Low EL Fordmods Tyre Shredder
Age:28 Posts: 311 Joined: 05 Nov 2004 Location: Cairns, Far North Queensland QLD, Australia
Posted: Tue Jul 15, 2008 4:18 pm Post subject: |
| Hey nicco, slightly off topic, did you use a new clutch cable, and if so, what sort of $$ did you pay (PM if you want), cause i need a new one, and im sure thats part of the reason my clutch pedal sits out so far. |
s-tranzor Fordmods - Getting Side Ways
Age:25 Posts: 433 Joined: 29 May 2007 Location: Perth WA, Australia
Posted: Tue Jul 15, 2008 4:35 pm Post subject: |
| Gaz wrote: | On mine, its quite the opposite. I can push the clutch in half way and changes gears. I rarely ever push it to the floor, just a little stab is all it needs to disengage?
I adjusted it 140mm from the floor. |
Mine is the same and I have a Mal Wood HD clutch. Full engaged is about 2 cm from the top (I think) but it starts to grab about 1/4 way up the travel. Makes engagement a nice gradual thing which is probably a good thing on a high torque engine. Especialy when you are tryna eat a pie while shifting.  |
Age:24 Posts: 3707 Joined: 13 Mar 2006 Location: Dubbo NSW, Australia
Posted: Tue Jul 15, 2008 5:31 pm Post subject: |
| snap0964 wrote: | There's an anchor point in the floor - use a ruler or similar, hold it horizontal and straight ahead from the pedal hole, should give you the location.
It can be hard to locate amongst the soundproofing. |
there is an anchor point as was stated ^ what i did when i replaced my spring i got a set of pointy nose pliers and pushed the clutch pedal fully in and attached it that way.. |
Age:21 Posts: 2546 Joined: 08 Nov 2004 Location: Townsville/Cairns QLD, Australia
Posted: Tue Jul 15, 2008 7:12 pm Post subject: |
Tim: yeah i bought a brand new clutch cable. I rang around and got some quotes. Repco and Autobarn both wanted about $75 for the cable, but repco only wanted $10 to get it to Cairns. Autobarn was $15.
Super Cheap was $85 and Ford was $120.
I ended up getting mine from Repco.
Froudey: cheers for the tip. |
TROYMAN Technical Contributor
Age:34 Posts: 2665 Joined: 07 Nov 2004 Location: South Western Sydney NSW, Australia
View User Gallery (29)
Posted: Tue Jul 15, 2008 7:19 pm Post subject: |
far out man.
ford must have different prices in different states..
i only paid $70 from ford about 3 months ago.. |
Posted: Tue Jul 15, 2008 7:39 pm Post subject: |
probably just imbred townsville ford people!!
they also told me that an EF gear stick would be $454  |
Age:44 Posts: 2956 Joined: 13 Jan 2005 Location: South Coast NSW, Australia
Posted: Tue Jul 15, 2008 10:42 pm Post subject: |
You can also use an EB/ED cable - it's around 4-5" longer than EF/EL, but the inner cable travel is the same.
Be interesting to see if the price is greatly different. |
Age:19 Posts: 4061 Joined: 02 Mar 2006 Location: Port Lincoln SA, Australia
Posted: Tue Jul 15, 2008 10:45 pm Post subject: |
| nicco wrote: | probably just imbred townsville ford people!!
Holy f**k!  |
Posted: Wed Jul 16, 2008 1:00 am Post subject: |
alfy, yeah thats about what i said as well!!  |
Posted: Wed Jul 16, 2008 7:08 pm Post subject: |
| Cool. I need a new cable (extractors have melted the outer, which im sure is causing mine to stretch), and my mate at ford spares quoted me $75 for a new ford one. |
94efdabomb Fordmods Newbie
Age:20 Posts: 8 Joined: 26 Jul 2008 Location: cessnock NSW, Australia
Posted: Sat Jul 26, 2008 7:54 pm Post subject: had the same problem |
yeah mate had the same problem on my ef aftermarket 5 speed in the end we worked out that the cable wasnt routed properly and with in the time it wasnt it strected the cable because mine used to stick out to china so give it a shot cheers
yeah well im in nsw and they qouted me 125 dollars for my clutch cable i went to the ford centre in cardif and they gave me a new one for $79 ford dnt know s**t got no idea about nothin i wanted to take my seat out to fix the broken brackets they wanted 80$ per seat the tool cost me $4 and the old man welded it up all up it cost me about 20 bucks so where do they get $80 |
Posts: 3169 Joined: 08 May 2007 Location: Sunny QLD, Australia
Posted: Sat Jul 26, 2008 9:01 pm Post subject: |
| nicco wrote: |
clutch pedal is around 170mm!! its a long way out.
Just to make sure, that you are measuring pedal travel, not pedal distance from the floor depending how you measure it i guess.
If you measure from the back of the pedal where it meets the carpet and the distance to the floor is a good indication of travel.
Duh i know, but just making sure..... |
Posted: Sun Jul 27, 2008 9:33 am Post subject: |
ff: yeah, i measured the travel. it goes all the way to the floor, and i measured where it touches.
94: interesting. could you please tell me where "incorrectly" run is? and where properly run is. at the moment, i just played with ways to make it not touch the headers or anything moving. |
Bug Fordmods - Getting Side Ways
Age:26 Posts: 467 Joined: 05 Nov 2004 Location: Tweed Heads NSW, Australia
Posted: Sun Aug 03, 2008 3:46 pm Post subject: |
| A couple of zip ties also does the job just fine |
Greenmachine Fordmods Tyre Shredder
Age:41 Posts: 319 Joined: 22 Mar 2005 Location: Cairns Qld - god's own country QLD, Australia
Posted: Tue Aug 05, 2008 7:47 am Post subject: |
My cable runs forward and down from the firewall to about where the pwr steer rack pipes are and then I've got it cable-tied to the rack across to the other side where it curves back and up to the bellhousing clamp.
Interesting to hear the EF/EL cable is shorter, because the length of mine has always been a drama - ie. the bend radiuses where it goes onto and comes away from the rack are of necessity quite tight to take up the length - shorter would be perfect! |
