Bassfreak55 Fordmods - Getting Side Ways
Posts: 529 Joined: 11 Nov 2004 Location: Canberra ACT, Australia
Posted: Mon Jan 17, 2005 9:54 pm Post subject: Best engine combination... |
For all you high performance engine builders out there..!!
Whats the best combination of parts i would go for to extract as much power possible out of an el xr8 302 engine for around $5000?
Only for the top end of the engine though, as the bottom end will get rebuilt & stroked later down the track.. |
kermey Fordmods - Getting Side Ways
Posts: 1334 Joined: 13 Dec 2004 Location: Perth WA, Australia
Posted: Mon Jan 17, 2005 10:51 pm Post subject: |
fluffy dice, only if u can afford it with you 5g bugget  |
drazull Fordmods - Getting Side Ways
Age:25 Posts: 780 Joined: 05 Nov 2004 Location: Adelaide SA, Australia
Posted: Mon Jan 17, 2005 10:59 pm Post subject: |
HAHAHA
You madman.
I dont know too much abour V8's but www.trickflow.com might be a good place to start. |
Posted: Mon Jan 17, 2005 11:05 pm Post subject: |
| drazull wrote: | HAHAHA
You madman.
Yep, the Trickflow kit is a deffinate plan 'b'. Ie, if i cant find anything better, then i will buy that kit without a doubt. I just wana know if theres an alternative thats worth going with with instead of the TF kit, ie, if i can obtain a little for power etc.. |
Age:22 Posts: 2033 Joined: 05 Nov 2004 Location: Penrith NSW, Australia
Posted: Tue Jan 18, 2005 12:12 am Post subject: |
| You can always do better.. AFR heads will be better, you could always get a lumpier cam but that would mean notching pistons probably. Could also get Trickflow R series intake, it's endless for the windsors. You have to set your budget and your goal, then go from there. |
Posted: Tue Jan 18, 2005 10:57 am Post subject: |
Best part under $5k to get the most power
Nitrous kit.
Use the rest of the money for the repairs. |
4.9 EF Futura Moderator
Posted: Tue Jan 18, 2005 11:06 am Post subject: |
| XR8Chic wrote: | Best part under $5k to get the most power
Nitrous kit.
Lol, yeah well put...
Spose you could hunt down some 2nd hand GT40 heads from AU... 2nd hand GT40 upper/lower.. but even then i'm not sure if $5k leaves much change. Spose std MAF and TB wouldnt be much good on that combo either...
You able to do this stuff yourself? |
Age:55 Posts: 2496 Joined: 07 Nov 2004 Location: Penrith NSW, Australia
Posted: Tue Jan 18, 2005 12:13 pm Post subject: |
Replace them heads and good inlet AFR or the TFS combination..Then maf etc latter...Cam when heads are off 2030 1.6 rockers or 2031 with 1.72 rockers...Should be under $5k just...Get maf Pro-m latter from Mr Landau ...
Heads and inlet is the BIGGEST bottle neck... |
Waggin Site Admin
Age:25 Posts: 6757 Joined: 18 Dec 2002 Location: Sydney NSW, Australia
Posted: Tue Jan 18, 2005 3:03 pm Post subject: |
Do the GT40 heads become available often on the 2nd hand market?
What sort of price do they fetch? |
Posted: Tue Jan 18, 2005 4:00 pm Post subject: |
| Around about a grand or a little bit over.. Call Herrod Motorsport as they usually have some left over from AUs they have had converted to AFR. |
Waggin Site Admin
Posted: Tue Jan 18, 2005 4:14 pm Post subject: |
Would they be considered a worthwhile investment at that sort of price (ie, bang for buck).
What sort of power celing do they have after some generous port work? Can they reach over 200rwkw with cam,rollers and exh ? |
Posted: Tue Jan 18, 2005 4:31 pm Post subject: |
| Kell was reaching near that power figure with just E7s (albeit ported).. GT40Ps are said to be the best bang for buck around here. Decent cam, intake, rollers etc and you'll be laughing. |
Posted: Tue Jan 18, 2005 4:48 pm Post subject: |
| 4.9 EF Futura wrote: | | You able to do this stuff yourself? |
LOL! If i wasnt gonna do this stuff myself, and was gonna pay someone else to fit it, id get jack s**t for 5 grand! ..So yes, ill be doing it myself for sure.
| EBXR8380 wrote: | Replace them heads and good inlet AFR or the TFS combination..Then maf etc latter...Cam when heads are off 2030 1.6 rockers or 2031 with 1.72 rockers...Should be under $5k just...Get maf Pro-m latter from Mr Landau ...
Thanks for ur help Graeme, much appreciated. |
MrLandau
Posted: Wed Jan 19, 2005 11:13 pm Post subject: |
You can get better gear than the Trickflow kit but you would soon blow your $5k budget.
Pro-topline 180's or AFR 185's will cost you $3000, the manifold another $1000, then you need headstuds, rollerrockers, pushrods, cam, timing chain set and gaskets to finish it. The Trickflow kit comes with all that and alloy rocker covers. I seriously don't think you will beat the power it makes for the price.
Shane |
xr8 dismantler
Age:37 Posts: 3111 Joined: 06 Nov 2004 Location: MELBOURNE VIC, Australia
Posted: Wed Jan 19, 2005 11:28 pm Post subject: |
i cant work out why i still have that AU 5ltr to suit rebuild sitting in my workshop has come out of a AU series 3 has gt40 heads and roller lifters ect
only $1000
might have to put the price up to 2 grand!! |
Fairmont99 Fordmods - Smokin em up
Age:25 Posts: 241 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Thu Jan 20, 2005 11:05 am Post subject: |
| Would be nice to drop a 220 into the AU1 but just can't afford that. A 220 into something like an ED now that could fly. |
SQUEAK Fordmods Tyre Shredder
Age:24 Posts: 377 Joined: 05 Nov 2004 Location: SYDNEY NSW, Australia
Posted: Thu Jan 20, 2005 1:35 pm Post subject: |
| Get a set of aftermarket alloy heads, and a trickflow inlet manifold, larger throttle body and a trickflow cam |
Age:37 Posts: 2469 Joined: 25 Nov 2004 Location: Sydney Australia NSW, Australia
Posted: Sat Jan 29, 2005 5:32 pm Post subject: |
I gotta agree well XR8CHIC, go NOS. I have just installed a dry system on my 5.0, no probs whatsoever. Did the install myself, transformed the car. Total cost 1500 fitted by me.
NOS 1095
Fil 120
Fuel Pump 210
extra jets to tune it 50
1 case of crownies 43
61/2 hrs total
GOOD LUCK anmd seriously consider this
PS( If you are in Sydney i will install the lot for the same dollars) |
