BenJ's EL Engine Conversion
BenJ
PostPosted: Wed Sep 03, 2008 5:51 pm    Post subject: Reply with quote
I am using the knock sensor.
BenJ
TROYMAN
View User Gallery (20)
PostPosted: Wed Sep 03, 2008 6:49 pm    Post subject: Reply with quote
as am i..
i dont know why you would use the el manifold loom and make adaptors as its just as neat if not neater to just use the eb loom.. once its done you cant even tell..
just look how factory bens and my loom looks.
its only 2 extra wire for the knock sensor.
2 extra wires for the bbm solinoid and 2 extra wires if you want your thermo fans running of the ecu.. a total of 6 wires neatly taped up and run through the fire wall..
unless you do a whole body loom swap i dont see the point..
and at any time we can unplug it and re fitt the eb manifold and loom with no fuss. icon_smile.gif
frankieh
View User Gallery (29)
PostPosted: Thu Sep 04, 2008 1:18 am    Post subject: Reply with quote
A full loom swap was one of the reasons I don't want to change the engine loom... I am putting an EL motor in and an el front end.. decided if I want to go the way of BenJ and do the dash too, I'd rather just swap the whole loom...
still, will see how this works.. if it doesn't I guess I'll be doing it that way as well.
snap0964
PostPosted: Thu Sep 04, 2008 9:59 am    Post subject: Reply with quote
frankieh wrote:
I also want to make use of knock sensor and it's also a challange to make an adaptor.
If you don't have a knock sensor plug, the Inlet air temp (IAT) plug should be a straight fit IIRC.
huggiebear
View User Gallery (28)
PostPosted: Thu Sep 04, 2008 12:06 pm    Post subject: Reply with quote
i havnt hooked my knock sensor up and havn't had any issues with it... what does it actually do?
frankieh
PostPosted: Thu Sep 04, 2008 3:29 pm    Post subject: Reply with quote
As I understand it.. it retards the timing by up to 4 degrees if it detects detonation.
huggiebear
PostPosted: Thu Sep 04, 2008 6:13 pm    Post subject: Reply with quote
crazy stuff.... i think i might have to hook it up
commandojones
PostPosted: Thu Sep 04, 2008 8:42 pm    Post subject: Reply with quote
Sorry (lateness)I used the EB loom, i had to alter to fit the in and around the BB manifold n to hook up the ISC etc. I havent hooked up the knock sensor either. retards the timing hey. when i first had the motor in it used to ping under load, running on premo helped, all i did was retard the timing (base ignition timing- i think) cos the timing light showed it was advanced slightly. ever since then no pinging but i wondering if i lost tiny bit of power doesnt quite feel the same. icon_confused.gif
TROYMAN
PostPosted: Thu Sep 04, 2008 8:52 pm    Post subject: Reply with quote
commandojones wrote:
Sorry (lateness)I used the EB loom, i had to alter to fit the in and around the BB manifold.
yep you should have only had to extend the isc and tps wires..
the rest is a straight fit.
commandojones
PostPosted: Thu Sep 04, 2008 8:58 pm    Post subject: Reply with quote
Yeh thats all i did from memory
BenJ
I also had to extend the Coil wire and the Air Temp wires.
BenJ
knowsfords
PostPosted: Fri Sep 05, 2008 10:19 am    Post subject: Reply with quote
BenJ
I had to extend the airtemp wires (while it was in the car and threaded through, not fun) but the coil just reached iirc
TROYMAN
PostPosted: Fri Sep 05, 2008 10:49 am    Post subject: Reply with quote
there must be slight differences in loom lengths or its in the way its routed?
with mine i only had to extend the tps and isc wires.
and when we did mrs eb ghias car i only had to extend tps,isc and the wire to the starter..
huggiebear
PostPosted: Fri Sep 05, 2008 11:20 am    Post subject: Reply with quote
with mine it all JUST squeezed in. just extended the 2 sets of wires. tho its not all plug and play for everyone. my old EA used 2 TPS's one for the gearbox which had a seperate computer to run it. and the ISC was a completely different plug. my NC however... since its more like an EL then an EB it had all the correct plugs from factory. so now i have spares icon_smile.gif
relaxed_diplomacy
PostPosted: Thu Sep 11, 2008 9:56 pm    Post subject: Reply with quote
Hi Troyman,
Hope everything's been cool for you.
Where exactly through the firewall did you run the wires? Did you have to remove any of the dash?
huggiebear
PostPosted: Thu Sep 11, 2008 9:58 pm    Post subject: Reply with quote
i ran mine through the gromit that the window washer loom comes through
BenJ
PostPosted: Thu Sep 11, 2008 10:44 pm    Post subject: Reply with quote
I ran mine through the grommet where the vac lines come through behind the washer bottle.
BenJ
relaxed_diplomacy
PostPosted: Thu Sep 11, 2008 10:56 pm    Post subject: Reply with quote
Looks like a consensus. So this can be done without removing dash? Maybe take out the glovebox?
[PS - looking at that photo of your car BenJ, i wonder if you have considered painting the A-pillar and roof black? I think Ford Probe's were often red with black pillars and roof, to compare]
huggiebear
PostPosted: Fri Sep 12, 2008 8:47 am    Post subject: Reply with quote
you only need to remove the glovebox, i also removed the passenger side of the dash. bottom section. its easy as. a few screws and it pops out giving you alot more access and arm space.
BenJ
PostPosted: Fri Sep 12, 2008 10:37 am    Post subject: Reply with quote
Yes with the EB Dash you can do that.
Completely different story with the EL dash. The bloody thing doesn't come apart like the EB one.
But a but of stiff wire and all is possible.
BenJ
Page 6 of 7
[47 queries :: 0.05524 seconds ]
