mitch7700 Fordmods Newbie
Age:19 Posts: 5 Joined: 24 Oct 2007 Location: Perth WA, Australia
Posted: Sat Oct 27, 2007 3:41 pm Post subject: |
| I'v heard that if you replace a panel filter with a pod filter u need to get your computer retuned/remaped because of the extra air flow, i had a mate who did this and it stuffed his ecu up resulting in his engine not starting or doing anything |
phongus Fordmods Junkie
Age:22 Posts: 8300 Joined: 17 May 2005 Location: Melbourne VIC, Australia
Posted: Sat Oct 27, 2007 3:47 pm Post subject: |
| mitch7700 wrote: | | I'v heard that if you replace a panel filter with a pod filter u need to get your computer retuned/remaped because of the extra air flow, i had a mate who did this and it stuffed his ecu up resulting in his engine not starting or doing anything |
You don't need or have to retune/remap the ECU. Maybe in jap cars where they have an airflow meter.
phong =P~ |
Posts: 2889 Joined: 31 Oct 2005 Location: . QLD, Australia
View User Gallery (28)
Posted: Sat Oct 27, 2007 4:15 pm Post subject: |
| yeah i think your mate done something else stupid to his motor.. as ford computers actually relearn them selves... hense why people reset their computers before a long trip.. gives you better fuel ecconemy if your a hoon driver. |
Posted: Sat Oct 27, 2007 4:19 pm Post subject: |
So what does resetting your computer actually do, and is it worth doing, ifso how do you do it
THANKSmate |
Posted: Sat Oct 27, 2007 4:23 pm Post subject: |
resetting it just puts it back to factory specs..
see as the computers relearn if you plant your foot like a hoon it will adapt to how you drive and give it a bit more fuel then normal, but if your a grandma driver if will lean it out as you dont use the power..
resetting it just makes it reset back to normal fuel etc.. then it will adapt to how you drive.
to reset your computer just disconnect your battery for about 30 minutes. some people say 15 others say 30 or 45 minutes. then reconnect and it will run weird for a second then slowly smoothen out. dont rev hard otherwise it will learn to dump fuel. let it idle for about 15 minutes.
i think there is a thread or technical document on it |
Posted: Sat Oct 27, 2007 4:25 pm Post subject: |
| mitch7700 wrote: | So what does resetting your computer actually do, and is it worth doing, ifso how do you do it
THANKSmate |
The ECU will reset, putting everything back to basically "zero". The computer starts from scratch and learns everything all over again. It removes "bad habits" it learned prior the reset. It's like formatting your computer and putting all the programs back in and the computer runs smooth and much better then with all the junk.
To reset the ECU, you will need to remove the negative terminal of the battery and let it sit there for about 15mins...or if you really want...undo the negative at night, go to bed and then plug it back in.
You will find, when you start the car after a reset, that it will idle rough. Don't rev the engine or else it will start learning bad habits again.
phong =P~ |
Posted: Sat Oct 27, 2007 4:27 pm Post subject: |
| haha basically the same thing but phong said it in a neater way... i sat there trying to work out a good way of putting it |
Posted: Sat Oct 27, 2007 4:34 pm Post subject: |
thanks for your help, u guys seem to know what your talking about, i'v just bought a 1998 EL ford falcon GLI 4litre and i was woundering if there is any advice you can give me about this model my main plans for the car it to crank up the power.
thanks |
Posted: Sat Oct 27, 2007 4:36 pm Post subject: |
| have a look through the forums there is a heap of info on what you can do to them, either turbo it or if you dont want forced induction, tickford head, cam, extractors etc... |
02tonna Fordmods Parts Gopher
Age:22 Posts: 61 Joined: 06 Nov 2007 Location: Perth WA, Australia
Posted: Sat Nov 10, 2007 2:58 pm Post subject: |
| would there be much diff from a k&n pod filter to a k&n pan filter??? ive put a k&n pan in mine with a larger snorkle and cant tell the diff.. its a ba 6cyl manual |
Age:19 Posts: 961 Joined: 27 Mar 2006 Location: Brisbane QLD, Australia
Posted: Sat Nov 10, 2007 4:27 pm Post subject: |
| 02tonna wrote: | | would there be much diff from a k&n pod filter to a k&n pan filter??? ive put a k&n pan in mine with a larger snorkle and cant tell the diff.. its a ba 6cyl manual |
no. that's because your stock filter was probably still relatively clean, therefore there wasn't much gain. You won't tell the difference between a k&n pod or panel |
Posted: Sat Nov 10, 2007 7:02 pm Post subject: |
not really i put it on a week after i bought the car and there were a s**t of flys bee's and mossies in the filter and piled up in the bottom of the box. previous owner was from the bush  |
mystro Fordmods Parts Gopher
Posts: 69 Joined: 14 Oct 2007 Location: newcastle NSW, Australia
Posted: Wed Jan 02, 2008 6:14 pm Post subject: |
i did my pod today i have an el ,i just removd the four bolts from the box flange thingy pulled it out,spun the lid around put the pod directly on the stock pipe screwed the clamp tight spun the lid back around and reclipped the air box easy as no cutting required,unless you want holes in the box
parts needed pod,10mm,flat screwy, 15mins max,and a 15mm spanner if you want to remove the pipes strut mount to make it easier |
EL__Fairmont Fordmods - Getting Side Ways
Posts: 414 Joined: 08 Aug 2006 Location: Central Highlands QLD, Australia
Posted: Fri Jan 25, 2008 1:27 am Post subject: |
| This is a pic of the G&D $600 intake that claims hp improvement. As you can see they found on the dyno the tapered intake pipe and 55mm bellmouth airbox lid adaptor was beneficial over a straight 3in pipe. |
Posted: Fri Jan 25, 2008 2:23 am Post subject: |
3in intake pipe works ok with k&N panel filter
Falcon Powa Fordmods Oompa Loompa
Age:18 Posts: 28 Joined: 02 Apr 2008 Location: Broome WA, Australia
Posted: Thu Apr 17, 2008 7:36 pm Post subject: |
i live in the country and just wanna know wheres the best store or places to buy pod filters, snorkels, air intakes... are the ones on ebay anygood or could i be able to see the local ford dealer?
Cheers |
lukey Technical Contributor
Age:21 Posts: 959 Joined: 08 Nov 2004 Location: Melbourne VIC, Australia
Posted: Fri Apr 18, 2008 2:49 pm Post subject: |
I dunno if local Ford dealers would have pod filters but you can pick up Tickford/GT ect. snorkels from spare parts.
Autobarn / Supercheap / Bursons and all those kind of places will stock K&N and other filter brands as well as SS inductions and similar systems. |
BuNtEr Technical Contributor
Age:41 Posts: 3228 Joined: 12 Feb 2007 Location: your mums NSW, Australia
Posted: Fri Apr 18, 2008 4:12 pm Post subject: |
| Falcon Powa wrote: | i live in the country and just wanna know wheres the best store or places to buy pod filters, snorkels, air intakes... are the ones on ebay anygood or could i be able to see the local ford dealer?
Cheers |
Super cheap, robbos, Peps. |
Posted: Fri Apr 18, 2008 8:51 pm Post subject: |
Only Auto one in town so i could ask them to order it in.... i mite do that next thursday on my day off
Cheers |
