Cleaning Carbies - Holley's
XeTurbo
PostPosted: Sun Dec 26, 2004 5:03 pm    Post subject: Cleaning Carbies - Holley's Reply with quote
I was just after some info on giving my holley a clean out, i got some s**t petrol the other day from batemans bay and since then it has been running pretty crappy and coughing a little, and i think my carby might need a clean, its has the symptoms of running the car with the choke on? could a new air filter help? and what can i clean on my carby, with out like pulling it all apart as its only fairly new.
cheers John.
xd351wgn
PostPosted: Sun Dec 26, 2004 6:10 pm    Post subject: Reply with quote
if you look at the holley books i lent you ( you had better still have them!!) they will tell you all you need to know!
XeTurbo
PostPosted: Mon Dec 27, 2004 12:20 am    Post subject: Reply with quote
yes tom i still have them! might give it a look over! so hows your car getting along?
master
Donating Member
PostPosted: Mon Dec 27, 2004 7:26 am    Post subject: Reply with quote
There is a spray you can get, I forget what it is called, I think I got it from Supercheap. Anyway I used some on the 2brl weber of my old xd 4.1. Make sure you wear rubber gloves, I didnt, and I found out how corrosive this stuff is. It removed all the grit, grime and build-up in my carbie, and brought it back looking like brand new.
xd351wgn
PostPosted: Mon Dec 27, 2004 8:22 am    Post subject: Reply with quote
Carbi clean, will clean it up dude. i got some so give me a call. and come pick up your s**t!! icon_twisted.gif
Sketch
PostPosted: Mon Dec 27, 2004 10:30 pm    Post subject: Reply with quote
depends how thorough you want to be dude, a rebuild kit is pretty inexpensive, and make a worthwhile difference, and often the needle's get grit in them than can only be dislodged by compresses air or a tooth brush,,, if your goin that far you might as well get the kit and do it perfectly,, its worth it,
if you have a vaccum secondary carb, make sure to check the diaphram in the secondary butterfly's they often become weak or porus, causing improper operation. and not enough air,,, is never fun icon_smile.gif
eed-250
PostPosted: Tue Dec 28, 2004 3:43 am    Post subject: Reply with quote
If it helps when i was looking up prices i found a place which does holley rebuilds for 280 dollars.
The old mustang needs one baaaaaaaaad
flames are NOT GOOD.
XeTurbo
PostPosted: Tue Dec 28, 2004 10:29 am    Post subject: Reply with quote
well my carby is only 1.5 years old so it shouldnt be up for a rebuild yet i dont think? and my baseplate on the carby is only 6 months old. i think i have just clogged it from, s**t petrol or something?
anyways ill give it a look, also would degreaser be ok to spray down the carby? or will it damage stuff?
Sketch
PostPosted: Tue Dec 28, 2004 11:13 am    Post subject: Reply with quote
depends if its water or solvent based degreaser, water based isnt great to get inside the bores, and solvent based can corrode the rubber inside the carby. o'rings ect.
XeTurbo
PostPosted: Tue Dec 28, 2004 4:54 pm    Post subject: Reply with quote
i took my carby off today and soaked it in degreaser and cleaned it right up, and took my jets out and cleaned them, and now it revs up very quickly, but whilst driving and accellerating it takes off awesome gets to around 2 and a bit grand then coughs slightly and then picks up again, its got me buggered, im thinking my fuel filter could be giving me problems?
Sketch
PostPosted: Tue Dec 28, 2004 5:01 pm    Post subject: Reply with quote
have you set your float levels correctly? it could be too low and hitting a lear spot during acceleration, and when accel levels out, it fills back up enough,,
or it could be fuel filter, but that usually clogs up at higher revs and stays clogged untill teh revs drop.
XeTurbo
PostPosted: Tue Dec 28, 2004 7:39 pm    Post subject: Reply with quote
nah i havent played with my float levels, i lowered the secondaries heaps the other day because i thought it was running s**t, i might check the float levels and see how that goes.
[39 queries :: 0.04328 seconds ]
