cold air intake
ebxr8
PostPosted: Tue Jan 18, 2005 1:14 pm    Post subject: cold air intake Reply with quote
hey guys i have a 1992 xr8 and want to do something to up the performance of the air intake but i want to hear about all the possible options before making any decions...anything you guys have to offer is greatly appreciated..cheers.
PostPosted: Tue Jan 18, 2005 1:30 pm    Post subject: Reply with quote
I guess there's a couple of options...
Get a larger intake snorkel than the standard job... either one from another Ford or an aftermarket job like SS inductions (bit pricey IMO).
Or make your own. If you have a look in my gallery you can see where the intake plumbing goes, and there's a pic of where i have mounted the pod filter. Didnt have much choice with the supercharger but dont see why you couldnt righ something up like that to feed the airbox.
teeys
PostPosted: Tue Jan 18, 2005 1:42 pm    Post subject: Reply with quote
i was (and still am) interested in a steel pipe from tb to maf similar to the i6 guys..i know its not cold air.. but if it was custom made you could really move it to wherever you want
ebxr8
PostPosted: Tue Jan 18, 2005 1:48 pm    Post subject: Reply with quote
on the standard intake box the hole is pointing out towards the fan..is there any way of laying an intake ontop of the fan and running the hose back in through the hole in the standard box??
PostPosted: Tue Jan 18, 2005 1:51 pm    Post subject: Reply with quote
Do you mean draw air from the fan and direct it to the airbox?
If so... i wouldnt recommend it - the fan is drawing air through the radiator which is extracting all the heat from the coolant.
Do you have a snorkel on there at the moment?
ebxr8
PostPosted: Tue Jan 18, 2005 1:53 pm    Post subject: Reply with quote
nah i don't have a snorkle on there at the moment...its stock as a rock
PostPosted: Tue Jan 18, 2005 1:55 pm    Post subject: Reply with quote
OK well there's meant to be a plastic snorkel coming from the hole in the airbox and going up to the top of the radiator to breathe cold air from between the bonnet and the headlight (this is the factory setup). At the moment she is sucking in hot air from the engine bay.
ebxr8
PostPosted: Tue Jan 18, 2005 2:01 pm    Post subject: Reply with quote
yeah thats the main reason i wanted to get something done to it coz i noticed it was just sucking the hot air from around the motor...how much would one of those factory snorkels set me back for the time being??
PostPosted: Tue Jan 18, 2005 2:03 pm    Post subject: Reply with quote
About 35 bucks from Ford, will need to make sure you can get one that fits your airbox.
ebxr8
PostPosted: Tue Jan 18, 2005 2:08 pm    Post subject: Reply with quote
cheers buddy...that'll slot nicely into my tight budget until cash flow starts to actually flow again...thanx mate
PostPosted: Tue Jan 18, 2005 2:09 pm    Post subject: Reply with quote
No probs - just make sure it's gonna fit before handing over the $$$
ebxr8
PostPosted: Tue Jan 18, 2005 2:10 pm    Post subject: Reply with quote
will do champ
Vic
PostPosted: Tue Jan 18, 2005 4:10 pm    Post subject: Reply with quote
Yeh, go the GT snorkel like Marty has suggested as they're so damned cheap. It beats paying for the aftermarket ones I have and tried.
TerroristGHIA
PostPosted: Thu Jan 20, 2005 1:48 am    Post subject: Reply with quote
You could also cut a 4 in hole in the bottom of the airbox through the inner guard and run some ducting to the from bar. I did this on mine and it works a treat. Best part is that it cost less than $30 for the ducting fitted
Speary10
PostPosted: Thu Jan 20, 2005 7:55 am    Post subject: Reply with quote
[quote="FPV56L"]You could also cut a 4 in hole in the bottom of the airbox through the inner guard and run some ducting to the from bar. I did this on mine and it works a treat. Best part is that it cost less than $30 for the ducting fitted[/quote]
FPV, Where do you get the air from, cos as far as i know there aint much room at the fron of these cars to receive air. I am looking at similar modifications for my EL, but I am going to great lengths as there are not many opportunities in my front bar. I would be interested to hear how you did it.
Cheers[/quote]
Vic
PostPosted: Thu Jan 20, 2005 9:53 am    Post subject: Reply with quote
The end of the duct pipe comes out behind the empty cornering lamp vent underneath. Quite a few people have done this.
XR8Chic
PostPosted: Thu Jan 20, 2005 10:57 am    Post subject: Reply with quote
You can buy them from a few workshops that specialise in ford.
I actually sold one on here not that long ago to MrLandau.
TerroristGHIA
PostPosted: Thu Jan 20, 2005 6:19 pm    Post subject: Reply with quote
yep, thats where it comes out at the front of the bar where the corner lights go. I used 125mm flexible ductiong for house airconditioning. It needs to squash to about 2 inches high to clear the ABS controller below the airbox. Its a squeeze, but the ducting is plastic with wire reinforcing so it still retains its shape
[45 queries :: 0.05321 seconds ]
