Click Here! It has the answers to all your 6 cyl questions!
Goto page 1, 2, 3  Next
stockstandard
PostPosted: Fri Aug 11, 2006 12:49 pm    Post subject: Click Here! It has the answers to all your 6 cyl questions! Reply with quote
I want to use a pod filter, how do I do it?
http://www.fordmods.com/forums/viewtopic.php?t=23157
http://www.fordmods.com/forums/viewtopic.php?t=22597
What Exhaust/Extractors do I get and how much?
http://www.fordmods.com/forums/viewtopic.php?t=33443
http://www.fordmods.com/forums/viewtopic.php?t=32870
http://www.fordmods.com/forums/viewtopic.php?t=32265
http://www.fordmods.com/forums/viewtopic.php?t=1416
Whats the best cam?
No such thing icon_biggrin.gif << VERY true - no one cam is THE best
have a look through http://www.fordmods.com/forums/viewtopic.php?t=66
Wade, Surecam, Crow, RPD, Jim Mock Motorsport and others all make cams for these engines. Check them all out and see what is best for you. If you post a thread asking for cam advice, provide as much information as possible about your car - Engine mods both current and future, gearbox, diff, how you drive most of the time, how much of a lumpy idle can you put up with, what your power/quarter mile goals are. This will help others to help you icon_smile.gif
Whats the differences between the all the different model heads?
http://www.fordmods.com/forums/viewtopic.php?t=31256
http://www.fordmods.com/forums/viewtopic.php?t=30800
http://www.fordmods.com/forums/viewtopic.php?t=32074
http://www.fordmods.com/forums/viewtopic.php?t=31501
http://www.fordmods.com/forums/viewtopic.php?t=31415
I need to change my head gasket, what ones can I use?
http://www.fordmods.com/forums/viewtopic.php?t=30752
http://www.fordmods.com/forums/viewtopic.php?t=33021
http://www.fordmods.com/forums/viewtopic.php?t=32433
Can I swap rocker covers on my EA?
http://www.fordmods.com/forums/viewtopic.php?t=31444
How do I remove the service spanner from my dash?
http://www.fordmods.com/forums/viewtopic.php?t=15765
Ive seen an intake mod chip on ebay that claims that it will give me 20hp, do they really work?
NO! These are a scam. For your money you will get a 10c resistor that will trick you ECU into thinking its hotter/colder than it is. The best you can hope for is to not lose power.
How do I remove my speed limiter?
First read this – http://www.fordmods.com/forums/viewtopic.php?t=27962
http://www.fordmods.com/forums/viewtopic.php?t=23508
What cheap mods can I do for more power?
My engine is making a ticking noise, what could it be?
http://www.fordmods.com/forums/viewtopic.php?t=33227
http://www.fordmods.com/forums/viewtopic.php?t=32652
http://www.fordmods.com/forums/viewtopic.php?t=30949
http://www.fordmods.com/forums/viewtopic.php?t=30600
http://www.fordmods.com/forums/viewtopic.php?t=30490
http://www.fordmods.com/forums/viewtopic.php?t=29538
http://www.fordmods.com/forums/viewtopic.php?t=30196
http://www.fordmods.com/forums/viewtopic.php?t=26655
http://www.fordmods.com/forums/viewtopic.php?t=9726
http://www.fordmods.com/forums/viewtopic.php?t=8474
http://www.fordmods.com/forums/viewtopic.php?t=4635
http://www.fordmods.com/forums/viewtopic.php?t=3578
http://www.fordmods.com/forums/viewtopic.php?t=1750
Can I put an engine out of X into my Y?
http://www.fordmods.com/forums/viewtopic.php?t=31883
http://www.fordmods.com/forums/viewtopic.php?t=38977 (BA->e-series discussion)
What spark plugs/leads are the best?
http://www.fordmods.com/forums/viewtopic.php?t=33668
http://www.fordmods.com/forums/viewtopic.php?t=33076
http://www.fordmods.com/forums/viewtopic.php?t=32308
http://www.fordmods.com/forums/viewtopic.php?t=359
http://www.fordmods.com/forums/viewtopic.php?t=20711
How do I reset my ECU?
http://www.fordmods.com/forums/viewtopic.php?t=33496
http://www.fordmods.com/forums/viewtopic.php?t=28483
http://www.fordmods.com/forums/viewtopic.php?t=26774
http://www.fordmods.com/forums/viewtopic.php?t=24908
Can I get a bigger throttle body for my I6?
http://www.fordmods.com/forums/viewtopic.php?t=31818
How do I set the timing?
*note: you cant change the timing on EF's as the ignition is fully computer controlled.
1. Have the engine at normal operating temperature, clean the timing marks on the balancer and timing cover, connect timing light.
2a (EA and EB1). There will be a plug in the engine bay near the brake booster. Earthing this puts the ECU into diagnostic mode for timing adjustments to be made.
2b (EB2 or later). Open the instrument panel cover to the lower right of the steering wheel and locate the diagnostic port (white plug with lots of pins). Connect a test lead (bit of wire, paper clip, etc) from the top-left pin (Engine STI) to earth (the lower-left pin is an earth).
3. Start the engine. It should idle very high indicating that the ECU is doing a self test. You now have 1 minute to check the timing by firing your timing gun at the timing mark on the balancer. If you run out of time, stop and restart the engine. The timing should be locked at 10 degrees advanced.
4. If the timing is out, loosen the hold-down bolt on the distributor and rotate it until you have the correct timing.
5. Turn off the engine, remove the jumper wire from the diagnostic port and tighten the distributor hold-down bolt.
If you can think of any more post them and ill add them to this list.
wicksy
PostPosted: Fri Aug 11, 2006 12:50 pm    Post subject: Reply with quote
lol good idea, it does get annoying people keep repeating threads
eb_guy888
PostPosted: Fri Aug 11, 2006 1:31 pm    Post subject: Reply with quote
I agree
twr7cx
PostPosted: Fri Aug 11, 2006 1:33 pm    Post subject: Reply with quote
Very nice.
Maybe move pods to the top of the list...
voxace
View User Gallery (27)
PostPosted: Fri Aug 11, 2006 1:36 pm    Post subject: Reply with quote
Someone HAS to make that a sticky.
Steady ED
Fordmods Addict
PostPosted: Fri Aug 11, 2006 2:12 pm    Post subject: Reply with quote
Whats the best cam?
Sticky this AND the engine conversion thread stockstandard has done.
PLEASE!
stockstandard
PostPosted: Fri Aug 11, 2006 2:26 pm    Post subject: Reply with quote
cheers steady ED
also moved pods to the top
efbignik
PostPosted: Fri Aug 11, 2006 2:31 pm    Post subject: Reply with quote
good work stocky
Grechie
PostPosted: Fri Aug 11, 2006 2:45 pm    Post subject: Reply with quote
sticky this!!
good work stockstandard!
fiftyone
PostPosted: Fri Aug 11, 2006 8:37 pm    Post subject: Reply with quote
finally, someone figures out the search doesn't work.
stockstandard
PostPosted: Fri Aug 11, 2006 9:02 pm    Post subject: Reply with quote
snap0964
PostPosted: Fri Aug 11, 2006 9:25 pm    Post subject: Reply with quote
I was going to say the same thing - here's 10 mins searching's worth.
How about I6 cylinder head stuff - gaskets/interchanging/differences/LPG:
Rocker covers:
stockstandard
PostPosted: Fri Aug 11, 2006 9:33 pm    Post subject: Reply with quote
cheers snap
smiley235
PostPosted: Fri Aug 11, 2006 9:41 pm    Post subject: Reply with quote
Is this a scam or worth getting?
http://cgi.ebay.com.au/Intake-Mod-Chip-4-Ford-Falcon-XR6-XR8-AU-EA-BA-EB-EF-EL_W0QQitemZ250015143435QQihZ015QQcategoryZ102349QQrdZ1QQcmdZViewItem
YES IT f**k IS A SCAM!!!
stockstandard
PostPosted: Fri Aug 11, 2006 9:44 pm    Post subject: Reply with quote
YES - how did I miss that one!!!
snap0964
PostPosted: Fri Aug 11, 2006 9:50 pm    Post subject: Reply with quote
stockstandard wrote:
cheers snap
mrnasty
PostPosted: Sat Aug 12, 2006 10:02 am    Post subject: Reply with quote
stocko, chuck up a specific:
"BA Turbo motor into anything other than BA"
theblackone
PostPosted: Sun Aug 13, 2006 11:06 pm    Post subject: Reply with quote
this should be a sticky
rushed
PostPosted: Sun Aug 13, 2006 11:15 pm    Post subject: Reply with quote
another vote sticky.
would solve many of these repeat topics.
haggis
PostPosted: Mon Aug 14, 2006 2:49 am    Post subject: Reply with quote
Actually, a script that made someone who clicks on the 6 cylinder forum for the first time automatically show this page would be an awesome idea... Slightly annoying whenever you're on a different machine and would have to enter it a second time... but we know how to do that quickly, a first time user would be far more likely to read the first post at least icon_smile.gif
Page 1 of 3
[47 queries :: 0.08791 seconds ]
