Boost mileage with HHO gas
Goto page 1, 2, 3 ... 16, 17, 18  Next
garthr
PostPosted: Sun Dec 30, 2007 9:20 am    Post subject: Boost mileage with HHO gas Reply with quote
Has anybody thought about building one of these? - would be interesting to know some first hand results.
http://waterpoweredcar.com/hydrobooster2.html
Timmeh
PostPosted: Sun Dec 30, 2007 10:18 am    Post subject: Reply with quote
I'm too afraid the oil companies will send a hitman to my house if I use that.
relaxed_diplomacy
PostPosted: Sun Dec 30, 2007 11:59 am    Post subject: Re: Boost mileage with HHO gas Reply with quote
There is always inefficiency in converting one form of energy to another. The energy expended by the vehicle's electrical system is greater than the hydrogen energy derived.
garthr
PostPosted: Mon Dec 31, 2007 5:08 am    Post subject: Reply with quote
if u read the info they are not using bulk electricity to do the conversion (as in straight water would require) - they are using an electrolyte solution to minimise the amps.
My question was - has anyone got 1st hand experience with something like this?
relaxed_diplomacy
PostPosted: Wed Jan 02, 2008 9:57 am    Post subject: Reply with quote
Are you saying they create "electrolyte solution" at home and regularly put it into the car? If so i didn't notice them saying so on the website.
Rick's EF Fairmont Wagon
PostPosted: Wed Jan 02, 2008 10:45 am    Post subject: Reply with quote
It kind of sounds like they run the fuel through the device then into the engine. The device releases hydrogen from the petrol to help lower fuel consumption? I need to read into it more.
PostPosted: Wed Jan 02, 2008 11:07 am    Post subject: Reply with quote
I was wrong, It seems that you add hyrogen and oxygen from the electrolyser into the intake and the ecu leans out the injectors. The question is of course. with you burn out the pistons due to too low a fuel mixture? Or does it give you enough feul with the addition of the gas?
PostPosted: Wed Jan 02, 2008 11:13 am    Post subject: Reply with quote
It's worth a try if someone wants to donate a boxcar for the project....LOL
-GAS-MAN-
PostPosted: Wed Jan 02, 2008 8:47 pm    Post subject: Reply with quote
You need the adjustable LED circuit to adjust the mixture, this also displays the mixture on the LED readout. Interesting! If i saw the results in person and they were good, i would buy one, but until then... :'(
garthr
PostPosted: Wed Jan 02, 2008 10:18 pm    Post subject: Reply with quote
seems like this one is using 1- 3% KOH (potassium hydroxide) as the electrolyte but only for initial fill after that u just add water every time until it has to be cleaned out.
other setups use baking soda - 1 tsp per litre, some use caustic soda.
anyone know what KOH is sold as in australia?
-GAS-MAN-
PostPosted: Thu Jan 03, 2008 12:54 pm    Post subject: Reply with quote
Did anyone watch the videos on the guy who made his car run enirely on water, off a cell taking 1 amp?
My grandpa told me since i was 12 about him, how he was killed and his plans destroyed..
Same about the guy who invented a way to wirelessly transport electricity
*pop* *burn* problem solved, damn governments, how long do they honestly believe oil companies can last, they will destroy our earth and for what, they own like 80% of other free energy patents, plus they are so rich they could diverisfy immensely!
Our economy would change drastically, but so much for the better in every single way imaginable!
PostPosted: Thu Jan 03, 2008 1:13 pm    Post subject: Reply with quote
Shell and BP both now make solar panels.... you think they are getting the idea that they need to diversify their business away from fossil fuels. Mobil is in trouble and has moved to Bangkok to try and save costs.... (hide)
garthr
PostPosted: Sat Jan 05, 2008 6:02 am    Post subject: Reply with quote
Since no one seems to have any first hand knowledge of this, i threw something together to do some tests. Have virtually copied the one from the "water4gas" site.
It is basically a nescafe jar with electrodes mounted through the lid. Electrodes are just stainless welding wire, doubled over and wound around a plastic core.
Used baking soda for electrolyte cos that's what i had handy.
Have installed it in my hilux ute for testing (it's carburettored)
Does produce gas.
Just have to do some miles now to get some real results.
PostPosted: Sat Jan 05, 2008 7:36 pm    Post subject: Reply with quote
that's great Garth I will look forward to your results.
hans hartman
PostPosted: Sat Jan 05, 2008 7:47 pm    Post subject: Reply with quote
need the cash to pay fwits in act,super-------need a jumbo wheel barrow.
foggy
PostPosted: Sun Jan 06, 2008 9:17 am    Post subject: Reply with quote
Hey Garthr,
Just a quick suggestion with that setup on the hilux take it for a warm up run then see if you can lean out the mixture a bit on the carb. the downside of this (I think) is the it will be running a little lean at startup until you Hydro cell comes on line but it should make a difference while doing distance work.
Have fun
Foggy
garthr
PostPosted: Sun Jan 06, 2008 2:52 pm    Post subject: Reply with quote
yeah foggy, i will keep it in mind as one of several things i might be able to do. for now i just want to see what difference is with same setup. then things like advance timing to take advantage of higher octane rating of the gas, also would like to put a valve in line to restrict gas flow at idle and open up at higher revs (the opposite of what is happening now) - all depends on how effective my cell is.
Has made some difference though, exhaust has gone really quiet which would indicate the burn is very smooth compared to straight petrol.
foggy
PostPosted: Sun Jan 06, 2008 5:31 pm    Post subject: Reply with quote
Just another couple of quick questions has it made any difference to the running temperature of the car and any idea how many amps this thing is pulling??
Good luck
garthr
PostPosted: Mon Jan 07, 2008 4:50 am    Post subject: Reply with quote
haven't noticed any real difference in temp, - still just gets to thermostat temp.
i have it running on 6 amps.
cell temp after driving was 52 degrees (ambient of 23 though, overcast)
Whiteknight1
PostPosted: Mon Jan 07, 2008 5:46 am    Post subject: Reply with quote
Yea I've read a few articles on a guy called Stan Meyer from USA who ran cars off tap water, apparently it took huge electricity to extract hydrogen from water, and this guy nutted it out, and got it working, then was found dead in his home icon_sad.gif.
If it was an oil company keeping him quiet, then this place is fked.
Page 1 of 18
[47 queries :: 0.05867 seconds ]
