Age:22 Posts: 2417 Joined: 07 Nov 2004 Location: geelong VIC, Australia
Posted: Sun Feb 13, 2005 5:54 pm Post subject: custom intake manifold - welding questions |
im looking into buying an eaton M90 supercharger for my ED, i want to run it off the AC compressor belt, but to fit it onto the intake side of the motor i need to piss off the standard manifold, and go something like the one on the BA XR6T, if i buy aluminum wire for my MIG, will i be able to weld a new aluminum plenum to whats left of the runners on my stock manifold (im going to keep the flange and about 80mm of the runners so i dont have to stuff around making new spots for the injectors and mounts for the fuel rail.
OR will a BA XR6T manifold bolt up to my motor (im not holding my breath on this one) |
Aaron_EF8 Fordmods Stock as a Rock
Age:24 Posts: 133 Joined: 05 Nov 2004 Location: Adelaide, SA SA, Australia
Posted: Sun Feb 13, 2005 7:56 pm Post subject: |
| A BA BBM manifold won't bolt up, but an EF-AU one will, and they are the same apart from the bolt positions for the head. |
Wolf Fordmods Oompa Loompa
Age:30 Posts: 20 Joined: 10 Feb 2005 Location: Canberra ACT, Australia
Posted: Sun Feb 13, 2005 8:04 pm Post subject: |
| Welding cast alloys, such as the plenum, can be hasrd as you get all kinds of inconsistencies in the material, unlike the blank sheets of aluminium you use to creat the modifications. which will normally be much easier to weld. Can be a tough job, you didn't mention if you are an experienced welder or not. |
Posted: Mon Feb 14, 2005 4:45 pm Post subject: |
Wolf, i am a fairly good welder, but ive only ever used MIG or ARC before, im gonna drop into one of the welding supply shops round here and have a chat about welding aluminum with a MIG, if they recon its a go, ill have a try at it.
Aaron, i thought the BA XR6T had a plenum arrangement like the EA-ED but with really short runners? - or maybe im thinking of the nizpro manifold, oh well. |
Posted: Mon Feb 14, 2005 9:50 pm Post subject: |
| Think you need a TIG for alloy welding... Ive apid for alloy welding and it costs alot more than steel to be welded. I made a manifold last year and there was $300 for just the welding |
Posted: Tue Feb 15, 2005 4:11 pm Post subject: |
| yeh, i decided it was too much effort, then i realised that the nizpro XR6T manifold, was the bottom half of an EF-AU style BBM, (the runner part) with a new plenum on top, i think im gonna go that way (cos i can make a new plenum easy as aout of mild steel). |
pinkbits8u Fordmods - Getting Side Ways
Age:36 Posts: 403 Joined: 05 Nov 2004 Location: newcastle NSW, Australia
Posted: Sun Mar 13, 2005 7:52 pm Post subject: |
| yeh tig wouldav been the go , ive tried it with al before and i m no good so i get the boilies to to it , ill be probably modifieing or building one from scratch later in the year for a 6/71 and im not lookin forward to it |
MarkZE Fordmods Oompa Loompa
Age:31 Posts: 22 Joined: 10 Dec 2004 Location: Brisbane QLD, Australia
Posted: Mon Mar 21, 2005 12:15 pm Post subject: |
TIG or MIG welding of ally is acceptable but either way you have to have a high freqnecy pulse welder. You can't just use any old TIG or MIG machine. The cheapest welder I have seen with the right functions is around $3000.
TIG welding is generally used because it is neater and give the nice fish scale welds. MIG welding ally is easier and quicker.
Also welding cast aluminium is okay as long as you use the filler wire designed for cast aluminium. The other trick is to make sure the ally is very clean and not oil soaked. If it is oil soaked to need to hot wash it or clean it with a solvent and a wire brush to get the grime out of the pores in the castin as much as possible. |
Age:23 Posts: 1303 Joined: 08 Nov 2004 Location: Bunbury WA, Australia
Posted: Tue Mar 22, 2005 1:37 pm Post subject: |
| MarkZE wrote: | TIG or MIG welding of ally is acceptable but either way you have to have a high freqnecy pulse welder. You can't just use any old TIG or MIG machine. The cheapest welder I have seen with the right functions is around $3000.
Someone's done this before!  |
[36 queries :: 0.04283 seconds ]
