green car Fordmods - Getting Side Ways
Age:31 Posts: 463 Joined: 27 Sep 2007 Location: perth WA, Australia
Posted: Fri Sep 26, 2008 1:55 pm Post subject: Cam choice for ef |
Im putting a cam in my ef and want to know what rev range the 1636 works in.
People seem to think this is a good cam.
I have extractors,2.5 zorst and cat,3.45 diff, cai, vernier gear.
I want a cam that works with the stock convertor. |
Posts: 3428 Joined: 08 May 2007 Location: Sunny QLD, Australia
Posted: Fri Sep 26, 2008 2:09 pm Post subject: |
| It will suit your mods well, as its a medium rev range cam. Any bigger and you would start looking at a shorter diff ratio, & maybe HD valve springs |
phongus Fordmods Junkie
Age:23 Posts: 8811 Joined: 17 May 2005 Location: Melbourne VIC, Australia
Posted: Fri Sep 26, 2008 2:20 pm Post subject: |
The Wade 1636, from what I have heard, is a decent cam. It will give you power mid range as FordFairmont mentioned up until top. Not sure how big of an improvement.
I have the 1673 cam and the power kicks in at about 2500RPM up until rev limiter. So I would assume the 1636 will do the same thing but just not as much power as the 1673.
phong =P~ |
Posted: Fri Sep 26, 2008 2:44 pm Post subject: |
btw, from what you mentioned in the other thread, you will need an AU cam ground to 1636 specs...... not the actual 1636 cam.
I think its the 1502 or something but you will have to talk to Wade cams for specifics |
Age:19 Posts: 1867 Joined: 30 Oct 2006 Location: Grafton NSW, Australia
Posted: Fri Sep 26, 2008 4:29 pm Post subject: |
| Yeh, min would be the 1673 in the AU version IMHO. I've got the 1673, and its not enough IMO. |
Posted: Fri Sep 26, 2008 4:30 pm Post subject: |
| 1671AU is the AU version of the 1673 just so you know. |
racer Fordmods Stock as a Rock
Age:38 Posts: 104 Joined: 16 Jul 2007 Location: sydney NSW, Australia
Posted: Sat Sep 27, 2008 11:10 am Post subject: |
OK. The 1636 wade cam starts working from 2500rpm but realy kicks in at 3000rpm. Ive reved my engine to 5500rpm. Just got my car dynoed today & made 128 rwkw with 370nm of torque.
Max power at 160kph approx 4700rpm & after that rpm the power flatens out which is good. The dyno operator (Jim at Dart Automotive) said to me that he had a JMM dev 5 el & made on his dyno only 134rwkw. His dyno is not hp/kw friendly. I am very happy with this cam & i drive my car every day to work & back home. Just i last thing below 2500 very ordernary but when it hits 2500-3000 it is like a switch revs & goes like a rocket. |
Posted: Sat Sep 27, 2008 7:10 pm Post subject: |
| If you want a cam with low end power i would suggest the camtech cam stage 1 or the wade 1004-1604 cams. I can't speak for the wade 1004-1604 cams but i had the camtech stage 1 cam. The camtech cam had loads of torque & power low to middrange rpm. |
Posted: Sat Sep 27, 2008 7:21 pm Post subject: |
| racer wrote: | | Just one last thing, below 2500 its very ordinary but when it hits 2500-3000 it is like a switch revs & goes like a rocket. |
you will find when compared to the larger Wade cams, the 1636 feels like it has heaps of grunt below 2500rpm. |
Posted: Sun Sep 28, 2008 11:17 am Post subject: |
Thats what i needed to hear, thanks for all the helpful replies.
I have only dealt with crossflow cams in the past and i know how crap a motor feels if the cam is too big for the convertor, this is the primary reason for wanting a small cam.
I just wanted to find out where some of these wade cams come in because the specs between crow and wade are different and wade dont advertise a working rev range(helps to make a choice if you know what revs the cam works in)
Anyways thanks again and ill probably be looking at a reasonably small sized cam until i get a stall(it is the missus work car haha)  |
Posted: Sun Sep 28, 2008 11:39 am Post subject: |
| Sorry my bad. It was a DEV 4 complete kit NOT a DEV 5 that got dynoed. |
