phatba Fordmods Stock as a Rock
Age:28 Posts: 119 Joined: 30 Sep 2007 Location: perth WA, Australia
Posted: Tue May 13, 2008 2:23 am Post subject: changing ba interior |
hey guys, i have a ba xt, and am looking at putting in higher series ba seats and door trims. if i get seats with electric memory, is it hard to connect that up? (dont really mind if i use it or not but if its easy then why not) also i only have front power windows. is it possible to change the arm rest to suit the non power, and drill holes for the winders? or would i be better off to put in rear power windows? also if the seats come out of a crashed car can the side plastic trims be replaced? usually they crack in an accident. and if the side airbag has deployed, can it just be stuffed back in and the seam re stitched? my car doesnt have side air bags so doubt they would be able to be used anyway.
thanx all for your suggestions |
Nicko Moderator
Posts: 10711 Joined: 05 Nov 2004 Location: SE Melb VIC, Australia
Posted: Tue May 13, 2008 9:25 am Post subject: Re: changing ba interior |
| phatba wrote: | hey guys, i have a ba xt, and am looking at putting in higher series ba seats and door trims. if i get seats with electric memory, is it hard to connect that up? (dont really mind if i use it or not but if its easy then why not) also i only have front power windows. is it possible to change the arm rest to suit the non power, and drill holes for the winders? or would i be better off to put in rear power windows? also if the seats come out of a crashed car can the side plastic trims be replaced? usually they crack in an accident. and if the side airbag has deployed, can it just be stuffed back in and the seam re stitched? my car doesnt have side air bags so doubt they would be able to be used anyway.
Depends if you want to do it properly!!
If you want the mmemory function to work you willneed to get the body loom, dash loom and mirrors.
Have a look for a thread by lukeyson as he is currently doing this to his xr8
Its in the interior modifications forum |
Posted: Tue May 13, 2008 12:33 pm Post subject: |
| ok but the seats can go in with no problems for now until i get time to do the wiring and stuff? |
Nicko Moderator
Posted: Tue May 13, 2008 9:34 pm Post subject: |
yes
but you need power to adjust the seats! |
[32 queries :: 0.03324 seconds ]
