Cheers guys no more help needed
Big Kev
PostPosted: Mon Nov 15, 2004 6:33 am    Post subject: Cheers guys no more help needed Reply with quote
Hi guys,
Just wanting to ask for opinions on what people think would need to be done to a 96 EFII XR6 to beat a BAMKI/II XR6 Turbo on acceleration.
Im looking at a decent twin turbo setupand the rest.
Cheers for any help.
Thanks
Kev
1 SLY 97EL
PostPosted: Mon Nov 15, 2004 8:00 am    Post subject: Reply with quote
The phrase
"Horsepower=Dollars, so how much money do ya want to spend?" comes to mind.
ALPz
PostPosted: Mon Nov 15, 2004 8:08 am    Post subject: Reply with quote
y even go twin ? why not one big single turbo setup ?
i got a price from Bresciani Racing,
for about $7,500 it included
pipes
GT3540
mirctech LT12 fitted
intercooler
they said they had already done this to an xr and it turned out really good, and sounded awesome with about 200rwkw.
you can contact them if you want, PH: (03) 93052198
they have the fasted vl turbo in aus, i think its no. plates is [PANNIC]
Big Kev
PostPosted: Mon Nov 15, 2004 9:52 am    Post subject: Reply with quote
Pannic yeah I thin of seen that VL icon_lol.gif got alot of go.
Yeah im aiming to try and get 280rwkw but would be happy with 250rwkw.
Looking at spending 15K all up for engine mods, turbo setup, intakes and exhaust etc.
Thanks for the info and oh yeah i was meant to add to the orignal post big single turbo setup OR twin turbo but the twins I know are alot of a*** around to get going.
Rapier
View User Gallery (33)
PostPosted: Mon Nov 15, 2004 11:24 am    Post subject: Reply with quote
i rekon you would have no probs if you wanna spend that much u may be able to crack 300rwkw with 15k
tjb45
PostPosted: Mon Nov 15, 2004 11:51 am    Post subject: Reply with quote
To give you an Idea, I've just about finished my EF II turbo project, I've spent about $4000 at the moment, that includes turbo, manifold, waste gate, blow off, Fuel pressor regulator, oil lines, front mount intercooler, 3" exhaust, intercooler piping, turbo timer, and boost gauge. I’ve still got to do something about the timing as it needs a little retarding at high RPM, but it is fuelling good.
I’m only running between 6-7 PSI until I get the timing worked out. I’ve done a few 0-100 times and got between 6 – 6 ½ seconds and that wasn’t at full throttle. Also its an auto.
I read that the XR6 turbo manuals do around 6 ½ second 0-100 so I should be close to them.
Good luck.
Smackdown
PostPosted: Mon Nov 15, 2004 11:59 am    Post subject: Reply with quote
Why would you be looking at a twin turbo for an I6? just get the biggest turbo you can find! When doing up rice burners, people normally pull out the twin turbo setup and replace it with one big one. My guess would be that you'dbe better off doin that too. Both for cost and performance.
Big Kev
PostPosted: Mon Nov 15, 2004 12:30 pm    Post subject: Reply with quote
Cheers for the help guys yeah the GT40 ball bearing turbo sounds like a good go. Meant to be able to run 900 horses.....i only want the setup to run 10-12psi.
Thanks for all the assistance
Smackdown
PostPosted: Tue Nov 16, 2004 11:37 am    Post subject: Reply with quote
Lol, why is it that everyone who wants a turbo is always really young? For about half the price, you can easily get your car into the low 14s. If its that blow off sound that you're really after, i can hook up some speakers to your clutch to make a nice pettttteeechhhhh sound for you if you want.
don't get me wrong, turbo I6s are f**k awesome but you might wanna do other stuff to it first.
There's always a cynical post isn't their? Sorry but it had to be me, I wanted a turbo for mine too until i realised how much it would be and what the potential of the 4L was without forced aspiration.
Anyway, if you do it, that thing will fly.
Big Kev
PostPosted: Tue Nov 16, 2004 12:43 pm    Post subject: Reply with quote
Nah well alot more will happen then just a turbo.....will be the works.....im droppin an AUIII VCT engine (could get the 8 if I want apparently- might go the whole way and fit the one from a TS50), Manual Conversion, port work, headers, exhaust, chip, turbo brakes, full rebuild on the AU engine....and lots more
but thanks again for the input guys
twr7cx
PostPosted: Tue Nov 16, 2004 2:41 pm    Post subject: Reply with quote
As far as I know that Gas Research Australia company has a turbo division that has an 4.0L I6 Turbo kit for around the 5 grand mark...
markrowe1
PostPosted: Tue Nov 16, 2004 3:15 pm    Post subject: Reply with quote
yes they do it is TSA which is part of gas research
last time i looked they had a kit 5 possibly 6 grand it was non intercooled and running 5 or 6 psi i think they also had intercooled kits for a bit more
ohh i dont think they had new fuel management with them kits either. just a rising rate regulator (could be wrong though)
try this
http://www.gasresearchpc.com.au/html/turbo_systems_australia.html
Fairmont99
PostPosted: Tue Nov 16, 2004 3:22 pm    Post subject: Reply with quote
EACRUISER
View User Gallery (20)
PostPosted: Mon Nov 29, 2004 10:02 am    Post subject: Reply with quote
The thing is that a single turbo setup is more prone to lag, this greatly reduces power until further up in the rev range. high kilowattts.
A properly setup twin turbo system will always make more bottom end torque.
It depends on what you are after.
A large single turbo is the go if you want a car that drives like a pig down low then comes on hard latter in the rev range until you redline, and makes high KW numbers to impress your friends. Although you will be revving the hell out of the engine to make your power and sucking the juice down.
But a Twin-Turbo setup is the go if you want a car that has a lot of torque down low and still has the topend go to match. just doesn't have the sky-rocketting KW figures, i do like the torque figures though..
Remembering that torque equals acceleration. (or tyre-frying ability) depending on how heavy your foot is.
Personally i prefer the twin-turbo setup as it is more user friendly, you just have power every where, no matter where the needle is you plant your foot and go.
I have driven a Single Turbo Toyota Soarer and a Twin Turbo Toyota Soarer. The single turbo came on boost hard after 3500rpm and then it flew, but i thought i was driving a high powered V8 when i took the Twin Turbo for a drive, it just had huge pulling power all through the rev range.
Fun.
On a ford six, zoom magazine did an article on installing a Twin Turbo setup onto a ford six in a series of articles over a few months. they basically went through a step by step process they did on a ute that had so much power it just lit the tyres up even when towing heavy trailers and with the back tray full.
old_mate
PostPosted: Mon Nov 29, 2004 11:13 am    Post subject: Reply with quote
Mmm
The big 4L doesnt really suffer lag if you buy a turbo thats suited to it. It has a good deal of torque as it is.....I know of a couple of cars running GT35/40's with standard motors and making from 220-255rwkw
EACRUISER
PostPosted: Mon Nov 29, 2004 11:18 am    Post subject: Reply with quote
just reading from the post's before and that most uneducated people bolt on the biggest turbo they can find.
i just prefer a linear power band instead of one that hikes in the middle.
old_mate
PostPosted: Mon Nov 29, 2004 10:28 pm    Post subject: Reply with quote
oh for sure, you dont wanna slap on a huge turbo that wont spool up until 5000rpm...
but with a single turbo thats got the right wheels on it you can still get a reasonably linear response...look at the BA XR6T for example
And with single, the manifolding is easier, you only need the one dump pipe and wastegate, and the intercooler piping is easier. Just my opinion, they did make good power and torque with the zoom ute afterall.
EBXR8380
PostPosted: Mon Nov 29, 2004 10:32 pm    Post subject: Reply with quote
Gt 3040 or 3540 is the way to go.. With modern ball bearing tech they spin so quick and keep spining when engine is off ...
4 Lirs have SO much exhaust flow its not funny, you'd need a big a** turbo or bad set up to get any lag ...
mickysacca
PostPosted: Wed Dec 01, 2004 8:51 pm    Post subject: Reply with quote
with the gas research kits, wat kind or rwkw were they getting with/without intercooler?
EBXR8380
PostPosted: Thu Dec 02, 2004 12:35 am    Post subject: Reply with quote
Afaik 160 to 180 ..They use a T3.. Bit small....
TSA....
http://www.gasresearchpc.com.au/html/turbo_specifications.html
[47 queries :: 0.0813 seconds ]
