Age:27 Posts: 4687 Joined: 24 Nov 2004 Location: Canberra ACT, Australia
Posted: Fri Jun 06, 2008 1:02 am Post subject: |
You'll need either:
- an amp with high level inputs (just hook up the speaker wires into the amp)
- line converters (converts the speaker wires into RCA connections, then you can use any amp)
- modded ICC with RCA outputs (then use any amp)
(1 and 2 are the easiest options).
Then run power to the amp, speaker wire back to the doors, and add a boxed sub.
Easy. |
