AUXR8 2
Posts: 363 Joined: 08 Nov 2004 Location: Liverpool 02 9600 6229 NSW, Australia
Posted: Sun Sep 16, 2007 2:27 pm Post subject: CMS stage 3 E series head & cam package |
My stage 3 again delivers more torque & hp from your i6, with the stg 3 cam it give you a nice lope at, idle sounds great with a good exhaust mod what you get is....
fully serviced head
heavy duty valve springs
over size exhaust valves
minor port work
reground stg 3 cam & shims
new vernier cam gear
total $1690.00 plus P&H (on an exchange basis) or $150.00 core deposit will apply.
Again this package is ECU freindly...... very impressive with a manual.
thanks
Joe
Age:18 Posts: 3826 Joined: 02 Mar 2006 Location: Port Lincoln SA, Australia
Posted: Sun Sep 16, 2007 2:33 pm Post subject: |
| any idea on the rwkw this puts out on say, an EB of EF? |
Posts: 2981 Joined: 08 May 2007 Location: Sunny QLD, Australia
Posted: Sun Sep 16, 2007 2:38 pm Post subject: |
| Also ive read from a post here that the stage 3 cam needs the timing changed to run properly..... is that the case? |
AUXR8 2
Posted: Sun Sep 16, 2007 10:38 pm Post subject: CMS stg 3 |
NO...............the 3 dosn't need the timing changed to run propley the factory ignition map is fine.....but if you have a dizzy set up then you have the luxury of adding a few degrees of extra base, where the guy's that run coil packs can't for now ??...... I have both the 2 & 3 cams out there in dizzy & coil pack set ups & eveyone is still running there factory ECU'S & factory ignitions.
I know they work as I have proven dyno & track figures to back them up, which is more than what other products claimed.... obviously there is one in question but I am working with him in resolving his problem.
thanks
Joe. |
AUXR8 2
Posted: Sun Sep 16, 2007 11:09 pm Post subject: CMS 3 |
| alfy wrote: | | any idea on the rwkw this puts out on say, an EB of EF? |
IMO...... I think that you will see a better resault in a EB & D than a EF using the stage 3 set up for 2 reasons, the first thing is, I think IMO the log manifold works better than the BB & the fact that you have a dizzy to play with, again we are talking about using our FACTORY ECU's ...which is why I made these cams.
I did a stg2 package for an ED (manual) a few years ago & we got 140ish rwkw we also did a stg2 for an EF (new auto with a 2700 stallie) last year & we got 140rwkw, now if the BB is suppost to be the better manifold, so people claim, there should have been a difference in the two....... oh , & the D had more km's on the clock as well.
thanks
Joe |
Posted: Mon Sep 17, 2007 9:42 am Post subject: |
| FordFairmont wrote: | | Also ive read from a post here that the stage 3 cam needs the timing changed to run properly..... is that the case? |
Hi thanks sounds good. |
kezz Fordmods - Getting Side Ways
Age:20 Posts: 2144 Joined: 05 May 2005 Location: blu mtns NSW, Australia
Posted: Mon Sep 17, 2007 11:54 am Post subject: head packages |
joe what kind of labour figures would people be looking at for installation?
as a head & cam package labour only $400.00 most of the time is taken up in cleaning & preping then check cam pre-load & cam dailing.....
thanks
Joe |
fordfreak ef Cruise Moderator
Age:25 Posts: 8174 Joined: 17 Apr 2005 Location: ya mums bed! lol NSW, Australia
View User Gallery (31)
Posted: Mon Sep 17, 2007 2:55 pm Post subject: |
| ive just last fri night taken delivery of my car wit ha stage 3 head and cam package... needs the unichip to be reprogrammed.. and that will be not this thur coming the following thursday... the 27/9/07... at autotech... |
AUXR8 2
Posted: Mon Sep 17, 2007 11:40 pm Post subject: Re: head packages |
[quote="kezz"]joe what kind of labour figures would people be looking at for installation?]
thanks
Joe |
AUXR8 2
Posted: Tue Sep 18, 2007 12:47 am Post subject: cms3 |
| fordfreak ef wrote: | | ive just last fri night taken delivery of my car wit ha stage 3 head and cam package... needs the unichip to be reprogrammed.. and that will be not this thur coming the following thursday... the 27/9/07... at autotech... |
would be intressting to see what reading you get from them also get them to do a before to compare with
Joe |
Age:20 Posts: 811 Joined: 19 Feb 2007 Location: Lilydale VIC, Australia
Posted: Tue Sep 25, 2007 7:51 am Post subject: |
| Hey mate do these head & cam packages suit the EL Hybrid engines? I wouldn't mind getting the stage 3 because JMM is a rip off haha |
AUXR8 2
Posted: Tue Sep 25, 2007 8:50 am Post subject: cms 3 |
I can do a 3 for the hybird but, I'll be honest with you I only sold 2x stage 2 cams for the hydbrid & they work well with the factoy ECU.... but I dont know how a 3 cam will go with that ECU, as it is a more agressive profile.....also the 3 does works in eveything else, I'm not sure how it will go in a hybird motor ?? as with the AU cams you must run an edit ,chip or a piggy back of some sort....but if your willing to give it a go then I'm more that happy to do one for you.
thanks
Joe |
^JAsE^ Fordmods Parts Gopher
Age:25 Posts: 82 Joined: 05 Nov 2004 Location: sydney NSW, Australia
Posted: Tue Sep 25, 2007 8:59 pm Post subject: |
| Guys just wanted to put my 2 cents worth in im quite sure there is no difference in the ecu of an el hybrid to a normal one as far as im aware the head is the only difference but i just want to say that look as far as im concerned this is THE BEST package around to suit the e series alot of time research and experience has gone into developing these i should know i was a tester for most of the cams and look at the torque my car has now and thats still a stage 3 cam |
Posted: Sun Sep 30, 2007 10:25 pm Post subject: |
| How much is Postage and handling to Melbourne? |
AUXR8 2
Posted: Mon Oct 01, 2007 10:36 am Post subject: cms pakage |
| GeZza200 wrote: | | How much is Postage and handling to Melbourne? |
depends what you want sent & how quick you want it ??
Joe. |
Posted: Mon Oct 01, 2007 6:17 pm Post subject: |
fully serviced head
minor port work
Do i send you my head and you do those mods to it, or do you provide the head aswell? |
XR_Fairmont Fordmods - Smokin em up
Age:26 Posts: 299 Joined: 11 Jul 2007 Location: Wakeley/NSW Sydney NSW, Australia
Posted: Mon Oct 01, 2007 9:21 pm Post subject: |
| whats the most power u can get out of a EFll Auto |
AUXR8 2
Posted: Wed Oct 03, 2007 8:50 am Post subject: stage 3 package |
| GeZza200 wrote: | fully serviced head
minor port work
Ok, the stage 3 package is $1690.00 or ($1795 for AU & hybird ) plus $95 return delivery exchange, but if yours is a EL hybird I don't know how the stage 3 cam will perform as I havn't sold a 3 cam to anyone with a hybird motor, but I have sold the stage 2 cams to guys & so far so good & thats being honest with you, or if you have a hybird you have to run a chip or a piggy back of some sort as do the AU's
I would rather do yours up to save on deposits or I will have to charge extra then credit the deposits....
thanks
Joe |
Posted: Wed Oct 03, 2007 9:39 am Post subject: |
| Would it be easier just to use a EL head then screwing around with my AU/hybrid head? Because the EL Hybrid have the same ECU as the normal EL |
AUXR8 2
Posted: Wed Oct 03, 2007 6:21 pm Post subject: stage 3 cma |
| GeZza200 wrote: | | Would it be easier just to use a EL head then screwing around with my AU/hybrid head? Because the EL Hybrid have the same ECU as the normal EL |
the head isn't the problem its the Factory ECU in the hybird & I dont know how my stg 3 cam will go as Its a fairly lopey at idle but my 2 's work in the hybird so far............ all the other E series, its all good  |
