TROYMAN Technical Contributor
Age:34 Posts: 3094 Joined: 07 Nov 2004 Location: South Western Sydney NSW, Australia
View User Gallery (20)
Posted: Sun Feb 24, 2008 10:41 am Post subject: |
| xfpaul wrote: | | TROYMAN wrote: | actually im about to change my injectors over to au ones..
i originally used the el manifold and injectors.
im planning to come an friday .
im still alittle disabled with my ankle (hobling around on crutches)lol
but i can now push the clutch in without to much discomfort so im hoping to be there.. |
thanks for your help , au2 in the nc2 is great any how correct me if im wrong but i checked the part no on the au2 injectors and they come up as 14lb so i stayed with nc injectors which are 19lb |
do you have that part no?
there are some guys who are getting good numbers with au injectors and ive heard that the au injectors possably flow 21lbs?
and std injectors only flow 18.15 to 18.25? acording to there part no
its mentioned in this thread.
http://www.fordmods.com/forums/stock-injectors-t59369.html |
Posts: 3649 Joined: 08 May 2007 Location: Sunny QLD, Australia
Posted: Sun Feb 24, 2008 10:50 am Post subject: |
| according to injectors online, the eseries are 18lbs and the AU is 20lbs |
BuNtEr Technical Contributor
Age:41 Posts: 3227 Joined: 12 Feb 2007 Location: your mums NSW, Australia
Posted: Sun Feb 24, 2008 5:53 pm Post subject: |
| i rang Benj just over a hour ago and they havent got the new motoer in as yet, lets hope its in soon |
Age:46 Posts: 158 Joined: 12 Jun 2005 Location: hobart TAS, Australia
Posted: Sun Feb 24, 2008 5:57 pm Post subject: |
ok now im confused the nc2 injectors are bosch 280 150 790 normal 4.0l injectors , same as misses xf and mates el xr6 both websites have them rated at 18 /18.15 at 43.5 psi
the au2 injectors are 280 155 844 one site it lists them at 14.3/43.5, the other has them at 20/???
im running a malpassi rising rate and want to increase the injectors (i think) because the 3.8 that the m90 came off run 42lb but am a little worried that the el ecu wont handle them , back the injector pulse time down to keep a good idle
i use ultimate fuel only , have no pinging at all , 6 psi boost , hyperspace fairlane rear ratio , knock sensor is not hocked up base timing set 10 degress adv
9.6:1(au2)+6 psi = about 11.3:1
yeah i know it shouldnt be runing but it flys ???????????????????? |
Posted: Mon Feb 25, 2008 6:14 pm Post subject: |
so benj
how did the engine change go??
is up and running ? |
Posted: Mon Feb 25, 2008 6:22 pm Post subject: |
| TROYMAN wrote: | so benj
last i heard 2 hours ago still fitting the motor |
Posted: Mon Feb 25, 2008 6:25 pm Post subject: |
ohh
he must of had a few dramas..lol |
Posted: Mon Feb 25, 2008 6:28 pm Post subject: |
| perving on the women i bet lol |
BenJ Cruise Moderator
Posts: 1687 Joined: 20 May 2005 Location: Seven Hills, Sydney NSW, Australia
Posted: Mon Feb 25, 2008 9:08 pm Post subject: |
Hey All
The EB now has an EL engine.
I will post up over the next few days all of the 'fun' we had.
BenJ |
paulc Cruise Moderator
Age:51 Posts: 1237 Joined: 22 Jun 2005 Location: Campbelltown NSW, Australia
Posted: Tue Feb 26, 2008 5:18 am Post subject: |
| Well done mate, look forward to the debriefing on how thing went. |
Age:21 Posts: 986 Joined: 01 Sep 2007 Location: sydney NSW, Australia
Posted: Tue Feb 26, 2008 2:06 pm Post subject: |
nice one benny.
hows it goin compared to the old motor? |
Age:31 Posts: 1068 Joined: 23 Dec 2004 Location: Mildura VIC, Australia
View User Gallery (25)
Posted: Tue Feb 26, 2008 9:46 pm Post subject: |
nice work, well done  |
jonathon Fordmods - Getting Side Ways
Age:21 Posts: 1165 Joined: 14 Apr 2006 Location: Whyalla SA, Australia
Posted: Wed Feb 27, 2008 1:28 pm Post subject: |
| exelent work |
Posted: Wed Feb 27, 2008 4:01 pm Post subject: EL Engine Install |
Well, what can I say. PaulMac, Luke (my son) and I had quite a time.
What started out as, "4 hours, no worries" turned into a very long haul.
OK, so Sunday started at 7.30am with Luke and I jumping in the car and heading from Sydney up to the Central Coast to go to PaulMac's place. We rolled up to PaulMac's at about 9am and by 9.30 we were already taking the car apart.
Now PaulMac has put an EL engine in his car, but used the Log manifold, so we at least had some experience here. However we progressed slowly and methodically and around 3 hours later, had the EB engine and auto mostly out of the car.
We had our problems like we all do. The auto cooler lines didn't want to come off and the engine crane wouldn't fit under the front of the car as it was too low. But we perservered and got it out.
Check out all the gunk on the back of the Auto. PaulMac wondered how it stayed cool.
During this time I pulled the EL BBM loom off the engine and layed out the loom I had made. I found I had to extend the plug for the air temp sensor as this hadn't been mentioned in any of the threads I had read. Luckily I had taken everything with me. Here I am with the EL BBM Loom removed.
The engine bay was almost as dirty as the auto was, so PaulMac fired up the pressure washer and gave it a good blast. Nice and clean now.
Then we moved the trailer with the EL Engine. I am balancing it. Wouldn't want it to roll over and break something now would we.
Now the fun begins. It is supposedly a simple task. Just slide the auto up to the back of the engine, give it a bit of a jiggle, and it should just drop into place. Like bloody hell it does. We fought with the damn thing for two hours. I am sure we tried more positions and angles than most prostitutes would know. Then all of a sudden it worked. About bloody time.
Next step was making sure the EL Engine was prepped to go in. Close examination showed up a few differences between the EB and EL engines. We realised the heater hoses wouldn't fit. The EL engine mounts were different so had to be swapped. And the fuel lines are different too.
PaulMac went off to Bursons and picked up some heater hoses. While he was out I took care of a few things, like changing the alternator plug, bolting in the EL ECU and plugging in my custom loom for the BBM and Knock Sensor, and started playing with the cruise cable and throttle cable. Oh, and where is the EL throttle cable Paul? We realised it was still on the car the engine came out of DOH. PaulMac's lovely wife went for a drive to get it. Thankyou heaps.
So PaulMac returned and we hoisted the EL Engine up and slid it half into place. By this time it was dark, and we had to work by light. PaulMac then worked out how we could marry the fuel lines up.
The following is his how too.
"There are two simple ways to attach the fuel lines and maintain the EL top and bottom connections.
1] My preferred option is to cut the EL metal fuel lines at the chassis rail of the donor car, leaving the flexible line intact with a 'tail' of 50-60mm of metal fuel line. Flare them very slightly with a flaring tool if you have one. Re-fit to engine or manifold while out of the car, marking the regulator feed line 'tail' clearly.
Install the engine and from under the car place hose clamps over the [EA-ED] flexible lines then cut them to a length suiting the metal 'tail', insert the tail into the appropriate chassis feed or return line, clamp tight.
NOTE: Feed line goes to the regulator, return line from the rail.
2]The second option is used when the EL flexible lines have been cut before the bottom join or the 'tails' are of inadequate length. Cut two lengths of metal fuel line [flare slightly if possible] and insert and clamp them into the EL flexible lines, forming the 'tails'.
Proceed as above."
The second option was forced upon us because one EL fuel line had not been cut away as required, [due to a misunderstanding by the engine supplier, an otherwise very helpful and professional mechanic] and we had to cannibilise the other for the metal line needed."
Cheers,
Thanks PaulMac - I guess one could always use the EB fuel rail.
Once that was done the engine was lowered down but wouldn't get that last 10mm for the engine mounts to drop over the K frame. So, it was out with the right had mount and down it went. But do you think it was easy to bolt the mount back on? Ohhhh Nooooooo. Stupid bloody thing.
This pic shows the engine almost in place, and gives you a look at our high tech lighting. This was around 1am.
Finally we held our mouths the right way and got it sorted. We went around connecting all the bits we had disconnected. PaulMac put the EL radiator in and found that it was slightly different to the EB one. The rubber spacers on the bottom held it up too high, so he improvised that. And then the hose that goes from the bottom of the header tank into the right side of the radiator wouldn't fit as the EL radiator has a right angle bend in it. More solutions were found. The auto cooler lines didn't want to go back together again.
Finally at around 4.30am it was all back together and it was time to start it for the first time.
I turned the key and............... ZIP!!!! It just cranked over.
The fuel pump sounded odd tho, so we threw a few ideas around, and I suggested that the fuel lines could be back to front. A bit of research on line and comparing PaulMac's car etc proved this theory to be sound. So they were swapped over and we were ready to try again.
The key turned, the engine fired..........and ran..........clang clang clang clang....... I turned it off in a hurry.
So considering it was now 5am and we had been working straight through from 9.30am the previous day, we packed up a little bit, called it a morning and went inside for a well earned NAP. |
EVL098 Fordmods - Smokin em up
Age:32 Posts: 278 Joined: 23 Nov 2006 Location: Sydney West NSW, Australia
Posted: Wed Feb 27, 2008 4:12 pm Post subject: |
Sounds like much fun was had.
I have never ever had an engine conversion go to plan 100%.
Now when I am going out to do something at lunch on a Sunday and I tell the missus it will take a couple of hours , she says "ok Ill get dinner ready for about 9 oclock".
She knows and suffers it all too well! |
Posted: Wed Feb 27, 2008 4:24 pm Post subject: |
Day Two - 3 hours or so later.
We took our sorry worn out selves back out to the car (where did I put that match and petrol again?) took it down off the stands and ramps, and with slightly clearer heads tried it again. More clanging.
Much conversation ensued as to the possible cause, mostly revolving around the auto being faarked. In the end we put the front back up on stands, and removed the dust sheild of the auto to check the torque convertor bolts. The all looked fine so I asked PaulMac to start the car while I was under it (Don't do this at home boys and girls). Clang Clang Clang. I immediately could see the problem. PaulMac joined me under the car and agreed with my diagnosis.
It would seem that while we were frigging around trying to put the auto on the engine, we had shoved a jack under the sump at the back of the engine to lift it...........and crushed the sump so now the cranshaft was hitting it.
NOT HAPPY JAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Much more discussion ensued and the only solution was the obvious one.
Lift the engine, drop the sump and bash out the dent.
Sounds simple enough doesn't it. Let me tell you nothing is simple - ever!!
PaulMac ducked off to get a sump gasket, while I removing the gazzillion bolts that hold the sump on. We hooked up the front of the engine to the engine crane to lift it. But it wouldn't lift high enough to remove the sump.
So I dropped the K Frame to give us more room. The Bugger still wouldn't come out. Does anyone know if the EB and EL sumps are the same? The K Frames are quite different, so they could be different.
After much swearing and struggling it was suggested, not sure by who now, to insert a long object on an angle from the side into the sump and then bash the holy hell out of it in an effort to puch the dent out.
To cut a long long day short, this actually worked. You will not believe how relieved I was when we started it and there was no wrong noises.
So we buttoned it all back together, filled it with oil and started it again. Now I gave it a rev. Up to 2 grand and splutter. FAAAAAAARK!!!!!!!
A quick think later, I remembered the EB Map sensor got pretty squashed by the BBM while putting the engine in. So I grabbed the EL map sensor, swapped them over and all was rosy. It revved strong and hard. The BBM was doing its thing and all was good with the world.
Except for the auto fluid pouring out on the driveway. This proved to be a loose auto cooler line. I hate those things. Once tightened up all good.
Of course by now it was after 5pm Monday.
Here are a couple of shots with the engine in and finished.
I took the EB for a test drive and it went great. The only real worry was that the temp guage in the dash didn't work, and I think we killed my Davies Craig thermo switch at some point. I had to run the fans from my manual overide switch.
We packed up, jumped in the car and headed back to Sydney. The car went well and cruised easily home.
I hope you all enjoyed my little story. I will be posting up a list of parts that I think others will need if they are considering a similar conversion. And I will provide some more detail of other changes/mods to make this happen.
PaulMac and family, the biggest thank you for the time, effort and hospitality. You are a true friend and Ford Modder.
BenJ |
Posted: Wed Feb 27, 2008 4:54 pm Post subject: |
far out mate
good to see its running sweet .
i bet you were spewing about the sump.
when i read that the part about the sump my first thought was oh no! |
Posted: Wed Feb 27, 2008 5:11 pm Post subject: |
Spewing is putting it mildly. But, I was relieved that it wasn't the Auto, as I was not enjoying the prospect of pulling the engine back out!!!!.
I just found out why the Davies Craig switch wasn't working. The temp probe had broken off the end of the wire!
On other things cooling related, I have spent a good number of hours yesterday and today, trying to get the ECU to control the fans. However I have not had any success. I have now procured a replacement Davies Craig switch, as remembering to turn the fans on is a dangerous game.
The fix for getting the temp guage to work, was to replace the lower thermostat housing with one from the EB. This had the fittings and sensors the dash needs, as well as the climate control (for when that gets installed).
More things as I think of them.
BenJ |
[47 queries :: 0.09254 seconds ]
