ringastinga Fordmods - Getting Side Ways
Age:22 Posts: 847 Joined: 09 Aug 2005 Location: frankston VIC, Australia
Posted: Fri Sep 12, 2008 7:32 pm Post subject: |
| question... did the el's have knock sensors or just the ef's? as i didnt change the timing case when i did my eb to el conversion |
Age:36 Posts: 1476 Joined: 23 Dec 2007 Location: Perth WA, Australia
View User Gallery (29)
Posted: Fri Sep 12, 2008 7:40 pm Post subject: |
| Timing case?? The knock senor is in the block under the intake manifold isn't it? |
Posts: 3455 Joined: 31 Oct 2005 Location: . QLD, Australia
View User Gallery (28)
Posted: Fri Sep 12, 2008 8:36 pm Post subject: |
| yes the EL has a knock sensor. it is located on the passenger side of the motor towards the back on the block itself |
Age:33 Posts: 1026 Joined: 14 Dec 2007 Location: delegate NSW, Australia
Posted: Fri Sep 12, 2008 9:34 pm Post subject: |
All this talk about sensors is topical for me. Today i fitted the upper half of my EL BBM to the lower half of my AU BBM. Makes it much more plug and play.
Is there any chance i might ever decide to use the crank angle sensor or the other sensor just next to it? What does it do? Otherwise i'll take them off.
There is also a sensor at the back of the head a little bit towards the drivers side. What does that do?
The AU block doesn't have bolt holes for a coil, so i decided to mount the coil vertically using the middle two BBM bolts. It's a neat setup, but i'll need to redrill it again because the plug is interfering with another plug that goes into the BBM. |
Posted: Fri Sep 12, 2008 9:37 pm Post subject: |
huh? you confused me. there should only be 1 knock sensor and its not on the head. there shouldnt be ANY sensors on the head itself.
how does the bottom half of an AU manifold make it more plug and play? the bottoms are identicle |
Posts: 2657 Joined: 27 Dec 2004 Location: melbourne, sunshine VIC, Australia
Posted: Fri Sep 12, 2008 9:47 pm Post subject: |
| the AUs have the temperature sensor in the head at the rear....its actually a better system because it measures cylinder head temperature, which means it can still sense temperture even when completely out of water...I dont think its compatable with the E series ecu but |
Posted: Fri Sep 12, 2008 9:58 pm Post subject: |
| bloody hell. i didnt know that.. |
Posted: Fri Sep 12, 2008 10:10 pm Post subject: |
| huggiebear wrote: | | how does the bottom half of an AU manifold make it more plug and play? the bottoms are identicle |
It's the EL upper that is making things easier.
I'm surprised at the number of changes to the sensors and even the castings between the EL and AU upper bbm stuff. |
Posted: Fri Sep 12, 2008 10:15 pm Post subject: |
| gogetta wrote: | | the AUs have the temperature sensor in the head at the rear....its actually a better system because it measures cylinder head temperature, which means it can still sense temperture even when completely out of water...I dont think its compatable with the E series ecu but |
Thanks. I was guessing it's a temp sensor.
The advice i've been given on this forum is to fit the EB lower thermostat housing, which has two temp sensors. I did that today. |
[36 queries :: 0.05907 seconds ]
