building a 5ltr
xr8 dismantler
Commercial Sponsor
PostPosted: Sun Jan 23, 2005 9:40 pm    Post subject: building a 5ltr Reply with quote
im looking at building a 5ltr or a stroker for my sierra XR8
want something tuff , i have a AU 5ltr motor in bits any ideas on a good combo ??
it will be EFI with a autronic ECU and a T5G gearbox
MrLandau
Commercial Sponsor
PostPosted: Sun Jan 23, 2005 9:45 pm    Post subject: Reply with quote
Want tuff Darren
click the www button and follow the 347 stroker link.
Shane
xr8 dismantler
Commercial Sponsor
PostPosted: Sun Jan 23, 2005 9:59 pm    Post subject: Reply with quote
yeh
looks like you've been busy with the die grinder.
MrLandau
Commercial Sponsor
PostPosted: Sun Jan 23, 2005 10:05 pm    Post subject: Reply with quote
Yeah - there is a fair bit of clearancing required to fit the Eagle competition 347 stroker into a standard roller block. Hopefully - not too far down the track, this will all be retrofitted into a DART block.
How much power are you looking for Darren?
Shane
xr8 dismantler
Commercial Sponsor
PostPosted: Sun Jan 23, 2005 10:12 pm    Post subject: Reply with quote
i would think 500+ hp would be nice
but i dont know if the T5G will handle it. and the grenada diff.
might have to look a bit milder like 350 -400 hp
Disco Frank
PostPosted: Sun Jan 23, 2005 10:51 pm    Post subject: Reply with quote
MrLandau wrote:
Want tuff Darren
Shane
hehe cheeky f**k !
do it man do it!
stuff the grenada in the bin and put ina 9" i am sure u can source all the parts..... icon_smile.gif
comon i want to c that car at nextyrs summernats as the best sleeper around! icon_twisted.gif icon_twisted.gif icon_twisted.gif icon_twisted.gif icon_twisted.gif icon_twisted.gif
MrLandau
Commercial Sponsor
PostPosted: Sun Jan 23, 2005 11:11 pm    Post subject: Reply with quote
500hp is getting close to hand grenade material - even as a 347. There are components that will take it and those that won't. The standard roller block is one of those things that won't.
Shane
Interceptor
PostPosted: Mon Jan 24, 2005 1:37 am    Post subject: Reply with quote
as for the 9", DJR should be able to help you with a 9" carrier for the sierra IRS setup, cos DJR were behind getting the 9" homologated for race use in the late 80's.....
Disco Frank
PostPosted: Mon Jan 24, 2005 8:40 am    Post subject: Reply with quote
it got irs?
i know u can get a 9" carrier for the commondore IRS
Waggin
Site Admin
PostPosted: Mon Jan 24, 2005 9:11 am    Post subject: Reply with quote
Shane
Are there stroker kits which don't require so much clearancing work (or none at all)?
MrLandau
Commercial Sponsor
PostPosted: Mon Jan 24, 2005 9:37 am    Post subject: Reply with quote
No but there are blocks that come clearanced for the stroker cranks - they are called Darts. icon_rolleyes.gif
Shane
EBXR8380
PostPosted: Mon Jan 24, 2005 11:09 am    Post subject: Reply with quote
Mine is 3.25 / 330 Crank in Dart block it still needed clearancing...It depends on what rods and bolts are used..If you are using std block keep h.p under 500 fwhp...
Strength check here...
http://www.turbomustangs.com/techarticles/stockblock.htm
http://ten.ewzone.com/articlefull.asp?aid=1979&sid=42&cat=12
PostPosted: Mon Jan 24, 2005 11:44 am    Post subject: Reply with quote
Actually quite impressive what they take before giving up the ghost. High PSI or high revs.... most those guys getting under 11sec down 400m....
Did you derstroy your block before going to Dart ebxr?
EBXR8380
PostPosted: Mon Jan 24, 2005 11:52 am    Post subject: Reply with quote
No on engine stand in back shed...
I'm Marinising it and its going in a boat...
Turbo of course...
Blew a few head gasgets so to lower comp I built another block..
It was more bad tune as I thought I fitted dissy in same place, obviously not....
Waggin
Site Admin
PostPosted: Mon Jan 24, 2005 11:57 am    Post subject: Reply with quote
I'd be happy with 500RWHP and keeping it under 6000rpm
EBXR8380
PostPosted: Wed Jan 26, 2005 1:23 am    Post subject: Reply with quote
Imo its more abuse and high rpm.. 50 ounce external ballance doesn't help..
There is a way around this now!! Thats to fit the latest stroker kits with Zero ballance but you need different harmonic ballancer and fly wheel.Is that another excuse to stroke ???
Btw I prefere the 330 with 5.4 rod over 347....
Disco Frank
PostPosted: Wed Jan 26, 2005 9:52 am    Post subject: Reply with quote
Turbo of course...
mm heard a few yrs back some of the jet boat guys were buildign ford V8's that could spin to over 10000rpm all day long any truth to this?
MrLandau
Commercial Sponsor
PostPosted: Wed Jan 26, 2005 11:45 am    Post subject: Reply with quote
The guys in the Stock 5.0 class in the states are pulling over 9000rpm - but you are talking grout filled blocks and other trick bits. Most of them are stepping up into Dart blocks.
Shane
EBXR8380
PostPosted: Wed Jan 26, 2005 10:33 pm    Post subject: Reply with quote
Yep but 302 R's and Mexican blocks etc are more common there..They could have also been destroked 351's ?? With 4 bolt mains fitted on there stronger webbing...
[46 queries :: 0.06384 seconds ]
