drazull Fordmods - Getting Side Ways
Age:25 Posts: 780 Joined: 05 Nov 2004 Location: Adelaide SA, Australia
Posted: Fri Feb 04, 2005 12:43 am Post subject: Bonnet swap |
| Quick question: can a 1997 XH XR ute bonnet fit on an 1995 falcon? |
Age:36 Posts: 3202 Joined: 05 Nov 2004 Location: Singleton NSW, Australia
Posted: Fri Feb 04, 2005 11:12 am Post subject: Re: Bonnet swap |
| drazull wrote: | | Quick question: can a 1997 XH XR ute bonnet fit on an 1995 falcon? |
ahh that is an easy one for me, NOPE, sorry it is totally different, basically it is a X series, E series Frankenstein bonnet. |
Happy Moderator
Age:35 Posts: 9946 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Fri Feb 04, 2005 11:27 am Post subject: |
| i thought if you changed the front bumper as well it would... no? |
jeffb Fordmods - Smokin em up
Age:24 Posts: 290 Joined: 05 Nov 2004 Location: Mackay QLD, Australia
Posted: Fri Feb 04, 2005 11:30 am Post subject: |
| No it wont fit, the back of the bonnet is different, but u could put a XH bonnet onto and XF or XG if you changed the front bumper as well.. |
Posted: Fri Feb 04, 2005 11:33 am Post subject: |
| Bummer, I like the bonnet bulge on the XH |
Happy Moderator
Posted: Fri Feb 04, 2005 11:35 am Post subject: |
probably the only thing you could do then is find an EF bonnet and do something yourself (or with a panel beater) and make up an original "bulge" and put that on.
If you do it properly and it looks professional your EF would look sweeet! |
Posted: Fri Feb 04, 2005 11:57 am Post subject: |
| jeffb wrote: | | but u could put a XH bonnet onto and XF or XG if you changed the front bumper as well.. |
It isn't that simple, otherwise you would see heaps of X series with XH fronts, the whole front is different, if you search around you might find the member who it the conversion to a XD, the XH front is more EF than X series, but nearly all panels are XH only. |
Posted: Fri Feb 04, 2005 4:40 pm Post subject: |
Would putting a bulge on a normal bonnet be much to get someone to fabricate?
Is it possible to cut the front half of the XH bonnet and weld it to the windscreen half of an EF bonnet?
What I am asking is where the difference in the bonnets is? Front, sides, rear, or (gulp) all of the above? |
Posted: Fri Feb 04, 2005 5:29 pm Post subject: |
| jeffb wrote: | | No it wont fit, the back of the bonnet is different, but u could put a XH bonnet onto and XF or XG if you changed the front bumper as well.. |
And the front gaurds. I was also under the impression that the radiator support panels are lower too on the XH. But I have seen an XF with an XH front on it.... How did I know it was an XF? Because it was a sedan.. and it looked ordinary |
Posted: Sat Feb 05, 2005 6:25 pm Post subject: |
| Is a EF -EL bonnet a clean swap. |
eebee Fordmods - Smokin em up
Age:38 Posts: 217 Joined: 17 Jan 2005 Location: budgewoi NSW, Australia
Posted: Sat Feb 05, 2005 10:52 pm Post subject: |
| only on the XRs and fairmonts. on gli and futura you would have to change head lights and the bumper. |
djr-xr6 Fordmods Oompa Loompa
Age:26 Posts: 23 Joined: 23 Jan 2005 Location: Bathurst, NSW. NSW, Australia
Posted: Tue Feb 08, 2005 10:42 am Post subject: |
| I have another question on bonnets im looking at changing an ED bonnet to an EB (Much claner lines than ED) would it bolt straight on?? |
Sturmovik Fordmods - Getting Side Ways
Posts: 725 Joined: 07 Feb 2005 Location: Canberra ACT, Australia
Posted: Tue Feb 08, 2005 11:10 am Post subject: |
| djr-xr6 wrote: | | I have another question on bonnets im looking at changing an ED bonnet to an EB (Much claner lines than ED) would it bolt straight on?? |
What do you mean cleaner lines? EB-ED bonnets are exactly the same, only difference is the grill. |
Age:22 Posts: 2432 Joined: 05 Nov 2004 Location: Manjimup WA, Australia
Posted: Tue Feb 08, 2005 11:11 am Post subject: |
| I thought the bonnets were the same? The grille will bolt up, but you need some spacers. So i guess the bonnets are different. But not sure how much of the profile is |
| As for an XH front, the inner front guards are different too, so they'd have to be changed also (what fun) |
Posted: Tue Feb 08, 2005 11:24 am Post subject: |
| Sturmovik wrote: | | djr-xr6 wrote: | | I have another question on bonnets im looking at changing an ED bonnet to an EB (Much claner lines than ED) would it bolt straight on?? |
The EB grill looks much better than ED. |
