Age:21 Posts: 2480 Joined: 08 Nov 2004 Location: Townsville/Cairns QLD, Australia
Posted: Sat Jul 12, 2008 7:54 pm Post subject: Clutch Pedal Stopper |
I am leading this on from my last topic about the pedal being too high, but think it deserved its own thread.
I have done my manual conversion now, and the clutch pedal sits about a day in front (2" to 2.5") of the other pedals. It also means i need my knees up around my ears to put my foot on the clutch.
the flywheel has been machined at least once, and looked well used before i put it on, unfortunately i didnt measure how much meat was on it before installing it (didn't know i would need to)
the clutch is brand new, and is fully engaged about one inch off the floor. The rest of the travel is just taking up slack in the pressure plate (i think that is the right terminology for what i want)
to combat the high pedal, i want to put a stopper in the pedal, making it sit back down a bit. it wont affect the clutch engagement doing this, it really is fully engaged well before this.
the question i want to know the answer to though is whether or not the throwout bearing will wear out really quickly with there being a bit of pressure against it all the time?
if anyone can shed any light on this it would be appreciated.
Cheers,
Nic
Age:24 Posts: 3555 Joined: 13 Mar 2006 Location: Dubbo NSW, Australia
Posted: Sat Jul 12, 2008 8:05 pm Post subject: |
| Can i suggest getting mock up something like a rubber bush just duct taped on or somethin to "prototype" it until you figure out how much you need to add and to see if it affects the pedal and the gearshifting
Posted: Sat Jul 12, 2008 8:15 pm Post subject: |
we are going to put a bolt with two nuts through the clutch switch mount (i have a manual pedal box) so it can be adjusted.
we got that covered!!
Timmeh Moderator
Posts: 6309 Joined: 06 Nov 2004 Location: Perth WA, Australia
Posted: Sat Jul 12, 2008 8:16 pm Post subject: |
| Can you adjust the pedal using the nut in the engine bay? Sounds like something is not right.
Posted: Sat Jul 12, 2008 8:18 pm Post subject: |
| yeah, to get the clutch to disengage properly we had to use the adjusting nuts in the engine bay. they wound out a fair way.
lil_lincoln Fordmods Tyre Shredder
Age:17 Posts: 379 Joined: 10 May 2007 Location: Melbourne VIC, Australia
Posted: Sat Jul 12, 2008 9:26 pm Post subject: |
| dude i just looked in my repair manual and it says it should be 178 and 180something. so i dun think you have anything wrong with it....
Posted: Sat Jul 12, 2008 9:58 pm Post subject: |
it actually doesnt look as bad in the picture as it feels or looks from the drivers seat
Posted: Sat Jul 12, 2008 9:59 pm Post subject: |
| also, i thought it was meant to be around 140mm from the floor for max travel
Age:25 Posts: 698 Joined: 10 Nov 2004 Location: Tingalpa QLD, Australia
Posted: Sun Jul 13, 2008 9:27 am Post subject: |
my eb is factory manual, and thats exactly the way the clutch sits and is supposed to sit. quit ya whinging!!!
TROYMAN Technical Contributor
Age:34 Posts: 2518 Joined: 07 Nov 2004 Location: South Western Sydney NSW, Australia
View User Gallery (30)
Posted: Sun Jul 13, 2008 9:33 am Post subject: |
my clutch pedal sits about 10-15 mm higher than the brake pedal..
and the clutch starts to engage about 20mm of the floor.
Age:22 Posts: 1993 Joined: 05 Nov 2004 Location: Penrith NSW, Australia
Posted: Sun Jul 13, 2008 12:07 pm Post subject: |
| Did you get the spring that connects the pedal to the floor? That helps pull it back a little.
Age:43 Posts: 2915 Joined: 13 Jan 2005 Location: South Coast NSW, Australia
Posted: Sun Jul 13, 2008 12:33 pm Post subject: |
The pedal height is determined by the cable adjustment - a bump stop won't alter this. Slight pressure on the TO bearing, so it contacts the PP is normal - the spring mentioned above helps this.
Normally the clutch pedal should sit level or slightly higher than the brake pedal.
The flywheel thickness/pressure plate will determine where the friction point is (assuming the other components are okay - fork, etc).
I had similar with my wagon using a 3 bolt flywheel/pressure plate - the clutch was so heavy it broke the cable eventually, so I ditched this and got a 6 bolt flywheel and HD pressure plate, clutch is nice and soft, and no probs - normal pedal height too.
All you can do at this time is have the friction point as close to the floor as you can, but still be able to engage/disengage normally - too high means the PP gets overtravelled, which isn't good long term. You won't meet factory dimensions, so no point trying.
Age:22 Posts: 3749 Joined: 15 Nov 2004 Location: Perth WA, Australia
Posted: Sun Jul 13, 2008 5:04 pm Post subject: |
On mine, its quite the opposite. I can push the clutch in half way and changes gears. I rarely ever push it to the floor, just a little stab is all it needs to disengage?
I adjusted it 140mm from the floor.
Posted: Sun Jul 13, 2008 11:36 pm Post subject: |
punnisher: i want it right
troy: i did some measuring today, brake pedal sits around 110mm from the firewall, clutch pedal is around 170mm!! its a long way out.
drone: no, i didnt even know there was a spring meant to be there, although it makes sense now that you've mentioned it! it wont pull the pedal back as far as i want it back though.
ray: i'll draw a pic of what i mean with the bump stop. i had trouble explaining it with words. My acutal clutch isnt *that* heavy. I currently have it engaging about 20 or 30mm off the floor, nice and early. It seems fully engaged within another 30mm or so. leaving the pedal another 100mm of travel with nothing really happening. Its only even a light pressure on the pedal at that stage.
gaz: you smug bastard!! lol
Posted: Mon Jul 14, 2008 9:08 pm Post subject: |
Putting heavy tension on the cable = bad idea.
Can cause the cable to stretch and fail prematurely, also can cause the TO bearing to do same.
Stick to the factory setup - get that spring fitted, and try someone else's cable.
Posted: Mon Jul 14, 2008 9:50 pm Post subject: |
| get a spring it will make all the difference they are like 6 bucks at ford if they say ef/el or pre au ones are no longer available just use an au same part number same same.
Posted: Mon Jul 14, 2008 11:28 pm Post subject: |
| snap0964 wrote: | Putting heavy tension on the cable = bad idea.
Stick to the factory setup - get that spring fitted, and try someone else's cable. |
to be honest, that was much the same conclusion i had come to myself anyway. was curious to see what everyone thought on it anyway. for now i had decided to let it go anyway. i'm used to the height of it now.
i will get one of those springs and see how she goes.
silly question, where does the spring mount to? i know where the hole on the pedal itself, but the other end.
Posted: Tue Jul 15, 2008 12:26 am Post subject: |
There's an anchor point in the floor - use a ruler or similar, hold it horizontal and straight ahead from the pedal hole, should give you the location.
It can be hard to locate amongst the soundproofing.
Posted: Tue Jul 15, 2008 10:41 am Post subject: |
| ahh cool thanks. i had never even noticed it there. will go and have a look later on.
