Blinkers wont work
XCH45R
PostPosted: Sat Jan 22, 2005 8:35 am    Post subject: Blinkers wont work Reply with quote
After a big storm yesterday now the blinkers in my ZH wont work.. any ideas? they work "sometimes" but not all the time lols
bowsaw
PostPosted: Sat Jan 22, 2005 8:53 am    Post subject: Reply with quote
Earths???
gilesie
PostPosted: Sat Jan 22, 2005 8:17 pm    Post subject: Reply with quote
When I brought my old ZH (many moons ago) only one brake light worked.
So when I got the car home I started looking , only to find that all the connections had corroded, the solution to the problem was to put XB lamp holders in.
smoke_
PostPosted: Mon Jan 24, 2005 9:42 pm    Post subject: Reply with quote
flasher unit?
XCH45R
PostPosted: Tue Jan 25, 2005 7:15 am    Post subject: Reply with quote
whats the flasher unit..? they sometimes work, depending on whether they want to or not.. The stick feels a bit loose? maybe thats the problem too, its like as if its not making a good connection,...
smoke_
PostPosted: Tue Jan 25, 2005 6:45 pm    Post subject: Reply with quote
if the stick is really loose, that can be the problem, the flasher unit is the thing that goes tick tick tick when you indicate.
XCH45R
PostPosted: Tue Jan 25, 2005 6:56 pm    Post subject: Reply with quote
ah k, so what is the first thing I should look for??
smoke_
PostPosted: Tue Jan 25, 2005 7:02 pm    Post subject: Reply with quote
well if it goes tick tick tick, the flasher unit could be intermittent, if the stick is loose, wiggle it around and see if it works/dosent work in certain positions, these are the 2 easiest things to do, the next thing is the hazard switch, the indicators work off the hazard switch in some cars, so check it out also.
gilesie
PostPosted: Wed Jan 26, 2005 5:45 am    Post subject: Reply with quote
With my experiance as an electrician, I would probably start with the fuse.
XCH45R
PostPosted: Wed Jan 26, 2005 8:08 am    Post subject: Reply with quote
preety sure its the flasher unit, its all crushed and stuff.. why? I have no idea.. someone has mauled it.. lol another thing, blinkers work untill i put my foot on the brake.. figure that one..
XGPANELVAN
PostPosted: Wed Jan 26, 2005 2:30 pm    Post subject: Reply with quote
mayb u need to change ur blinkerfluid ... How to change your blinker fluid
smoke_
PostPosted: Wed Jan 26, 2005 4:06 pm    Post subject: Reply with quote
now it sounds like a short between the brake light wirign and indicator wiring.
For the price, just replace the flasher unit they're not that dear.
XCH45R
PostPosted: Wed Jan 26, 2005 6:22 pm    Post subject: Reply with quote
smoke_rubber: I got a flasher unit today.. Yet to fit it though..
GTFORDMAN
PostPosted: Thu Jan 27, 2005 2:15 pm    Post subject: Reply with quote
if the flasher unit is not to blame, then id go and check my earth connections, that was my problem a few times.
Ps, thats a nice blue Fairlane in your sig, Photoshop?
PostPosted: Thu Jan 27, 2005 2:25 pm    Post subject: Reply with quote
Errrr... what exactly are they doing in that blinker fluid doco? lol
XCH45R
PostPosted: Fri Jan 28, 2005 9:39 am    Post subject: Reply with quote
now the car wont start, I think i got an earth problem..
Timmeh
PostPosted: Fri Jan 28, 2005 9:47 am    Post subject: Reply with quote
Check all fuses. I had that problem the other day becasue I was mucking around with the blinker relay and fuses. A fuse may have just dislodged itself. Check ignition fuse and starter fuse.
Electrical stuff can be so annoying.
gilesie
PostPosted: Fri Jan 28, 2005 6:17 pm    Post subject: Reply with quote
SCRAP IT
smoke_
PostPosted: Fri Jan 28, 2005 6:49 pm    Post subject: Reply with quote
wont start at all, does it click but not wind, or does it do nothing?
XCH45R
PostPosted: Sat Jan 29, 2005 9:29 am    Post subject: Reply with quote
it just winds over, but really slowly, no clicking or anything.. I jump started it took it home, went to turn it over an hour later, just wound over really slowly, and got slower..
Im thinking the blinker problem is the flasher unit and a short at the tail lights, Might try to clean the earth wire up a bit??
Can't see why she is draining the battery now though.. Could it be the short??
[47 queries :: 0.04601 seconds ]
