3750rpm, spikes and holds for the rest of it, so from about 4k |
Posted: Fri Jan 14, 2005 9:43 pm Post subject: |
| tickford_6 wrote: | could it be switching backwards????
i thought that too, but i checked it over and over again but its rite.  |
Waggin Site Admin
Posted: Fri Jan 14, 2005 10:12 pm Post subject: |
You realise if your EMS8860 was tuned with the BBM not working that you will need to re-tune the car with the BBM enabled?
The spark and fuel requirements are drastically different when the runners switch over. |
Posted: Fri Jan 14, 2005 10:15 pm Post subject: |
yeah it was
origianly it was tuned to long runners full time.
theni figured out the bbm wasnt running rite so i fixed it and retuned everything above 3750 so it was all spot on again.
But the figure of 225rwhp was the map made for the working bbm, but only running the long runners.
Fixed that this morning tho, HEAPS better! |
Waggin Site Admin
Posted: Fri Jan 14, 2005 10:20 pm Post subject: |
| If its just set up for the long runners, thats why you're losing peak power. |
Posted: Fri Jan 14, 2005 10:38 pm Post subject: |
| i made more power with long runners, thats what im saying. |
Waggin Site Admin
Posted: Fri Jan 14, 2005 10:41 pm Post subject: |
| Yeaaaaah, but if you have it set up so it switches to short runners at the correct RPM ~3300, and then spend some time with the fuel and spark maps above 3300rpm, you should have even further gains, thats why you are only getting a flat 200rwhp when it switches to short. |
Posted: Fri Jan 14, 2005 10:44 pm Post subject: |
| SVO XR6 wrote: | yeah it was
ehh ^^^
was tuned for short runners above 3750 |
Waggin Site Admin
Posted: Fri Jan 14, 2005 10:49 pm Post subject: |
Ah F**k.
I'm just not with it. LOL
So you found that switching at 3750rpm did it for you? Any reason for taking it higher than the ~3300rpm set by the EEC ?
I get a massive dip in my dyno curves when the BBM switches over. I'd love to experiment and see which setup would provide the most power, with the least power drop.. whether its better to switch just before peak torque, or just after. |
Posted: Fri Jan 14, 2005 10:52 pm Post subject: |
yeah, i read thats where jmm move it too, so i tryed it.
Ill put up a dyno sheet to show you the difference when i figure out how to.
An example, driving in wet (P-Zeros, f**k sticky) in 2nd.
flored it from 2500rpm, total traction from speed.
Hit 3700rpm and kicked the rear end out about 3 foot!!! |
Waggin Site Admin
Posted: Fri Jan 14, 2005 10:57 pm Post subject: |
| SVO XR6 wrote: |
is that with the BBM working, or not?
If it is with the BBM working, I wonder what the effect would be moving it up or down 500rpm.. whether you would suddenly kick at the switch RPM, or whether it would remain at 50rpm below switch point. |
Posted: Fri Jan 14, 2005 11:03 pm Post subject: |
with it on
It kicked the back out as soon as it opened!
on the dyon graph, it jumps about 15hp within 30rpm!! then stopped at 200rwhp
You need to see the graph, its crazy |
comhelp Fordmods Tyre Shredder
Age:25 Posts: 391 Joined: 06 Nov 2004 Location: Melbourne VIC, Australia
Posted: Sat Jan 15, 2005 7:00 am Post subject: |
I would be interested in seeing this graph as well  |
Posted: Sat Jan 15, 2005 4:46 pm Post subject: |
| Waggin wrote: | Ah F**k.
just remembered, when driving hard i usally rev to 6k. When pulling next gear it fell back onto 3700rpm ish. SO it seemed premo for driving hard. |
Age:25 Posts: 3099 Joined: 05 Nov 2004 Location: Mornington Peninsula VIC, Australia
Posted: Sat Jan 15, 2005 6:05 pm Post subject: |
so after all this... is the BBM helping or not?  |
Posted: Sat Jan 15, 2005 8:12 pm Post subject: |
| ehh, to a point yes, but peak power, no |
Timmeh Fordmods - Getting Side Ways
Posts: 6876 Joined: 06 Nov 2004 Location: Perth WA, Australia
Posted: Sun Jan 30, 2005 9:58 pm Post subject: |
Where is this switch for the BBM on an EF? I'm guessing your not talk about the piping from the airbox because the EL just has the one? Got pics of what your talking about after the throttle body?
Cheers.
I know nothing about this BBM stuff your talking about. |
