Best way to amp twin 12s?
timmay_73
PostPosted: Fri May 16, 2008 7:16 pm    Post subject: Best way to amp twin 12s? Reply with quote
Hey all,
Just purchased a crappy set of twin 12's icon_biggrin.gif and wondering how I should amp them...
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=180240800039
Obviously I'm not going for a really good set up. Just thought these were better than twin US audio subs for $150... Anyways, Everybody seems to have different opinions on how to amp them, some say I can use a 2 channel amp, others say I couldn't do it without a monoblock. So I thought I'd lay my trust in 'fordmod'ers icon_wink.gif
So what kind of amp can I use/should use?? icon_smile.gif
jonathon
Donating Member
PostPosted: Fri May 16, 2008 7:39 pm    Post subject: Reply with quote
i am running 2 12"clrion subs and a clarion 400w amp run power from battery to amp, earth from amp to near earth in boot, run the rca leade from amp th head unit, and run the rem(the little wire that tells the amp to turn on)from amp to head unit and some decent twin flex cable from amp to sub this is done twice once for each channel on ampand of course positive to positive , negative to negative
DARTHVADER
Donating Member
PostPosted: Fri May 16, 2008 7:41 pm    Post subject: Reply with quote
Hey Mate, hows it goin. Its obvious your not going for an install to please an audiofile.If it was my install id just get a Good quality 2 CH brand name amp with plenty of punch. Feed a mono signal into both channels and strap it down. icon_biggrin.gif
Thats my 2 cents, But each to their own.
DARTHVADER
Donating Member
PostPosted: Fri May 16, 2008 7:46 pm    Post subject: Reply with quote
Oh and dont forget to put a fuse on the POSITIVE (+) power lead to the amp. It should be as close as possible to the battery (within 30cm if u can manage it) icon_biggrin.gif
Just in case the cable rubs through on the fire wall or something, the fuseable link will give out first and not burn you pride and joy to the ground.
Yes it happens!!!
howsie
PostPosted: Fri May 16, 2008 7:50 pm    Post subject: Reply with quote
cheapest way out is to get a 4ch amp with low pass filter on the amp get rca splitters to run the rca cable to all channels.
My mate wen't the 2ch and monoblock options before and they absoultely suck (unless you spend decent money)
In my opinion monoblocks should not be run unless you have one for each sub
ge2589
PostPosted: Fri May 16, 2008 7:54 pm    Post subject: Reply with quote
on my set up i have a ten on the shelf and a 12 in the boot both running off a 800 watt mono its pretty easy cause if i need to take the 12 out to put other stuff in i just unplug it
timmay_73
PostPosted: Fri May 16, 2008 7:57 pm    Post subject: Reply with quote
Ohhhh wait I think I was misunderstood... I know how to wire it all up. I just wanted to know what type of amp to use... Can I use a 2 channel, or do I need to use a monoblock?
jonathon
Donating Member
PostPosted: Fri May 16, 2008 8:08 pm    Post subject: Reply with quote
i used a 2 channel 400w on my setup all depends on what wattage the subs are
dave0
PostPosted: Fri May 16, 2008 8:46 pm    Post subject: Reply with quote
dude mono blocks are the best there designed just for subs what more could you want when running subs. i have 2 type r 12's running off one alpine mono block and they absolutly shake the s**t out of my mont.
it all depends on the brand and the wattage the amp sends out
timmay_73
PostPosted: Fri May 16, 2008 9:11 pm    Post subject: Reply with quote
Thanks heaps for all the ideas icon_smile.gif Alright, lets see if I actually get it before I go blow some cash, so theoretically I could run EITHER:
A monoblock running both subs - Both subs from the one output;
A 2 channel amp - running one sub of each channel;
A 4 channel amp - using "RCA splitters" and somehow connecting the 2 subs, I assume by bridging the 4 channel to 2??
ge2589
PostPosted: Fri May 16, 2008 9:39 pm    Post subject: Reply with quote
oh my bad id go the mono for real thump
1965tbird
PostPosted: Fri May 16, 2008 10:01 pm    Post subject: Reply with quote
mate just shop around i started with a 2ch with a low pass filter on it so you flick the switch and away you go, but i did find the monoblock which i have now to be 10x better. But then again my sub cant handle my amp atm so just make sure you dont go over kill.
Good Luck!
howsie
PostPosted: Sat May 17, 2008 11:39 pm    Post subject: Reply with quote
and make sure you check nominal figures not peak power a 1500watt peak amp may only be rated for 50watt rated power, while a 800 watt peak amp may have 60 watt rated power
howsie
PostPosted: Sat May 17, 2008 11:41 pm    Post subject: Reply with quote
i have only heard my mates car with a monoblock so i'll take your word for it. Who knows his amp may be way underpowered.
data_mine
PostPosted: Sun May 18, 2008 2:02 am    Post subject: Reply with quote
Go a four channel amp, that way if you decide to upgrade in the future, you can get a monoblock to run the subs, and you'll have a 4ch to do the other speakers.
Giving those subs 1000W+ of power is a waste, you'll kill them.
[42 queries :: 0.05051 seconds ]
