panther69 Fordmods Newbie
Posts: 6 Joined: 11 Jul 2008 Location: Melbourne VIC, Australia
Posted: Fri Jul 11, 2008 4:55 pm Post subject: changing a T-5 from cable to hydrulic |
| Is it possible to change a T-5 from cable clutch to hydrulic clutch? if so, how? |
Krytox Technical Contributor
Age:29 Posts: 2504 Joined: 20 Mar 2005 Location: Seaford State: VIC, Australia
Posted: Fri Jul 11, 2008 5:51 pm Post subject: |
Would help if you specified what car!
X series, there are conversion kits.
EF/EL:
Yes it is possible, but not cheaply.
Considering the cable setup is 'pull' and hydraulic is push.
You'll have to modify the bell housing and clutch fork, as in welding fabricating or even replacing.
Then theres the clutch pedal, (less work) but its all R&D home made mods are required.
There is no quick 2hour slap on install to do so. |
jamesy3 Fordmods Newbie
Age:25 Posts: 7 Joined: 04 Feb 2005 Location: Kingaroy QLD, Australia
Posted: Mon Jul 28, 2008 9:15 pm Post subject: |
| Don't spose you could shed some light on where I might find a conversion kit for an xf? I'm putting a tremec 5 spd from an au into my xf and have been told the au's had hydraulic clutches so I'll need to convert the xf to suit it. |
OBS35N Fordmods - Getting Side Ways
Age:27 Posts: 1205 Joined: 06 Nov 2004 Location: Brisbane QLD, Australia
Posted: Mon Jul 28, 2008 9:29 pm Post subject: |
| didnt mal wood do a hydraulic clutch conversion? |
[32 queries :: 0.02748 seconds ]
