Cleaning Carboned Pistons
XeTurbo
PostPosted: Wed Dec 01, 2004 11:27 pm    Post subject: Cleaning Carboned Pistons Reply with quote
I was just wondering on the proceedure to clean the carbon off pistons?
Waggin
Site Admin
PostPosted: Wed Dec 01, 2004 11:40 pm    Post subject: Reply with quote
get some water in there while the engine is running. Acts like a steam cleaner thanks to the compression.
I'm sure someone can give you the exact procedure.. you don't want to hydraulic!
XeTurbo
PostPosted: Thu Dec 02, 2004 12:08 am    Post subject: Reply with quote
i have the engine apart, and the pistons out of the engine, so i was wondering if like soaking them in petrol, and using a dishwashing scourer or something to clean it off? im not too sure how prone to scratches/ weakness from the petrol, and scourer
EBXR8380
PostPosted: Thu Dec 02, 2004 12:17 am    Post subject: Reply with quote
Heads on or or off..If on? What we did years ago squirt 2 stroke or upper cylinder lube into carb / inlet till it nearly stopped then left it a while...Start it up and at hi idle and inject water into carb/ inlet..Then take out on road in lower gears.The oil softens carbon and the water takes it away..The hi rpm drive gets rid of it..We did this on slow drivers cars that came in all carboned up...Said it was the only place that fixed their cars....
If heads off wash with carb cleaner...
XeTurbo
PostPosted: Sat Dec 04, 2004 12:37 am    Post subject: Reply with quote
cool, ill give the 'ole carby cleaner ago, its right back to the bare block, ready for dipping, and new cam bearings. the only thing i need to get now is a cam, lifters, valve springs, and a gasket kit, and i should have it up and running soon
Dave
PostPosted: Sat Dec 04, 2004 6:29 am    Post subject: Reply with quote
CRC Gasket stripper
Waggin
Site Admin
PostPosted: Mon Dec 06, 2004 10:32 am    Post subject: Reply with quote
Dave wrote:
CRC Gasket stripper
Interesting! Is this also safe to use on Valves and Combustion Chambers?
CRC gear is just awesome
Dave
PostPosted: Mon Dec 06, 2004 6:47 pm    Post subject: Reply with quote
XeTurbo
PostPosted: Tue Dec 07, 2004 12:08 am    Post subject: Reply with quote
sounds like a good plan to me, where abouts can you pick this stuff up from, like repco or something?
Doghead
PostPosted: Sun Dec 12, 2004 6:31 pm    Post subject: Reply with quote
EBXR8380 wrote:
Heads on or or off..If on? What we did years ago squirt 2 stroke or upper cylinder lube into carb ..
This is no use to you because you have disassembled your motor but is about the use of 2 stoke oil as a carbon cleaner. I use two stroke oil to keep clean the top end on my Harleys. I add a cap full of Penrite 2 stroke oil to a full fuel tank about every 5000 kilometres. A very experienced fitter/motorcycle enthusiast put me onto it about fifteen years ago. I pulled an Harley Evolution motor down at about 150 000 which I had religousy oiled/cleaned and the combustion chamber, valves and piston crown were cleaner than other examples I have repaired. There was no "lip" at the top of the bore at the extent of piston travel, plugs are always clean as well. Have also done a plug chop from about 140kmh and they are fine, no carboning from the oil.
An engineer I work with told me that this top end lubricant (flashlube) is only so muchwhite spirit and 2 stroke oil. He has 5 pre unleaded vehichles and makes his own top end lube with Tolulene and two stoke oil.
mugen
PostPosted: Mon Dec 13, 2004 6:42 pm    Post subject: Re: Cleaning Carboned Pistons Reply with quote
the old carby cleaner will work fine
fordgt290
PostPosted: Mon Dec 13, 2004 7:24 pm    Post subject: Reply with quote
well why do u want to clean the carbon off ur pistons some people say its actually good to keep it on as it helps keep the compression up as parts wear which makes sence and the carbon doesnt really hurt anything unless its getting hot spots and getting detiation which is unlikely unless its a high stressed engine
XeTurbo
PostPosted: Tue Dec 14, 2004 6:51 pm    Post subject: Reply with quote
it doesnt really have too much carbon on it, just mainly stained with a few little chunks here and there, my pistons have only done 1500 ks so there pretty new, im just really wanting my engine to "be new" when i build it, as everything else is clean and tidy.
so what does this bloke mix to make his own lube?
sounds like an interesting topic
fordgt290
PostPosted: Tue Dec 14, 2004 7:32 pm    Post subject: Reply with quote
i wouldnt worry about it at all wont make any difference
XeTurbo
PostPosted: Wed Dec 15, 2004 11:24 pm    Post subject: Reply with quote
cool, might end up stuffing something up if i do!
also does anyone know any tricks to installing new rings? and is it worth buying a tool to do it?
EDXR8
PostPosted: Sun Dec 19, 2004 3:55 pm    Post subject: Reply with quote
Nah don't bother with the tool just as easy to do it with your fingers, its not hard at all
TS50EB
PostPosted: Sun Dec 19, 2004 4:06 pm    Post subject: Reply with quote
Best way I have found to clean pistons, soak it in petrol for as long as you can afford to.
For carbon in the grooves, get one of the old rings, break it, and use this to get into the grooves.
To do the top of the pistons, use a thick plastic scrapper or (very carefully) a metal scrapper.
If you are putting the rings onto the piston, slap lots of oil onto the piston and rings, the rings will go on by hand.
When you are putting them into the block, go spend $30-50 on a ring compressor from Repco or alike.
Andrew J
PostPosted: Sun Dec 19, 2004 4:19 pm    Post subject: Reply with quote
When utting the rings in, its easier to start with the oil ring and work your way back to the top from there. Just make sure you dont let a ring slip into the ring gap of another ring as theyre harder to get out icon_surprised.gif
As for a ring compressor, it makes it much easier, and stops you slipping with anything like a screwdriver. But if youre cheap, be careful, and you should be fine with either fingers or a screwdriver wrapped in an oily rag. that way, if youdo slip, it wont score the side of the piston.
XeTurbo
PostPosted: Mon Dec 20, 2004 5:48 pm    Post subject: Reply with quote
sweet! might be safe and buy a ring compressor!
is that ea citric acid?? im wanting to paint mine citric acid, but im still undecisive!
[46 queries :: 1.17497 seconds ]
