ILLaViTaR Fordmods Stock as a Rock
Posts: 190 Joined: 04 May 2007 Location: Aga VIC, Australia
Posted: Mon May 21, 2007 3:46 pm Post subject: Best LPG brand |
| What is the most efficient standard LPG brand (not injected) |
Posted: Mon May 21, 2007 7:44 pm Post subject: |
Is that Gas research Australia?
They have a few models on their site.
What one is best? |
Posts: 2088 Joined: 27 Dec 2004 Location: melbourne, sunshine VIC, Australia
Posted: Mon May 21, 2007 7:52 pm Post subject: |
| if your car isnt too modified then id suggest either omvl or impco, because they seem to be the 2 most popular and therefore servicing will be cheaper |
AUXR8 2
Posts: 363 Joined: 08 Nov 2004 Location: Liverpool 02 9600 6229 NSW, Australia
Posted: Mon May 21, 2007 8:30 pm Post subject: best LPG |
IMO, the Fords like positive pressure systems, thats why Ford stuck with Viallie as they had any choise including the negative pressure set ups, eg: Impco.......I'v used all of the brands but for your run or the mill to mid performance we use Airod from MED, easy to tune get good economy & easy to instal, the average 6 cylinder gets about 320km to a tank or down your way get a price of someone that dose Viallie, you also have Poliauto........Parnell....... Landi Renzo...... Sprint Gas.......OMVL as a positive pressure set up, as an idication negative pressure tends to back fire easier compaired to a positive pressure system with the same problem
Hope this helps
Joe |
ELGT Cruise Moderator
Age:76 Posts: 1072 Joined: 30 Jan 2005 Location: Brisbane, 444 cu in diesel boulevarde QLD, Australia
View User Gallery (16)
Posted: Mon May 21, 2007 8:33 pm Post subject: |
| I have always found barbeques galore excellent for all of my LPG needs.....bwahahahaaaaaa |
AUXR8 2
Posted: Mon May 21, 2007 8:43 pm Post subject: best lpg |
| speaking of bbq gallore I need to up date mine wheels & legs being chood by the dog, I'll check out the Stainless steel range, mmmm early xmas present to me. |
Posts: 1523 Joined: 30 Apr 2006 Location: Melbourne VIC, Australia
Posted: Mon May 21, 2007 10:38 pm Post subject: Re: best LPG |
| AUXR8 2 wrote: | IMO, the Fords like positive pressure systems, thats why Ford stuck with Viallie as they had any choise including the negative pressure set ups, eg: Impco.......I'v used all of the brands but for your run or the mill to mid performance we use Airod from MED, easy to tune get good economy & easy to instal, the average 6 cylinder gets about 320km to a tank or down your way get a price of someone that dose Viallie, you also have Poliauto........Parnell....... Landi Renzo...... Sprint Gas.......OMVL as a positive pressure set up, as an idication negative pressure tends to back fire easier compaired to a positive pressure system with the same problem
Hope this helps
Joe |
Very interesting - didn't realise there were different types of systems, ie positive and negative pressure set ups.
I had my EF converted with Impco and wasn't too happy with the cold start & economy. Installation was quite poor too, but that's obviously the installer, not the kit. |
Posted: Mon May 21, 2007 11:01 pm Post subject: |
hmmm.
There's a feww type of kits though and I'm unsure what is best.
The impco has a 200,225, 300A and 425 mixer how do I know what one is best?
I'm thinking of going Gas research since they're kits are only $1034, are impco cheaper? |
Posted: Mon May 21, 2007 11:04 pm Post subject: |
you would use the 200 or 225 mixer on a 6, the 425 is generally used on an 8...
who quoted you that price for the gas research?
whats included in the $1034 gas research kit? tank? obviously it doesnt include fitting |
Posted: Mon May 21, 2007 11:42 pm Post subject: |
The kit includes.....
Kits include the following :
Throttle Body, Convertor, Lock-off valve, Adapter, Electric Primer, Brackets, Gaskets, Linkages, and Closed Loop Processor System and Idle Speed Control System where applicable.
So I still need a tank which is frustrating.
That'll get pricey.
I was hoping 1k with the tank |
Posted: Mon May 21, 2007 11:45 pm Post subject: |
| Oh also I can get a twin throttle/twin converter for $1650 what exactly does that do? |
AUXR8 2
Posted: Tue May 22, 2007 12:21 am Post subject: best lpg |
| ILLaViTaR wrote: | hmmm.
what you are refering to is the size of the mixer or cfm, I think what you need to do is to go & see some set ups & decide whats best for your needs........... & as gogetta replied 200 or 225 will be fine if your going to use Impco.
Joe |
Age:22 Posts: 10073 Joined: 15 Nov 2004 Location: Hobart TAS, Australia
Posted: Tue May 22, 2007 8:38 am Post subject: |
| AUXR8 2 - you didn't like GRA? |
AUXR8 2
Posted: Tue May 22, 2007 4:43 pm Post subject: best lpg |
I'd pick GRA over Impco or OHG's for straight out performace any day, but for my straight gas V8 set ups I use Technocarb with a 3 stage convertor good for up to 370 rwhp.... then twin convertors for 370 & up I geuss that every fitter has there own preference.
Joe... |
Posted: Tue May 22, 2007 5:21 pm Post subject: |
| fair enough. I'm always interested to hear others opinions. so for a Supercharged (6psi powerdyne)Tickford SOHC 4L I6 you reckon GRA would be the way to go (or one of the better ways) if power was the prime concern with economy secondary? |
MADEA Fordmods Parts Gopher
Posts: 60 Joined: 11 May 2007 Location: beechy VIC, Australia
Posted: Tue May 22, 2007 6:09 pm Post subject: |
| my dad has a powerdyne supercharged xr6 wagon that is running the GRA setup its good for 252rwhp on 8psi, i can post up some picks if anyone is interested |
AUXR8 2
Posted: Tue May 22, 2007 6:21 pm Post subject: best lpg |
sure the GRA will do the job, easy to set up & & gives you good mixture control......make sure you get someone that has GRA knowlage as there more involved than what the average gas mechanic relizes.
Joe  |
