Rabidfrog Fordmods Newbie
Posts: 14 Joined: 21 Jan 2007 Location: Mildura VIC, Australia
Posted: Fri Feb 22, 2008 7:51 pm Post subject: |
Hey BenJ, Glad to see you got good use out of my cruise mod guide.
Car looks great dude and the wheel just sets it off.
Nice job.  |
BenJ Cruise Moderator
Posts: 1158 Joined: 20 May 2005 Location: Seven Hills, Sydney NSW, Australia
Posted: Fri Feb 22, 2008 11:31 pm Post subject: |
Cheers mate.
I don't know why more of us aren't doing this mod.
BenJ |
BuNtEr Technical Contributor
Age:41 Posts: 3227 Joined: 12 Feb 2007 Location: your mums NSW, Australia
Posted: Sat Feb 23, 2008 7:03 pm Post subject: |
| ToranaGuy wrote: | Nice work dude, especially with the steering wheel. It would be great to have an after market wheel to steer with & still have my cruise. But i've got a different idea about the cruise buttons.....
I can just see it, i will be spending way too much on my ford & will take way too long to get my Panel Van & Torana projects finished!
ToranaGuy |
easy toss the Torana and youw will be able to do the others lol. |
Posted: Mon Mar 10, 2008 12:06 pm Post subject: Steering Wheel Badge |
I have been playing around with the steering wheel horn badge. I removed the Autotechnic sticker and tried to find something Ford oriented.
I first tried a small Ghia Emblem
I drove around with this for a couple of weeks, but in the end decided it stood out too much.
So I now have this EL Fairmont Badge.
I like this more, as it is more subtle and the colours blend in well.
Cheers to all
BenJ |
TROYMAN Technical Contributor
Age:34 Posts: 2527 Joined: 07 Nov 2004 Location: South Western Sydney NSW, Australia
View User Gallery (30)
Posted: Mon Mar 10, 2008 12:32 pm Post subject: |
cool
i like them both...  |
Posts: 3009 Joined: 08 May 2007 Location: Sunny QLD, Australia
Posted: Mon Mar 10, 2008 12:47 pm Post subject: |
find a huge mofo redback spider, enclose it in resin and afix it to the steering wheel, similar to the classic redback gearknobs?  |
Posted: Mon Mar 10, 2008 1:33 pm Post subject: |
My teenage daughter suggested a Transformers badge.
I quite like the idea and will see what I can find.
BenJ |
Posted: Sun Mar 23, 2008 10:16 pm Post subject: |
Sneak Preview
Can you work out what this mod in progress is?
BenJ |
OZBMX Fordmods Tyre Shredder
Age:18 Posts: 336 Joined: 31 Dec 2007 Location: Munruben QLD, Australia
Posted: Sun Mar 23, 2008 11:11 pm Post subject: |
ah nice ef fairmont cluster, but you gonna print off some backers like off the old dash?
by the way, how did you get the odometer to work, going from the mechanical to digital? or does it pretty much input the same. |
Posted: Mon Mar 24, 2008 9:05 am Post subject: |
hey
i see you got it to work ben .
it looks good |
Posted: Mon Mar 24, 2008 9:10 am Post subject: |
| OZBMX wrote: | ah nice ef fairmont cluster, but you gonna print off some backers like off the old dash?
To use the EF/EL cluster you need to be running the EL ECU. The cluster receives information from the ECU via a DATA output line.
The speed and ODO in both clusters run off a signal from the Speedo sensor on the transmissions.
I have a few things to sort out before it is finished, but will post up some more detail when it is all done.
BenJ |
Posted: Mon Mar 24, 2008 9:11 am Post subject: |
| TROYMAN wrote: | hey
it looks good |
Yes Mate.
Do you know if the oil pressure switch in the EB is the same as the EL?
And I still have to work out how to mount it.
BenJ |
Posted: Mon Mar 24, 2008 9:24 am Post subject: |
yea the oil pressure sender should be the same.?
i noticed your oil pressure was on full??
if there is no conection between the sender and the guage the guage will go to full...
so does everything work ok ..
i cant wait to see it in the flesh.. |
Posted: Mon Mar 24, 2008 10:36 am Post subject: |
| i would like o do the same, i have to hunt down a cheap V8 ef ECU |
Posted: Mon Mar 24, 2008 10:58 am Post subject: |
Well Done Ben.
| BenJ wrote: | | The speed and ODO in both clusters run off a signal from the Speedo sensor on the transmissions. | And in the EF/EL's, the VSS to the ECU comes from the cluster, not directly from the speed sensor as in EA-ED.
I think you'll find the EF TC will now work accurately.
I've got a few spare mid series boards here, due to both cars having F/lane clusters now, so if you need an EPROM set up to preserve your kms, let me know. |
Posted: Mon Mar 24, 2008 11:04 am Post subject: |
| BuNtEr wrote: | | i would like o do the same, i have to hunt down a cheap V8 ef ECU |
According to the EF/EL Cluster Upgrade Doco they work in both, unlike the EB clusters.
BenJ |
XPFalcon170 Fordmods Tyre Shredder
Age:23 Posts: 361 Joined: 19 Apr 2006 Location: Liverpool NSW, Australia
View User Gallery (19)
Posted: Mon Mar 24, 2008 11:07 am Post subject: |
| mate, looks a treat. |
Posted: Mon Mar 24, 2008 11:08 am Post subject: |
| snap0964 wrote: | Well Done Ben.
Thanks Snap0964
I still have the ECU receiving the speed signal direct from the VSS. Do you think I need to change it to receive the signal from the dash?
Do you have any thoughts as to why the Tacho would get the shakes under acceleration. It is fine while standing still.
BenJ |
[47 queries :: 0.05883 seconds ]
