bridging ed falcon air sensor need help!!!
Gavsed
PostPosted: Sat Jan 12, 2008 2:53 pm    Post subject: bridging ed falcon air sensor need help!!! Reply with quote
hi i am trying to find out how to bridge my air sensor on my ed falcol can any 1 help me or give me a site i no it can be done on an el any help would be great thanks
TROYMAN
View User Gallery (30)
PostPosted: Sat Jan 12, 2008 7:27 pm    Post subject: Reply with quote
hi
why do you want to bridge the air charge sensor???
Gavsed
PostPosted: Wed Jan 16, 2008 5:40 pm    Post subject: Reply with quote
hi becuse i hear if you bridge the air sensor the air flow is sent as cold so therefore the car runs a lot better and more performance
mitchg911
Commercial Sponsor
PostPosted: Wed Jan 16, 2008 6:27 pm    Post subject: Reply with quote
haha.. if the intake air sensor is reading cold the ecu will make the engine run richer... at $1.50/L why would you want that?
Gavsed
PostPosted: Fri Jan 18, 2008 6:10 pm    Post subject: ideas Reply with quote
because i dont have a problem with payin that now does any 1 hav any ideas ???
TROYMAN
PostPosted: Fri Jan 18, 2008 6:34 pm    Post subject: Reply with quote
there is a resistor that sells on ebay that does something similar..
but as the ecu has a learning peramiter so the resister will only temperaraly work as once the hego sensor senses the over rich mixture the ecu will adjust the fuel ratio to try to lean it back out..
i think if you were to just short it out it would put the ecu into limp home mode.
or possably wont start or idle as the ecu needs a specific load return to give it a reading .
if you just short it out the load returned to the ecu wont be within the specified voltage and it will give out fault codes as a air charge failiure..
and afaik the air charge sensor and hego are in-operative at wide open throttle. i think its closed loop mode? so on full throttle the ecu has a factory setting so if it does run it wont do anything at full throttle..
therefore a waste of time!
also the sensor on ed is the same as the el one..
mitchg911
Commercial Sponsor
PostPosted: Sat Jan 19, 2008 10:03 am    Post subject: Re: ideas Reply with quote
its not gonna make more power running rich.
[34 queries :: 0.03154 seconds ]
