Click Here! It has the answers to all your 6 cyl questions!
theblackone
PostPosted: Mon Aug 14, 2006 7:10 pm    Post subject: Reply with quote
how come this isnt a sticky yet
flyingnunrt
PostPosted: Mon Aug 14, 2006 7:39 pm    Post subject: Reply with quote
How to repair the Clutch pedal box?
Walker
PostPosted: Tue Aug 15, 2006 12:37 am    Post subject: Reply with quote
It's now a Sticky!
Top work there stockstandard.
It certainly drives everyone crazy seeing the same questions pop up every other day, and i guarantee it will still happen but maybe not as much.
theblackone
PostPosted: Mon Aug 21, 2006 6:33 pm    Post subject: Reply with quote
good decision walker! i guess we wont be seeing repeats of the same questions! hehe
JT
PostPosted: Tue Sep 05, 2006 7:20 am    Post subject: Reply with quote
So if I fitted an AU engine into my EBII.. could I bolt on the EB intake manifold to the AU head and everything else would be the same?..
oh and yeah the sump needs that bit ground off the front etc.
voxace
View User Gallery (27)
PostPosted: Tue Sep 05, 2006 10:28 am    Post subject: Reply with quote
Yep, that's correct.
JT
PostPosted: Tue Sep 05, 2006 11:58 am    Post subject: Reply with quote
intriguing.. so apart from the fact that the AU engine will be newer is it actually any different internally?
or are the only power gains in the variably intake manifold which I would have to ditch anyway...
stockstandard
PostPosted: Tue Sep 05, 2006 12:33 pm    Post subject: Reply with quote
from the engine conversion thread:
Fair few changes here. In the bottom end, the crank got larger main bearings longer rods (6” compared to 5.88” in e-series). The rocker gear changed from 2:1 ratio to 1.8:1 (cams are not compatible with earlier engines). AU also received a alloy sump. Ignition went back to coil pack EDIS. AU's got sequential EFI at low rpm (below 3000), at higher rpm injection went back to bank fire.
XRFan101
PostPosted: Mon Sep 11, 2006 2:03 pm    Post subject: Reply with quote
Done a bloody good job here! Plenty of reference!
XRFan101
PostPosted: Mon Sep 11, 2006 2:04 pm    Post subject: Reply with quote
Youve done a bloody good job here! Thiers plenty of reference regarding just about everything!
lukey
PostPosted: Mon Sep 11, 2006 2:24 pm    Post subject: Reply with quote
Good idea mate, I like it.
Good to see people like my pod filter doco.
fiftyone
PostPosted: Wed Oct 18, 2006 12:49 am    Post subject: Reply with quote
i think the sticky is a band aid for the search, because IT DOESN"T WORK!
if it worked right do you think people would bother asking again?
theblackone
PostPosted: Wed Oct 18, 2006 1:32 am    Post subject: Reply with quote
fiftyone loves the search function! lol
its how the forum has been built..
stockstandard
PostPosted: Mon Oct 23, 2006 9:14 pm    Post subject: Reply with quote
Added info on setting the timing (had a run of timing related threads the other day).
EFford
PostPosted: Mon Nov 06, 2006 2:49 pm    Post subject: Engine timming? whats it for, and how and why do it??? Reply with quote
What is engine timming?, EF's you cant adjust it, how come? and what is the reason, and why would you adjust timming?
stockstandard
PostPosted: Mon Nov 06, 2006 2:57 pm    Post subject: Re: Engine timming? whats it for, and how and why do it??? Reply with quote
Engine timing is the position/time the spark plug fires at on each revolution. Generally speaking, its advantageous to have more timing (spark plug fires earlier) but if it fires to early you run into problems.
EF's cant adjust timing as the ignition system is completely computer controlled. On ea-ed and el engines it is partially computer controlled so you can move the distributor to give more or less timing.
Pet_ED
PostPosted: Mon Nov 06, 2006 3:06 pm    Post subject: Reply with quote
Good on ya fo doin it!
Im assuming the are threads in the list for:
BBM conversion and for
LOWS and SUPERLOWS etc
EF/EL Fan conversion etc
GAS faqs?
Just some ideas...
fonzy_69er
PostPosted: Mon Nov 06, 2006 3:09 pm    Post subject: Reply with quote
Heaps good idea, Keep up the good work.
stockstandard
PostPosted: Mon Nov 06, 2006 3:14 pm    Post subject: Reply with quote
GAS faqs?
Just some ideas...
most of them, except for lows/superlows which belong more in the suspension forum and gas which would be in the fuel forum.
There are lots of other topics I could add - T5 conversions, diff gear swaps, chips and aftermarket ecu's, etc but not sure how much non I6 specific things to bring into the I6 forum.
Pet_ED
PostPosted: Mon Nov 06, 2006 5:54 pm    Post subject: Reply with quote
GAS faqs?
Just some ideas...
Fair call.
Look fwd to see what else is added
Page 2 of 3
[47 queries :: 0.0495 seconds ]
