Boxing Pod Filter (The simple way)
Goto page Previous  1, 2, 3, 4, 5, 6
Falcon Powa
PostPosted: Tue May 13, 2008 8:26 pm    Post subject: Reply with quote
yeh i been reading dam!!! o well u think it be better then the stock el one? just for now i can buy one later.....
huggiebear
View User Gallery (28)
PostPosted: Tue May 13, 2008 8:27 pm    Post subject: Reply with quote
im not sure what size the stock EL ones are. i went stright to the tickford one when i put my EL motor in
Falcon Powa
PostPosted: Tue May 13, 2008 8:29 pm    Post subject: Reply with quote
ah ok well so if i head to ford dealer in town and ask for a Tickford snorkel for EL reckon they know wat im talkin bout? but ill install this one for now cause my other one is cracked a bit...
huggiebear
PostPosted: Tue May 13, 2008 8:32 pm    Post subject: Reply with quote
try and find a EF/EL GT snorkel. i used to have one. they are huge
Falcon Powa
PostPosted: Tue May 13, 2008 8:36 pm    Post subject: Reply with quote
ok sweet ill try find 1. also purchased a 3A racing filter. are they the same installation as the post before in this topic?
lukey
PostPosted: Tue May 13, 2008 9:27 pm    Post subject: Reply with quote
They'd be same installation.
I thought EL GT snorkels are same size as AU XR8 snorkels?
Falcon Powa
PostPosted: Wed May 14, 2008 9:09 pm    Post subject: Reply with quote
been looking at my filter looks like i mite need some type of pipe or hose to connect the filter..... i got some pics i took today on my phone plus at nite with touch not that clear ill take some better ones tommorow at day since i got day off.......
Falcon Powa
PostPosted: Thu May 15, 2008 7:39 pm    Post subject: Reply with quote
ok fellas just finish with my filter in my el falcon. hears wat ive done it was a quite of a hard job connecting the bottom of the pod with the top but ended all ok..... heres wat it looks like from the inside .............
any tips for wat i should do to improve this setup just mention them please
also was able to fit that BA snorkel in for now with one screw holding it on ill have to drill a hole later to fix this buts ok at the monment.....
udbdevo
PostPosted: Tue Aug 05, 2008 6:40 pm    Post subject: Reply with quote
need sum help with mine...tryed to tackle it on the weekend and failed
i cut the hose and fitted the pod to see that the outside clip ( square thing) was not lined up with the ones on the box.
after sussing it out further it seems that my pod is hitting the top of the airbox so their is no way it will fit properly. atm i have the pod sitting on the house with only a hose clamp and not screwed in.
also the intake going to the throttle body had to be unbolted becuase the outside screws dont line up on the outside the throttle body intake pipe does not line up either.
so pretty much it is all on 2gether except it is not 100% gap free and it is only being held on my hose clamps.
i was thinking of fitting the pod over the pipe in the box and then cutting the airbox to fit over the top of the intake pipe(going intot he airbox),.,,if that makes sense
so their would be a 5-10mm gap around the intake to the airbox...
thoughts>
huggiebear
PostPosted: Tue Aug 05, 2008 6:59 pm    Post subject: Reply with quote
i think you need to take pics.. i cant visualise it
EL__Fairmont
PostPosted: Tue Aug 05, 2008 7:44 pm    Post subject: Reply with quote
thoughts>
You could just buy a 3in 45degree storm water bend from Bunnings for $2.50 and epoxy glue it into the back of the lid. Then put your pod on the end of that.
Like this;
Page 6 of 6
[38 queries :: 0.04071 seconds ]
